Squeaky Brakes
Discussion in '2.5 Gen Tundras (2014-2021)' started by hillbillytoyo, Nov 15, 2017.
  1. Nov 15, 2017 at 2:35 AM
    hillbillytoyo
    hillbillytoyo [OP] Just a country boy
    Daniel
    WV
    21 Limited Cement CM TRD OF
    Alright I have a 2017 Tundra Crewmax with 10k miles. My brakes have been squeaking for about 3k miles. But it only does it when just starting up. I have visually inspected them and they are fairly clean. Even when I had my 10k service done they checked out ok. This is driving me crazy. Has anyone else had this problem this early on?
  2. Nov 15, 2017 at 2:42 AM
    Take to stealership..I mean dealership..under warranty
  3. Nov 15, 2017 at 3:57 AM
    Cbrunt
    Cbrunt 2017 SR5 CM
    Charles
    Sacramento
    2017 White SR5 Crewmax
    Bakflip g2 cover Trd pro grill/bulge Nerf bar steps
    Amen. Take advantage now while you can
  4. Nov 28, 2017 at 2:31 AM
    TTund16
    TTund16 New Member
    I have a 2016 and it squeals only during the first brake ... after that it never does!!!
    my brakes are fine and there are no issues.
    I think it needs to warms up especially if cold or damp.
    we discussed this once and not sure if there was a consensus.
    15whtrd likes this.
  5. Nov 28, 2017 at 12:08 PM
    hillbillytoyo
    Daniel
    WV
    Mine does the same thing. But I'm still not ok with the brakes squealing on a new vehicle.
    Cali2017NeverAgain likes this.
  6. Nov 28, 2017 at 2:13 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Same with mine. Been doing it since day one. Only on the first time braking backing out of driveway. Dealership says "normal". :notsure:
    TNTundra7 and GlobalGuy like this.
  7. Nov 28, 2017 at 2:28 PM
    TheBeast The Beach
    if brakes are good, you can add some brake grease to the back of the pad. Usually when changing brakes they do it. Maybe yours is all dried out.
    Also morning mist/rust will do that too if car sits outside.
  8. Nov 28, 2017 at 2:36 PM
    TTund16
    TTund16 New Member
    don't worry about it. u have one of the best powertrains in the market! :)
  9. Nov 28, 2017 at 2:38 PM
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    my 2017 has 3200 and same thing squeeks on the first pedal press in the AM after that no noise. I will make sure dealership takes care of it i want 0 Noise. Thats not a normal thing
  10. Nov 28, 2017 at 3:10 PM
    Samoan Thor
    Samoan Thor God is technically an alien
    Limited 2014 crewmax 4X4
    Kings F&R, no sway bars
    Happens often on cold days, mine squeak on first brake on first startup but that’s it. Brakes are still good 2014 45000miles stock brakes
  11. Nov 28, 2017 at 6:42 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Squeaky here too. When its time to change them I'm going to slather them in anti squeak slime.
  12. Nov 28, 2017 at 7:15 PM
    gtbigup02
    gtbigup02 New Member
    Ken
    Clarksville, TN
    2017 GMC Sierra
    I don't think that's for squealing. It's to prevent them from locking/sticking to the backing plate. So it's not even on the rotor side which typically cause squeaking. If it's a widespread thing then maybe that how they perform, like buying high performance pads, most of them squeak.
    TTund16 likes this.
  13. Nov 28, 2017 at 9:56 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Lubricant goes on the pins so the pads don’t get stuck in contact with the rotor.
    Brake quiet or paste goes on the backside of the pad to help with the noise.
    TTund16 and TheBeast like this.
  14. Nov 29, 2017 at 4:30 PM
    TTund16
    TTund16 New Member
    good points. I assume u never want grease or slippery stuff on the rotors ;)
    that's true. my co-worker has a fancy sport car and it makes that noise. somewhat annoying since his car makes the noise a lot but my Tundra does it only once and it doesn't bother me! at least I know the brakes are working ... lol
  15. Mar 8, 2019 at 10:01 PM
    fulanoderock
    fulanoderock New Member
    Ventura County
    2018 Toyota Tundra TRD Sport
    I know this is an old threat, but I just got this same exact problem on my brand new Tundra! And it's annoying the shit out of me. I asked the dealership to take a look and they said they found nothing wrong, except for some slight rotor warping which is super odd. They couldn't replace it, but said to report back in 6 months if it continues. My truck squeaks no matter what when lightly braking. I love my truck and I can overlook, but it's still irritating that my brand new truck is making this noise.
  16. Mar 9, 2019 at 3:24 AM
    TTund16
    TTund16 New Member
    Squeak will eventually go away!
    How many miles on your car?
  17. Mar 9, 2019 at 9:02 AM
    fulanoderock
    Ventura County
    5,456 miles.
  18. Mar 9, 2019 at 9:11 AM
    knoxville36
    knoxville36 New Member
    Knoxville, TN
    2024 GMC Sierra 1500 Elevation w/3.0 Duramax
    Mine has done it since the day I drove off the lot. It is only that initial stop once I back out of the driveway and hit the brakes. These rotors will literally show rust on them the next morning from driving.
    As crazy as it sounds all my trucks have done that just on the first brake. My Silverado did it and even my wife's Accord does it....
  19. Mar 9, 2019 at 11:09 AM
    maxcala
    maxcala New Member
    Max
    L.A.
    2014 Limited Crewmax
    I got the same squealing sound when I first got my tundra around mid 2014. Didn't want to go to the dealer because they said there was nothing wrong with it. Complained on the phone and they fixed it. Tech said one of the them is stuck.
  20. Mar 9, 2019 at 10:17 PM
    georgiey22
    georgiey22 SW Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
    Same here...hear it backing out of driveway on cold mornings. Immediately goes away.
    TTund16 likes this.
  21. Mar 10, 2019 at 12:21 AM
    TTund16
    TTund16 New Member
    mine does it the very first brake after sitting overnight. I Never had them checked since I don't think there is a problem.
    My co-worker has a very nice Dodge Charger and the brake noise drives me crazy when we go for lunch but he says they are ok ... I wouldn't like it if my brakes made noise all the time.
  22. Mar 10, 2019 at 11:40 AM
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    Same here. Had Toyota look at it and they said it was common. Said my brakes were fine.
  23. Mar 11, 2019 at 5:33 PM
    fulanoderock
    Ventura County
    Mine do it all day no matter what. The squeaking is non-stop. The service guy said if it continues by the next service then he will consider changing out the rotors with the warranty. He said there is some warping, which is odd for a new truck isn't it?
  24. Mar 13, 2019 at 12:02 AM
    TTund16
    TTund16 New Member
    Warping can happen if the rotor is wearing unevenly and it's no longer flat or even. Bad brake pads or intermittent touching can cause this.
    In a new car, I seriously doubt if calipers or pistons are bad. If they change the rotors, make sure they change the pads as well as they maybe the source of the problem.
    Do you have the noise on all wheels?
    fulanoderock[QUOTED] likes this.
  25. Mar 13, 2019 at 8:05 AM
    fulanoderock
    Ventura County
    It's coming from the rear, possibly from the driver's side. I can hear it louder when I drive my objects due to the echo.
  26. Mar 14, 2019 at 3:39 AM
    TTund16
    TTund16 New Member
    That's good news. It's just one wheel. Maybe bad brake pads or rock or something got caught in there.
    Go bug them and they will fix it before the next service. Tell them it should not be making noise and other wheels are ok and it's a safety concern ...
  27. Mar 14, 2019 at 4:00 AM
    Rngr188
    Rngr188 Ranked the best new member of all time
    Chad
    Harrison AR
    2020 1794 MGM TRD OR
    Yep mine does it on first stop on a cold morning sometimes when I back out of my driveway sometimes at the end of the street but that's it also sometimes when the it's cold and I pull my boat out of the garage. 2017 37k miles on it and it seemed to start once I replaced the factory tires with LT load range E tires, they really affected my braking and I only went up one size and they are factory width.
  28. Mar 14, 2019 at 6:15 AM
    TomyTun
    TomyTun New Member
    CA
    2016 TRD Off Road, Crewmax, 5.7L Non-FFV
    None
    Same as what everyone else has said. I noticed it when the temp is below 60 degrees in the morning and only happens the first two-three times I apply the brakes. I’m currently at 26,000 miles and it’s done it since day one. Truck is parked outside.
  29. Sep 12, 2019 at 6:13 PM
    Weaser116
    Weaser116 New Member
    Bill
    2015 Toyota Tundra DC
    I have a 2015 Tundra mine never did this until I replaced my rotors and pads with Toyota OEM parts I got from my dealership. Mine do this now in the morning whether I back out or pull out of my driveway. It stops literally by the time I get to the end of my street. It is annoying as hell. If it keeps up I will have my buddy at the dealer have it looked at. I saw some other threads where someone said it was a caliber going bad. I know it’s the back because I did the front first and then a few weeks later I had the rear rotors and pads replaced.
  30. Sep 13, 2019 at 9:39 PM
    nodnero
    nodnero I'm here legally yo!
    Temecula, CA
    Cement 2018 Limited 4x4 Crewmax
    18x9 Method 312 285/75R18 Toyo R/T Trail TRD Pro Suspension
    Since somebody else brought this thread back, I'll comment too as this is fairly relevant and currently on-going:
    A few months back at the 15k service I asked the dealer to check my rear brakes as they squeaked under light braking at all speeds but went away with moderate pressure. They couldn't replicate the noise and as I drove off, it was gone; assumed it was something loose. Next morning, squeak was back. With a long trip planned next weekend, I thought it would be smart to have it inspected and my service department said I was close enough to 20k miles (18,900ish) to get the service performed so the truck was dropped off yesterday. After being unable to replicate, I provided many tips to help hear the quite obvious noise and midday today was advised they were replacing the rear brake system after foreman inspected. A few hours later, the brake swap was in a holding pattern as they were now waiting on Toyota's decision on whether or not to replace the rear differential and rear axle as well for a potentially soon to be released TSB.
    When I picked up the loaner they provided, service advisor informed me there were 2 other Tundra's with "a very similar" issue in service at the same time as mine.
    TTund16 likes this.
