Squeaks and clatters
Discussion in '1st Gen Tundras (2000-2006)' started by Cacoleman2014, Jul 25, 2018.
  1. Jul 25, 2018 at 4:42 PM
    Cacoleman2014
    Cacoleman2014 [OP] New Member
    Louisiana
    2006 Tundra SR5 double cab
    So I recently purchased a 2006 Tundra SR5 double cab and I am hearing some weird noises. Got 158000 miles on it. When I drive slow (like parking lot speed) I get a squeak in the back of the truck that sounds like a hamster wheel squeaking. It squeaks in tune to the throttle until higher speeds then goes away. At slow speeds while coasting I get a clattering noise from the rear of the truck. Neither happens all the time, but more often than not. Also a little bit of a clunk either right after slow takeoff or sometimes after being stopped for a few seconds. Had a dodge for years so I really don't know much about these. I have my suspicion that it is a u joint, but not sure.Any info would be most appreciated.
    because_wumbo-truck likes this.
  2. Jul 25, 2018 at 4:50 PM
    Professional Hand Model
    Hand Protectors
    Get under there and put your hands on stuff. Grease the zerks on propeller(s). Check your carrier bearing bushing for wear (and play).
    Cacoleman2014[OP] likes this.
  3. Jul 25, 2018 at 5:08 PM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Yup u-joints or carrier bearing on the squeaks.
    Look for loose spring retainers or sway bar links on the rattle.
  4. Jul 25, 2018 at 5:14 PM
    Cacoleman2014
    Louisiana
    Parts don't look too expensive. Would all new u joints and carrier bears b overkill?
  5. Jul 25, 2018 at 5:15 PM
    Cacoleman2014
    Louisiana
    Is it a do at home job or is there things that have to be pressed ?
  6. Jul 25, 2018 at 5:25 PM
    Hand Protectors
    Pressed. You can take off propeller and take it to your local truck big rig shop and they will do it all. Make sure to buy the Toyota OEM carrier bearing as the others may be cheap hollow stuff. Do the greaseable zerks.
  7. Jul 25, 2018 at 5:36 PM
    Festerw
    Festerw New Member
    04 Tundra DC
    Only thing I'll disagree with is the greaseable part. My u-joint of choice is the Spicer sealed joints if they're available mostly because I'm terrible at remembering to grease them.
  8. Aug 25, 2018 at 1:09 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I just bought an 06 access cab and it does the same things.
  9. Aug 25, 2018 at 6:36 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Not sure if it's the same for double cabs but 2wd doesn't have grease zerks anywhere on the drive shaft.
    I remember the clunk you describe being a common thing for double cabs but cannot recall what it is. Search around for double cab tundra clunk in older forums and you might find it.
  10. Aug 31, 2018 at 11:33 PM
    Altitude
    Altitude OpsCkBad
    Charleston, SC
    Black 06 4.7 DC 4WD Limited 267k
    Lifted (Exact height unknown. I didn't install) 32" ATs
    Recently bought my tundra with 232k miles and i hear a constant squeak coming from the rear as well only when I back up though...
  11. Oct 23, 2018 at 5:42 PM
    Cacoleman2014
    Louisiana
    Update on the squeaks...... After some hassle I have gotten some good tires now and the mts are history. Took it to the Toyota dealership shortly after posting the original post and they said that noise was common for the truck. I have since put 10000 miles on the truck and the u joints are definitely sloppy. The guy at the tire shop says so much slop he can't align it... Wtf..... So tomorrow I guess it's off to the dealership to see what's going on.
  12. Oct 24, 2018 at 3:54 AM
    Hand Protectors
    Keep us posted on this. I’m at 160k on my 02’. Getting ready to replace the center carrier bearing and 4 u-joints (cardan joint) on the rear propeller.
    How many miles you have?
  13. Oct 24, 2018 at 4:06 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    That doesn't make any sense. The driveshaft u-joints have nothing to do with getting an alignment done.
    Ball joints would make sense.
  14. Oct 24, 2018 at 4:14 AM
    Hand Protectors
    Was thinking the same thing. Also, my front end squeaked bad until it was rebuilt with all OEM stuff.
    Could be the u-joints are going bad too as well as the front end stuff.
  15. Oct 24, 2018 at 5:31 AM
    Cacoleman2014
    Louisiana
    Yep I think it's all going bad.... I am at 162000, so I guess it's about time.
  16. Oct 24, 2018 at 2:18 PM
    Hand Protectors
    Yep. I paid a shop to do my front end and they did a terrific job. All OEM except the cam bolts which he said he wanted to use because they were better and could allow a better setting. I have no idea but its running great. So quiet and smooth.
    New lower control arms, new lower ball joints, new sway links, new shocks, new rotors/brake pads, new CV axles, cam bolts, etc. ran about $3400. I priced all the parts around $1700, so two days labor was another $1700.
    Prepping to do the rear prop carrier bearing replace. Will probs take the shaft up to a Heavy Truck Center and have them do the 4 joints. OEM Carrier bearing cost about $135 online. Shop said he’d do the joints for $100 parts and labor. Will double check that number one more time.
    Dannydirtyfingers likes this.
  17. Sep 28, 2019 at 10:54 AM
    merbesfield
    merbesfield New Member
    My 05 DC has a squeak on the right somewhere towards the rear door every time I go over a speed bump or make a right turn and tweak the body. So frustrating. Any suggestions would be appreciated.
