Squeaking noise
Discussion in '2nd Gen Tundras (2007-2013)' started by Jtrev11, Mar 26, 2017.
  1. Mar 26, 2017 at 9:40 PM
    Jtrev11
    Jtrev11 [OP] New Member
    2010 white base work Tundra
    i have an 2010 tundra base model I have this horrible squeaking noise when I start my vehicle but then goes away after 5-7 seconds, but it doesn't come on if I let the battery cycle all the way then start it, what could it be? After it sqeals it goes away for good. TIA
  2. Mar 26, 2017 at 9:43 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Typically that noise is from the belt slipping. May be time to replace.
    I assume the title was a mistake. Should it be squeaking or squealing?
  3. Mar 27, 2017 at 5:49 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Alternator belt is the usual suspect. Next up are the idler pulleys, though those tend to get loud and STAY loud. Good luck!! This should be an easy fix either way
    Edit: quick check on the alternator belt is to losses the alternator mounts slightly and use the adjusting nut/bolt the tighten the belt just a smidge and see if the noise goes away. Do not over stretch the belt (trust me). If the noise is gone after that, it's time for a new belt. $30-40 in parts and a 1-2 beer job
