Squeak From Front
Discussion in '3rd Gen Tundras (2014-2021)' started by TundraRunner481, May 20, 2018.
  1. May 20, 2018 at 9:21 PM
    TundraRunner481
    TundraRunner481 [OP] Kinda New Kinda Not
    SB
    So. Oregon
    2018 Cement SR5 CrewMax
    Not sure if anyone else with an '18 has a squeak when closing the door? Since it was new, it had a squeak from the front like a bird chirping everytime you close a door. Sounded like plastic rubbing from the front grille. Then i put the lift and tires on, since then it rides stiffer, so any bump was a squeak, it was driving me nuts! Had the wife take a listen while closing the door, and it is the support bracket for either the condenser coil, or trans cooler, I'm not sure which I didn't look that closely. All I know is I took the grille out, took the bracket off and lubed it up, (that's what she said) and squeak is gone. Hope it helps someone else, I can't be the only one.
    Stroke250 and 4x4_Angel like this.
  2. May 20, 2018 at 10:22 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    I got nothing. .. sorry... but this is funny:
  3. May 21, 2018 at 2:53 AM
    Stroke250
    Stroke250 New Member
    Todd
    Idaho
    2017 Ford F-250
    I have that squeak on mine as well.
