Spyder Tail lights?
Discussion in 'Lighting' started by Surfer Ken, Mar 28, 2018.
  1. Mar 28, 2018 at 8:39 PM
    Surfer Ken
    Surfer Ken [OP] New Member
    Ken
    Orlando, FL
    2018 Limited TRD CM smoked mesquite
    JL audio sound system, step rails, 3" lift, 20"rims 34" Toyo tires
    looking at purchasing these lights for my 2018 cm. anyone have any insight?Screenshot_20180324-184801.jpg
  2. Mar 28, 2018 at 9:01 PM
    Mat1018
    Mat1018 New Member
    Mat
    2016 Super White platinum CM 4x4
    4" lift, spyder headlights and tail lights, LT headers. Carven exhaust, and XD series monsters II wheels.
    I run them on my 16. I like them I don't have any complaints about them.
    Surfer Ken[OP] likes this.
  3. Mar 28, 2018 at 9:04 PM
    Surfer Ken
    Ken
    Orlando, FL
    is the install easy?
  4. Mar 28, 2018 at 9:07 PM
    atxtundra
    atxtundra New Member
    Install was super easy. Have some spare fuses ready in case you pop one. Do one taillight at a time and make sure everything works before putting it all back together.
  5. Mar 28, 2018 at 9:08 PM
    Mat1018
    Mat1018 New Member
    Mat
    Yep it is. 2 torques screws inside the tail gate area hold them on and they pop out away from the truck. Wiring is alittle weird because you use one of the bulb connections to plug into the new tail lights. But it's easy once your start putting it all together
  6. Mar 28, 2018 at 9:12 PM
    Mat1018
    Mat1018 New Member
    Mat
    Yeah I didn't have any of the new style short fuses on hand that was fun. Blow the fuse then try to figure out why tail lights didn't work haha.
  7. Mar 28, 2018 at 9:13 PM
    Surfer Ken
    Ken
    Orlando, FL
    thanks, I'm gonna order them. Do you have black outs? I was initially wanting the smoked glass but I heard that they are hard to see during bright sunny days. so I'm leaning torwards the black back w clear lens
  8. Mar 28, 2018 at 9:14 PM
    Surfer Ken
    Ken
    Orlando, FL
    would hate to get rear ended
  9. Mar 28, 2018 at 9:16 PM
    Mat1018
    Mat1018 New Member
    Mat
    Yeah I have the exact ones you posted. Smoked can look good depending on body color. But I had smoked tail lights before on a car and FHP didn't like that. Got that moving violation ticket.
  10. Mar 28, 2018 at 9:18 PM
    Surfer Ken
    Ken
    Orlando, FL
    thanks for the feedback
  11. Mar 28, 2018 at 9:19 PM
    Mat1018
    Mat1018 New Member
    Mat
    The clear housing is more then bright enough when brake lights are on. Even in bright sun sets.
  12. Mar 28, 2018 at 9:19 PM
    Mat1018
    Mat1018 New Member
    Mat
    No problem glad to help.
  13. Mar 29, 2018 at 5:09 AM
    Nebz
    Nebz New Member
    Orlando
    2014 Magnetic grey SR5
    Front Mesh Grille upper and Lower, Factory Steps, Flipbak cover, Spray in liner, Ballistic Sythe wheels, weather tech liners with tundra badges
    Just a few suggestions. When I installed mine the clips that hold the screws were not good at all so I stripped my OEM lights for the clips and used those. I also found that I had a plug with a broken prong so I used the factory plug and it worked.
  14. Mar 29, 2018 at 5:13 AM
    Surfer Ken
    Ken
    Orlando, FL
    Thanks for the tip, should I disconnect the battery negative when installing? to maybe prevent popping a fuse?
  15. Mar 29, 2018 at 5:28 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    I believe they are popping fuses because they had the wrong polarity plugged to start. It wasn’t the clearest when I installed mine and I work with electricity every day.
    If you disconnect the battery but roll polarity you will blow the fuse when you reconnect anyway. That’s what I’m thinking but the fuse blowers might chime in. :thumbsup:
  16. Mar 29, 2018 at 6:05 AM
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    For Spyders, take a look at smoke red on Tundras, or Recons in same, subtle and OEM-like. Spyders where you can see right through to the white tubes like your pic remind me of CFL bulbs. That’s just my personal opinion, if you like them, go for it. In the end, you have to like them.
    Too bad the QC isn’t great on Anza Eagle Eyes, that’s my favorite look, like Caddy’s and Audi’s, thin red LED strips.
    After removing the 2 torx bolts, be careful pulling away the taillight, the plastic clips can break apart. I’d do it in a warm garage or warm weather when it has more flex.
  17. Mar 29, 2018 at 6:14 AM
    Surfer Ken
    Ken
    Orlando, FL
    Thanks! I'll make sure to be super careful with removal. warm shouldn't be a problem, we're pushing 90°F down here in Florida. melting may become an issue. lol
  18. Mar 29, 2018 at 6:34 AM
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Lucky! We were in Orlando and Bahamas over spring break. Back to the cold north now. Yesterday, I took my 3rd brake light cover inside and re-wrapped it (damaged the vinyl when I took it off to put in LEDs).
    Easy to do, soapy water, squeegee, heat gun or blow dryer. Wrap costs less than $2 on eBay. I’m hesitant on dark tail lights, don’t want anyone to hit me.
    Enjoy the weather!
  19. Apr 4, 2018 at 11:47 AM
    Surfer Ken
    Ken
    Orlando, FL
    here we go
    Mountun Goat likes this.
  20. Apr 4, 2018 at 12:57 PM
    Surfer Ken
    Ken
    Orlando, FL
    Installed and got brake override malfunction, now truck won't go into gear. fml
  21. Apr 4, 2018 at 4:40 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    What? What did you do?
  22. Apr 4, 2018 at 5:21 PM
    Surfer Ken
    Ken
    Orlando, FL
    I think I connected the lower led plug into the brake light socket backwards. Pretty sure I blew a fuse under the dash. I will find out tomorrow morning. Need some low profile fuses.
  23. Apr 4, 2018 at 5:22 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Should be an easy fix then. Do the opposite of what you did and change the fuse. GL
  24. Apr 4, 2018 at 5:58 PM
    Surfer Ken
    Ken
    Orlando, FL
    I hope so, thanks
    BTBAKER[QUOTED] likes this.
  25. Apr 4, 2018 at 8:28 PM
    atxtundra
    You blew the 15a STOP fuse under the hood.
    Check the 15a TAIL fuse under the dash too.
  26. Apr 4, 2018 at 9:21 PM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    I have the smoked red ones since 2014 and they work great.
    Hope you get the install all working properly. They are nice taillights.
  27. Apr 5, 2018 at 6:18 AM
    Surfer Ken
    Ken
    Orlando, FL
  28. Apr 5, 2018 at 6:56 AM
    atxtundra
    Ahhh you have a 2018. Yup mines a 17. Glad you found the culprit. Good luck!
  29. Apr 5, 2018 at 7:17 AM
    Surfer Ken
    Ken
    Orlando, FL
    Success! thanks guys. Spyder needs to update their manual. There arent any black wires coming out of the 2018 Tundra taillight assembly. 20180405_100858.jpg
  30. Jun 21, 2019 at 8:29 AM
    rollingTide29
    rollingTide29 New Member
    Chase
    Murfreesboro, TN
    2019 MGM TRD Sport Crewmax
    It seems everyone is blowing fuses when installing? Is there a way around this? lol. I want to pick up a set of the smoked red for my '19. I am not an electrical person by any means.
