Spyder headlights
Discussion in 'Lighting' started by robzillaaa, Aug 20, 2018.
  1. Aug 20, 2018 at 6:09 PM
    robzillaaa
    robzillaaa [OP] New Member
    I have a question about these headlights. I have a 2018 tundra sr5. Will i need anything extra or is it just plug and play? Pic for reference
  2. Aug 21, 2018 at 8:03 AM
    PMG
    PMG New Member
    Plug and play, be sure to swap over the side amber markers. Most use 35 W HID kits to bump up the output as it's pitiful.
    Looks awesome though.
    Lots of threads on it if you search.
  3. Aug 21, 2018 at 11:27 AM
    War Machine
    War Machine SSEM # 5 3MW
    Also swap the leveling motors over to the Spyders. They don’t come with them.
  4. Aug 21, 2018 at 3:19 PM
    robzillaaa
    Thanks everyone
  5. Aug 21, 2018 at 7:14 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
  6. Aug 29, 2018 at 5:05 PM
    robzillaaa
    Can someone explain this further. I just installed the headlights but the side amber markers aren't working.
  7. Aug 29, 2018 at 5:11 PM
    atxtundra
    atxtundra New Member
    Spyder headlights don’t have bulbs in the side markers when they are new. He is saying to be sure you put the bulbs from your stock lights into the spyders.
  8. Aug 29, 2018 at 5:22 PM
    robzillaaa
    But i had to remove the bulb and plug in the connection to the sides. Sorry i am confused.
  9. Dec 10, 2018 at 8:29 AM
    edwin729
    edwin729 Tundra Life
    Edwin
    Arizona
    2023 Silver Tundra Crew 4x4 Plat
    I just reinstalled spyder headlights after I was sent replacements due to film tint chipping. Now I have issue with the new ones with the led light bar not turn on. Anyone have any idea or suggestions what the issue might be? I'm thinking its bad headlights as the previous set were working just fine.
  10. Dec 10, 2018 at 10:10 PM
    Cuzican
    Cuzican New Member
    Louisiana
    2017 Black Platinum Crewmax Tundra
    8" Lift, 22x10 Fuel Forged FF19, 37x13.50r22 Trail Grapplers, Amp Research steps, Spyder black smoked headlights with 35w HID's, all interior lights LED, Undercover tonneau.
    Check the connection on the back of the headlight, there are 2 wires that jump from the running light to the led bar, they have a disconnect in them for people that want to run ignition power to them. I forget the wire colors, but pretty sure the 12+ wire is green, the other wire is ran with it.
