Spyder headlights w/ HID bulbs shaking?
Discussion in 'Lighting' started by UTTundra, May 29, 2018.
  1. May 29, 2018 at 7:57 AM
    UTTundra
    UTTundra [OP] New Member
    Lou
    Utah
    I have the Toytec HID kit installed in a set of Spyder headlights. I'm happy with the output, but the lights shake over bumps. I've tried re-seating the bulbs, but it didn't help. Has anyone else dealt with this issue? Any suggestions on how I might fix them? I know the Spyder projectors are cheap, but want to attempt to fix this before I start looking into a proper retrofit.
  2. May 29, 2018 at 8:17 AM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Mine shimmy a tad but only over rough roads, and nothing that I even notice unless looking for it
  3. May 29, 2018 at 8:39 AM
    UTTundra
    Lou
    Utah
    I don't recall mind being as bad as they are now when I first installed them. I'd mess with them more, but it's a pain in the ass having to drop the N-fab bumper a couple inches (after pulling out the light bar), then pull the grill, etc.
  4. May 29, 2018 at 8:55 AM
    Eclipsed & Floating
    Voluptuous Whitey
    Why are you dropping the bumper to get the grill off????
  5. May 29, 2018 at 9:45 AM
    UTTundra
    Lou
    Utah
    My bumper overlaps the bottom of the grill by 1/8-1/4”. I could probably wrestle it off without dropping the bumper a hair, but would probably scrape it up pretty good doing that.
  6. May 9, 2019 at 2:19 AM
    tristan71187
    tristan71187 New Member
    Tristan
    2016 Inferno CM
    Just curious if you figured out a fix?
  7. May 9, 2019 at 6:34 AM
    UTTundra
    Lou
    Utah
    Haha, yeah. I got rid of the spyders and switched to the OEM LED headlights.
    Never had any luck getting the spyders to stop shaking. I also tried a set of OEM retrofitted headlights with Morimoto projectors. Those also shook. Using a more advanced mounting method for those projectors might have helped, but I got tired of messing with it.
  8. May 9, 2019 at 7:00 AM
    tristan71187
    Tristan
    2016 Inferno CM
    How do you like the the OEM? Were they complete plug and play?
  9. May 9, 2019 at 7:25 AM
    UTTundra
    Lou
    Utah
    The OEM lights are great. Much better than the Spyders. Almost as good as a quality HID projector, with none of the additional worries of shaking projectors, failing components, etc. I used the plug and play harness made by @iHacker.
    iHacker likes this.
  10. May 9, 2019 at 7:39 AM
    tristan71187
    Tristan
    2016 Inferno CM
    Last question which ones did you get? Was it the 2019 trd pros?
  11. May 9, 2019 at 7:42 AM
    UTTundra
    Lou
    Utah
    Yes. 2019 TRD Pro LEDs.
  12. May 9, 2019 at 7:46 AM
    tristan71187
    Tristan
    2016 Inferno CM
    Thanks for all the help. I’m just going to order the oem and hopefully sell the spyders. I don’t feel like messing with them.
    UTTundra[QUOTED][OP] likes this.
