Spyder Black LED DRL Bar Projector with SEALIGHT 9005/HB3 High Beam H11/H9
Discussion in '2nd Gen Tundras (2007-2013)' started by A-Team Rock’in, Jan 3, 2021.
Has anyone used the LED Sealights in the Spyder projectors?
  1. Yes
    1 vote(s)
    100.0%
  2. No
    0 vote(s)
    0.0%
Multiple votes are allowed.
  1. Jan 3, 2021 at 6:40 PM
    A-Team Rock’in
    A-Team Rock’in [OP] New Member
    Andrew
    2011 Toyota Tunrda Rock Warrior
    Tow kit, rear air shocks.
    Has anyone used the Sealight LED in the Spyder projectors? The Sealights don't look like they'll work after taking them out. Wanted to see if anyone's tried this before.
  2. Jan 4, 2021 at 5:15 PM
    Scott08rwd
    Scott08rwd New Member
    2008 SR5 rwd
  3. Jan 4, 2021 at 5:49 PM
    A-Team Rock’in
    Andrew
    The hook-up looks different but I didn't want to force it. If you got them to fit I'll give it another shot. Thanks!
  4. Jan 4, 2021 at 6:24 PM
    Scott08rwd
    2008 SR5 rwd
    I hooked the LEDs to the truck's plugs. Not the headlight assembly ones.
  5. Jan 4, 2021 at 6:29 PM
    Scott08rwd
    2008 SR5 rwd
    I had it backwards the low beams fit with the clips on the headlight assembly. The high beams I took the clippy part off and used silicone to adhere the led. I think H1 highbeams would work as intended
  6. Jan 4, 2021 at 7:48 PM
    A-Team Rock’in
    Andrew
    the link you shared was for different headlamps. Just want to confirm you used the Spyder's headlamps and these Sealights LED's?
    if so how did you also go about getting the DRL LED hooked up? I have seen a few different methods to this. Thanks!
  7. Jan 4, 2021 at 8:40 PM
    Scott08rwd
    2008 SR5 rwd
    Yeah they are different models. My truck doesn't have drl's. So I hooked them to the side parking lights of my '08. I had to splice them in. The Sealights weren't an exact fit. I would recommend trying to find an exact match. Probably return the Sealights. What year is yours? Maybe I can give some more specific advice. I also added aftermarket lights to my VW. Which required changing the pins in the plugs.
