Sputtering Start
Discussion in '2.5 Gen Tundras (2014-2021)' started by jacob.jons.jj, Aug 30, 2017.
  1. Aug 30, 2017 at 8:40 AM
    jacob.jons.jj
    jacob.jons.jj [OP] New Member
    Jacob
    2014 toyota tundra SR5 5.7 trd4x4
    leveling kit
    Hello Everyone!! I have a 2014 Toyota Tundra 5.7L I bought used with around 70k it currently has around 88k miles on it. When I bought the truck I noticed the next day it started kinda rough so I figured it probably had some bad gas. I put a can of seafoam in it and the problem seem to go away. after that tank of gas ran out the problem began again once I filled it back up (regular gas) the problem began again. it only sputters on crank up after it sits for a couple hours. I done some research and found a recall for the ECU something to do with flex fuel crap. I took it to the dealership and they (supposedly) did the software upgrade. I picked it up from the dealership and it started fine. the next morning I get into it to go to work and it does the same sputtering crap. My next tank I put premium gas in the truck and the problem seem to go away for a couple weeks but its now starting to do it again. I get gas at the same place everytime with all my vehicles. can anyone help me with this or having similar issues?? im a die hard Toyota man and this one is really starting to upset me.
  2. Aug 30, 2017 at 8:57 AM
    jacob.jons.jj
    Jacob
    leveling kit
    it is not badged anywhere that says flex fuel.
  3. Aug 30, 2017 at 8:59 AM
    jacob.jons.jj
    Jacob
    leveling kit
    no I purchased it used around 70k miles on it.
  4. Aug 30, 2017 at 9:06 AM
    jacob.jons.jj
    Jacob
    leveling kit
    5TFDW5F17EX390459 my 8th letter is a 1
  5. Aug 30, 2017 at 9:08 AM
    jacob.jons.jj
    Jacob
    leveling kit
    awesome thank you!!!
  6. Aug 30, 2017 at 9:11 AM
    jacob.jons.jj
    Jacob
    leveling kit
    so mine is flex fuel?
  7. Aug 30, 2017 at 9:12 AM
    jacob.jons.jj
    Jacob
    leveling kit
    winter?? whats that?? I live in south Ga winter to us is like 75 degrees haha
    GNTundra likes this.
  8. Aug 30, 2017 at 9:16 AM
    jacob.jons.jj
    Jacob
    leveling kit
    Gotcha!!! would flex fuel have anything to do with this problem?
  9. Aug 30, 2017 at 9:16 AM
    jacob.jons.jj
    Jacob
    leveling kit
    yes that's what I've read is that they get stuck in e85 mode?? how in the heck can I find out if it is or not? and what can I do to fix it?
  10. Aug 31, 2017 at 3:25 PM
    Viper3G
    Viper3G Why isn't work more like this?
    Rick
    2016 Crew Max 1794 4WD Super White
    Phillips X-treme Ultinon LED H4 bulbs, 3M Color Stable 35 tint on front doors, 3M Crystalline 40 on sunroof, OEM bed liner, OEM running boards, Morimoto fog LEDs, Fold-A-Cover G4 Elite, Husky X-Act Contour floor mats
    Hope you figure it out and it's an easy fix. And welcome!
  11. Aug 31, 2017 at 3:28 PM
    Tundra_mike89
    Tundra_mike89 New Member
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Toytec boss coilovers Toytec shackles Total chaos uca's Method wheels Nitto ridge grapplers
    My friend had that issue on his 2012 tundra. I think he said it ended up being an ignition problem. I'll have to check with him and make sure
  12. Aug 31, 2017 at 4:51 PM
    jacob.jons.jj
    Jacob
    leveling kit
    so do i!!!! if not it will be traded in for a diesel
  13. Aug 31, 2017 at 4:52 PM
    jacob.jons.jj
    Jacob
    leveling kit
    idk what it is. if i run premium gas it fires up a lot better but on regular gas it barely starts. if the dealership cant get it fixed they can keep it haha
  14. Aug 31, 2017 at 4:57 PM
    Tundra_mike89
    Michael
    South Texas
    2016 TUNDRA CM 4x4
    Ok just got off the phone with him. It was a bad ecm module computer. Exact same symptoms as you. Dealer changed it out and it fixed the problem.
  15. Aug 31, 2017 at 5:01 PM
    jacob.jons.jj
    Jacob
    leveling kit
    Thank you very much!!! i have an appointment to drop it off tuesday for them to look at it.
    Tundra_mike89[QUOTED] likes this.
  16. Jul 11, 2018 at 12:40 PM
    Sabre8
    Sabre8 New Member
    2014 Tundra 4x4 extra cab SR5 long bed
    Anything since then? I have a 14 flexfuel 5.7 with same issues...
  17. Dec 11, 2019 at 7:45 AM
    Target612
    Target612 New Member
    I have a 2016 FFV 5.7L V8 4x4 crewmax. I feel the need to notify the public that my car was having really really bad rough starts in the morning - didn’t matter if weather was cold or warm - first start of the day always sounded like the engine was choking. I googled online and found this site and many other message boards about the Alcohol Density Calculation problems and the need to “reflash” the ECM (see Toyota Service Bulletin T-SB-0058-13).
    I took the truck in to the dealer yesterday, they did a cold start this morning after it sat in the lot overnight, and concluded it had this problem that is specific to FFV Tundra engines.
    The service advisor said that Toyota just came out with a new TSB a few days ago updating the old TSB so that it now covers the fuel pump and the “reflashing” of the ECM, it now also covers all FFV Tundras from 2009 - 2019. The new TSB is T-SB-0166-19.
    So I hope this info helps, hit up your dealer if you are having enginestart-up problems with your FFVengine Tundras, and pass the word around!
    If I had known about these engine issues, I would have NEVER bought a FFV engine!!!
    This TSB engine fix is only good if you’re under 96 months or 80,000 miles!!!
    ryanjheise and kodyquist21 like this.
  18. Dec 12, 2019 at 1:52 PM
    ryanjheise
    ryanjheise New Member
    2015 SR5 FFV 5.7 4x4 CrewMax
    TRD Dual Ex
    Target612, same exact problem and result from dealer. I have 2015 Crewmax 4x4 5.7L V8 95,000 miles. Cost is approx $1,200.00. Not to excited about that. Can't get FFV in many places in Kansas anyway so next Tundra will NOT have FFV.
    Anyone have any long lasting affects by not repairing asap???????
  19. Dec 30, 2019 at 1:32 PM
    ryanjheise
    TRD Dual Ex
    Two mornings in a row it almost didn't start. Finally took it to a mechanic I trust. He's working on it as we speak after getting the same diagnose from Toyota dealer as Target612. Will find out later today if a reflashing did the trick.
  20. Dec 31, 2019 at 8:37 AM
    haysr1
    haysr1 New Member
    2015 Tundra TRD 3'' Toytech Boss on 34'' Nitto Ridge Grapplers
    I just started experiencing the same issue. I would definitely like to know your findings. Thanks!
  21. Jan 2, 2020 at 10:13 AM
    ryanjheise
    TRD Dual Ex
    My mechanic was able to "reflash" (update and calibrate flex fuel system) the computer and so far after 3 days in a row no issues. Didn't have to replace the fuel pump at this time. Didn't charge me much. Will update this post if anything changes. Just to confirm, my original diagnose by the deal was "Alcohol Density Learn value to high at 81%".
    haysr1 likes this.
  22. Jan 2, 2020 at 10:15 AM
    haysr1
    haysr1 New Member
    Did you have any codes/check engine light on?
  23. Jan 3, 2020 at 7:19 AM
    ryanjheise
    TRD Dual Ex
    I did not have any codes or check engine light. Wish I did. Are you getting in any warning lights.
  24. Jan 3, 2020 at 7:29 AM
    haysr1
    haysr1 New Member
    I don't have any codes either and the problem seems to be getting worse. I need to find an honest mechanic and have them flash and update the system. I'm in the North Denver area.
  25. Dec 1, 2021 at 6:39 AM
    Tundra6104
    Tundra6104 New Member
    2015 White 5.7L FFV
    Stock
    I'm having the exact same issue on a 2015 5.7L FFV and looking to "reflash" the ECM. Any reputable Tundra mechanic point outs in the Panama City and/or FL panhandle area?
