Spring compressors
Discussion in 'Suspension' started by sundance, Jun 5, 2019.
  1. Jun 5, 2019 at 6:24 AM
    sundance
    sundance [OP] New Member
    I've done plenty of mechanic work over the years. Most of it when I was much younger. I've replaced many strut assemblies and etc. However, I never done a strut/shock assembly on a truck with this large a spring. I currently don't own a spring compressor of any kind. I'm looking for recommendations. I want to change out my front shocks.
    Thanks!
  2. Jun 5, 2019 at 6:40 AM
    jeremyd
    jeremyd 2014 Crewmax SR5
    NV
    2014 SR5 CM 4X4
    ProComp 7" 35/12.50/18 -11
    I recently did some work on my truck with a 20 dollar spring compressor from Amazon. Or you can take it to a local shop..
  3. Jun 5, 2019 at 6:43 AM
    sundance
    I'm a Amazon Prime addict. What pair did you use? Thanks for the help!
    jeremyd[QUOTED] likes this.
  4. Jun 5, 2019 at 6:44 AM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
  5. Jun 5, 2019 at 6:47 AM
    P-Factor
    P-Factor New Member
    Yoda1, Uhhhh.... and sundance[OP] like this.
  6. Jun 5, 2019 at 6:56 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
  7. Jun 5, 2019 at 6:56 AM
    Jrharvey02
    Jrharvey02 New Member
    2010 Tundra CM 5.7 Platinum Dark Black
  8. Jun 5, 2019 at 7:00 AM
    sundance
    Thank You Gentlemen! I really appreciate the help.
    P-Factor likes this.
  9. Jun 5, 2019 at 7:01 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    I used a macpherson compressor off the truck in a vise for 700 lb springs and it felt super sketchy. I'll never do it again.
    If you have the means, take the struts off the truck and bring the assemblies to a shop with a legit floor mounted compressor and pay the $70.
  10. Jun 5, 2019 at 7:08 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    Go in early morning or late afternoon to a small shop with a case of Bud Light and ask if they'll change the springs over.
    801Tundra and sundance[OP] like this.
  11. Jun 5, 2019 at 7:10 AM
    MAK
    MAK Searching for Gnarnia
    San Diego
    2014 SilverSky DC TRD Limited
    FRAC, Console safe, Amazon special-console organizer, Rhino liner, Pace Edwards retractable tonneau cover, Drivers side swing case, AJT shift knob and matching key fob!, Interior trim De-chrome with Faux carbon wrap, color matched door handles and mirror covers, Maxpider 3D Floor mats, Custom Dog bed in DC area, BFG Radial TA KO tires, 18 x9 +20 Fuel Shok wheels, Toytec Boss 3:1(shackles), White Knuckle offroad sliders w/diamond plate step, Bumper skins, Blackout badges, Firestone airbags, RCI skid,
    Ditto for me. SUPER sketchy
    I changed the springs in my 1st gen with a spring compressor similar to those posted above. Scared the bejesus out of me. Thats why I bought a pre-assembled set for my 3rd gen.
    sundance[OP] likes this.
  12. Jun 5, 2019 at 7:19 AM
    jeremyd
    NV
    2014 SR5 CM 4X4
    Being scared is good !! It keeps you alive, Lol
  13. Jun 5, 2019 at 7:38 AM
    sundance
    What set did you go with? I've used FCS before and they're just okay.
  14. Jun 5, 2019 at 7:38 AM
    sundance
    Ain't that that the truth!
  15. Jun 5, 2019 at 8:15 AM
    xtyfighterx
    xtyfighterx New Member
    Ty
    North Idaho
    2015 Black Crewmax Mid Travel
    I’ve always used the weight of the truck to decompress like the videos above way easier than a compressor I’ve done at least a dozen Toyota’s this way. The spring won’t go anyway since it’s still all attached to the top shock mount it’s super easy.
  16. Jun 5, 2019 at 8:28 AM
    sundance
    Have you done a Tundra this way? I don't know if there is enough room to lower the assembly to the point of removing and installing it uncompressed.
  17. Jun 5, 2019 at 8:38 AM
    justfortun
    justfortun New Member
    James
    Boston
    2016 SR5
  18. Jun 5, 2019 at 8:40 AM
    MAK
    San Diego
    I actually ended up borrowing the most heavy duty ones that O'reilly had on their tool borrow program. They worked well, but I was still terrified.
    The ones that I had bought were supposed to he heavy duty, but I didn't feel comfortable with them for the truck springs.
    I pretty much did exactly as @justfortun did in his video. The sketchy part is transferring the spring from the safety of the large rod over to the strut. You gotta have faith and confidence in the strength of the spring compressors until you get the top nut threaded onto the strut. Thats the sketchy part.
    sundance[QUOTED][OP] likes this.
  19. Jun 5, 2019 at 8:45 AM
    sundance
    MAK likes this.
  20. Jun 5, 2019 at 8:53 AM
    MAK
    San Diego
    I was ok with the technique in the video up until the part where the dude sticks his finger between the springs in order to guide the shock bolt up thru the top hat while his buddy was compressing the spring with the jack. No way, Jose! One tiny slip and it's by-by finger. He definitely could have figured out some way to use a tool for that. Maybe a large flare nut wrench or something....
  21. Jun 5, 2019 at 9:07 AM
    xtyfighterx
    Ty
    North Idaho
    Yes I’ve done three tundras this way only difference is the skid plate just come off and sway bar either needs unbolted from the mounts or at the end links
    reneaux likes this.
  22. Jun 5, 2019 at 9:10 AM
    xtyfighterx
    Ty
    North Idaho
    Ya can’t remember what I used to guide it in but it doesn’t need much help just has to meet the hole then jack it up in it pretty simple. Decompressing the spring this way I think is actually safer than a compressor myself but to each their own. It’s also quicker and easier. Almost no room for error. Just make sure your jack is under the LCA in a good position and the jack can easily be lowered.
    reneaux and MAK[QUOTED] like this.
  23. Jun 5, 2019 at 9:14 AM
    djhase
    djhase member
    David
    Southern Illinois
    2019 Silver Tundra TRD
    I used a spring compressor once and almost lost a hand. I'll pay a shop that has the proper equipment to change over the springs. Last one charged me $50 to do my fronts. Definitely worth every penny.
  24. Jun 5, 2019 at 9:14 AM
    xtyfighterx
    Ty
    North Idaho
    Spring compressor are sketchy I won’t use em either.
  25. Jun 5, 2019 at 9:47 AM
    sundance
    Sounds good. Thanks for the info I appreciate it.
    xtyfighterx[QUOTED] likes this.
  26. Jun 10, 2019 at 6:45 AM
    phatjoe
    phatjoe New Member
    2019 TRD Pro Voodoo Blue
  27. Sep 27, 2021 at 5:37 PM
    Gamer68
    Gamer68 New Member
    2016 Toyota Tundra limited
    2.5 leveling kit//Hooke Road Front and rear Bumper w/lightbar//20" Black spoke Fuel Wheels wrapped in 33" mudders//TRD hood scoop//Weather Tech Floor mats//Black Waterproof seat covers//Hard tri-fold tonneau cover//
    So here is my question. why not use the spring compressors on the strut assembly while underneath the rig. Why disconnect at all if you are just going to put some leveling spacers in?
  28. Sep 28, 2021 at 3:40 AM
    Festerw
    Festerw New Member
    04 Tundra DC
    There's not enough room.
  29. Oct 2, 2021 at 4:18 PM
    Gamer68
    Gamer68 New Member
    Thanks for the info Fester. Will used the weight of the truck to compress/decompress the springs. Happy trails.
  30. Oct 2, 2021 at 6:31 PM
    Kfrog
    Kfrog New Member
    2016 Tundra SR-5
    I did replacement of shocks last week, still a little sore from lifting and working with springs. However, I do have a spring compressor like yours that works very well but is a little tight getting on spring and to give me more room ended up cutting 2" off the screws to allow them to fit between the frame. I used the truck jack under the shock to lift shock and get it positioned back in retainer bracket that is a little work but doable. I worked alone as there is not enough room for 2 in that wheel well, all's good.
