SprayIng atf fluid
Discussion in '1st Gen Tundras (2000-2006)' started by zipaloo, Jul 1, 2018.
  1. Jul 1, 2018 at 4:20 PM
    zipaloo
    zipaloo [OP] New Member
    Zippy
    2001 tundra
    2.5" body lift
    Howdy, I have a 2000 tundra with 228000 miles. Was driving home today noticed smoke billowing from the back of my truck. Pulled over to find atf all over the engine bay, mostly on the drivers side. I let everything cool down a bit, Ana started the engine again only to see fluid spraying in a pretty fine mist from somewhere on the drivers side of the engine. Any ideas on the likely cause?
  2. Jul 1, 2018 at 4:25 PM
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    Picture is worth a thousand words
    Black Wolf likes this.
  3. Jul 1, 2018 at 4:28 PM
    koditten
    Kirk
    Midland of the Mitten
    Lines that go into the radiator. Follow them down, you will find the leak.
  4. Jul 1, 2018 at 4:39 PM
    Yep...I think this is a common issue after time. I'm fairly certain I've seen this same problem here on the forum from other 1st gen owners.
