Spray wax / detailer recommendations?
Discussion in 'Detailing' started by HecticEnergy, Aug 6, 2018.
  1. Aug 7, 2018 at 1:41 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    This is the one Steve mentioned
  2. Aug 8, 2018 at 4:56 AM
    War Machine
    War Machine SSEM # 5 3MW
    I put Reload on half of the hood on both mine and daughter’s trucks yesterday, and Sonax on the other. At first glance, they produced similar results. I’ll do a water test this evening and report back. I didn’t want to do it immediately after applying, so it could cure some.
    The Reload is easier to apply. The Sonax is thicker, and doesn’t spread as easily.
    I also did a fender using Sonax as a quick detailer. It did ok. The thickness of it makes it a little tougher to use. I’d make sure it didn’t dry. Wipe it off fast.
  3. Aug 8, 2018 at 7:12 AM
    HecticEnergy
    HecticEnergy [OP] New Member
    TJ
    SE Texas
    2017 MGM Tundra SR5
    Winjet Rear brake lights, leather seats, BackFlip tonneau cover, Spyder headlights, Pro Grille, pop&lock
    Cool! I look forward to seeing the results!
    I ended up ordering some Reload (500ml spray) and ONR shine (32oz no wax).
    I’ll play with them independently before trying to mix into a detail spray. Just me and the kids until Sunday evening, hopefully I can take an opportunity to play with it.
    SouthBoundSteve likes this.
  4. Aug 8, 2018 at 7:42 AM
    briarpatch
    briarpatch New Member
    worth taking the plunge and buying a gallon?
  5. Aug 9, 2018 at 4:33 AM
    War Machine
    So, both seemed to have pretty equal water shedding levels. I got a good test with all the rain yesterday. One thing strange though. When wet, the Sonax side appears to have a lot more haze in it than the Reload side. It’s not apparent when dry. They look the same until covered in water. I didn’t get a pic yesterday because of the storm, but I took this one this morning, when it was wet from dew. Though it isn’t visible when dry, it is a turn off for me. They both seem to coat the same, but the Reload is easier to apply, so I’ll stick with that. The only advantage the Sonax has is the price.
    Reload on left, Sonax on right:
  6. Aug 9, 2018 at 5:12 AM
    Chu
    Chu New Member
    2014 Crewmax
    I'm a big fan of Reload.
  7. Aug 9, 2018 at 6:24 AM
    73bronco
    73bronco New Member
    2017 silver sky limited
    3/1 level ,295/70/18 toyo open country extremes,thule roof rack,color match door handles
    For a quick and easy shine between waxes I use turtle wax spray on as I dry the truck
  8. Aug 9, 2018 at 3:39 PM
    Pudge
    CT
    I really like reload as a sealant and ech2o for a detailed. I will be using some spray wax soon to add some depth and luster. Not sure what yet, either meg untimate spray was or megs gold class carnuba. I read the gold class carnuba looks better on dark paint but the ultimate is easy to use and lasts longer
  9. Aug 9, 2018 at 3:46 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Guys - just leave the research to Obssesed Garage. Matt will figure it out. Search YouTube and follow him. You won’t go wrong.
    HecticEnergy[OP] likes this.
  10. Aug 14, 2018 at 7:56 PM
    HecticEnergy
    TJ
    SE Texas
    2017 MGM Tundra SR5
    OPT Optimum (NR2010Q) No Rinse Wash & Shine - 32 oz. https://www.amazon.com/dp/B00D8DR0AO/
    ONR: as a rinseless wash I’m not really impressed. I did an evening wash after the sun went down behind the houses. The water I rinsed the truck off with was already mostly dry by the time I got to the hood (washed roof then drivers side doors and worked my way forward). Also not great at cleaning much off other than light dirt. I probably only put 50 mi on since my last wash, a few bugs on the grille didn’t seem to want to scrub off. I used 1.5oz in 3 gal of water.
    I’ll probably stick with a mr pink wash for now. I’ll try ONR as a detail spray next. Then maybe mix in some Reload and see how I like that.
    CarPro Reload Spray Sealant 500 milliter with Sprayer https://www.amazon.com/dp/B00L9A0AC8/
    Love the way Reload goes on and buffs off. Love the feel of the paint after as well. Super excited to see how this does over the long haul!
    I’ll take a few pics tomorrow after the sun comes up. It was dark when I’d finished.
  11. Aug 15, 2018 at 5:45 AM
    War Machine
    For the bugs, use bounce sheets and water. I spray water over the area, rub the bounce sheets over it, then rinse off. It works really well. I’ve seen guys put the bounce sheets in a spray bottle full of water and use that as well.
  12. Aug 16, 2018 at 6:50 PM
    War Machine
    Just tried this for the first time this afternoon. I ordered some after seeing your post. Wow. My first impression is that this stuff is top notch. You’re right about the slickness. Holy crap. I’m excited to use this more extensively. Thanks for the recommendation!
    @driverdog @SouthBoundSteve have you guys tried this?
  13. Aug 16, 2018 at 7:55 PM
    briarpatch
    Based on every review I saw, I ordered a gallon of this...Autopia has 25% off sale...can not wait to get it
    Pudge likes this.
  14. Aug 17, 2018 at 3:27 AM
    War Machine
    I also went ahead and ordered a gallon.
    driverdog likes this.
  15. Aug 17, 2018 at 3:32 AM
    War Machine
  16. Aug 17, 2018 at 3:33 AM
    War Machine
    driverdog and Pudge like this.
  17. Aug 17, 2018 at 11:51 AM
    Pudge
    CT
    I just washed my truck and then dried it. Decided to try out Megs ultimate wax which is a spray and only $8 at walmart.
    About 2 weeks ago I did a pretty extensive detail on my truck including clay mitt and megs polish followed by a coat of carpro reload.
    I will say the megs ultimate wax was very very easy to apply. Mist the panel, wipe it around then buff it off. The whole truck took maybe 20 or 30 minutes once it was all dry.
    I started with half the hood and while there was no noticeable change in the way the pain looked it was definitely smoother and slicker on the side with the megs wax. Even though I had just used reload 2 weeks ago. From there I worked my way around the truck. It did not leave any residue once buffed off. Even on black plastic trim. I also did the lights and there were no issues there either.
    My car was beading very well from the reload already so we'll see if this makes a difference or not.
    All in all I'd say this is a good product. They say it has very good longevity, more than most spray wax which leaves it maybe more towards a sealant than a wax.
    My next bottle of spray wax will be something specifically made for black or dark pain. I have read it actually does make a difference. If anyone has anything they recommend I'd be open to ideas.
    This is a good product overall and very affordable. It wont replace my beloved reload but is well worth having in the garage.
    Didnt take pics of the truck because I felt the thunderstorm moving in. Got her back in the garage for the afternoon.
  18. Aug 17, 2018 at 11:54 AM
    Pudge
    CT
    Anyone have anything the recommend for a dark paint? Or something you've tried that's specifically made for black or dark paint?
    I may try this beadmaker stuff when it's time for a new bottle of spray wax but hear good things about black paint specific products working well on dark blue cars
  19. Aug 17, 2018 at 3:20 PM
    #49
    briarpatch
    If you're talking about a quick detailer or spray wax, I've not seen one advertised as more beneficial for dark paint versus lighter colors. I have a pyrite mica truck, and have not noticed any difference between the products I've used. There are glazes, however, that are billed as 'for darker paint', such as PoorBoys Black Hole and Chemical Guys Black Light. I've tried Black Hole on a dark car, mainly to fill some light scratches the customer did not want to pay to correct. I also tried their White Diamond Glaze, for the same issue, which is geared toward lighter paints. There was no noticeable difference
  20. Aug 17, 2018 at 4:04 PM
    #50
    PermaFrostTRD
    Northern NY
    limited wannabe, suspension and tire improvements
    The meguiars quick (quik) wax and ultimate QW - maroon and black bottles, respectively - can’t be beat for results, ease of use, and forgiveness.
    It can literally be sprayed on your windows and plastic without causing the white spots. Can be applied in the sun and to a wet (minimally) surface.
    Can’t be beat in my opinion
    Pudge and SouthBoundSteve like this.
  21. Aug 28, 2018 at 5:17 AM
    #51
    War Machine
    So, an update to this experiment. I applied these to the hoods of mine and my daughter’s trucks on August 7th. I washed both again this past Saturday, so August 25th. The Reload was still in effect, and repelling water like a champ. The Sonax side was pretty much gone. Water was not repelled at all. So, after about 2 1/2 weeks, the Sonax had failed.
    After the wash, I used Carpro Eraser on my whole truck, washed again, and put P&S Bead Maker on the whole thing. I’ll report back in a few weeks to how well it held up. If it does the same as the Sonax, then I’ll just stick with Reload. I’ve actually yet to see Reload fail, though I do reapply it pretty regularly when I’m not testing other things.
  22. Aug 28, 2018 at 5:25 AM
    #52
    Pudge
    CT
    Thanks for posting this. I'm a big fan of reload as well. I first used it this summer. Last year I used their hydro2 and got a few months of protection, but I hear reload will last even longer.
    Only caveat to reload IMO is the lack of a good deep shine or gloss. Dont get me wrong it is shiny but not a really deep gloss. Interested in the beadmaker for that, or maybe aquawax which I've been ready alot od great things about.
  23. Aug 28, 2018 at 5:41 AM
    #53
    War Machine
    I have Aquawax, and it does shine up very well. I haven’t used it a ton though, so I can’t speak of how well it holds up. I’ve just done a few panels here and there. I like the Reload because it feels like it spreads better than the competition. I think it does a pretty good job of shining paint up. I know that people have raved about it when I’ve done other people’s cars.
    The only real downfall to Reload is the cost. It’s much more expensive compared to its competitors. That said, I feel like the same amount of product goes a long way compared to others. For example, as much as I love Bead Maker so far, it takes quite a bit of product to cover the truck. You have to put it in pretty thick. I used almost an entire one pint bottle on my truck. I also did my wife’s Sequoia, and it took the whole bottle, and I didn’t even do the roof. It’s nowhere near that much Reload to do the same thing.
    So, Reload costs at least twice as much, but I get at least twice as much coverage in my opinion.
    Pudge[QUOTED] and driverdog like this.
  24. Aug 29, 2018 at 1:29 PM
    #54
    Pudge
    CT
    Used this griots speed shine today to get off a shit load of smashed bugs on the front end and touch up a few spots from sap and finger prints. Worked well, very very nice spray nozzle, wipes off easily, leaves a good shine. It's cheap too, this big just was $10 at I think walmart. I think ech2o is better but this is solid for quick wipe downs and bug cleaning. It's slick too, but definitely on the thin watery side, it would be a great clay lube IMO especially for the price and amount you get.
    War Machine and HecticEnergy[OP] like this.
  25. Aug 29, 2018 at 5:24 PM
    #55
    briarpatch
    Great buy if u got that for 10.00...its normally 13.99 online. It is a solid quick detailer, and its what I use as clay lube. As silly as it sounds, Griots spray nozzles are some of the best out there. I save mine and re-purpose them when I empty a bottle of their product.
    HecticEnergy[OP] and Pudge like this.
  26. Aug 29, 2018 at 5:27 PM
    #56
    Pudge
    CT
    I got it with a coupon from detailed image with some polishing pads, not Walmart like I originally thought. To many orders lately lol.
    And I agree about the spray nozzle, it's really good and I'll definitely hold onto it when the bottle is empty
  27. Aug 29, 2018 at 6:59 PM
    #57
    tenntundra
    tenntundra 2013 SR5 crewmax Barcelona red
    Walter
    Tennessee
    2013 barcelona red sr5 crewmax TRD tundra
    3" suspension lift, BMF 20" wheels 305/55/20 nitto ridge grappler tires,painted RED bushwhacker fender flares,fold up tonneu cover,100 watt led fog lights,led interior lights,borla dual exhaust,tinted windows,window vent visors, Toyota hood protector,toyota step bars,spyder carbon fiber floor mats,k&n air filter,painted brake calipers red, installed red lug nuts on wheels remote start.
    I use the turtle wax ice.it does a good job and can use on the windows and doesn't leave any white residue.I use my California duster first then the wax.1/2 hour later looks awesome! That is how I have taken care of my 2000 tundra .
    don3032 and PermaFrostTRD like this.
  28. Aug 29, 2018 at 7:50 PM
    #58
    War Machine
    I’ve used that some also. Not bad at all.
    Pudge[QUOTED] likes this.
  29. Aug 29, 2018 at 7:55 PM
    #59
    Pudge
    CT
    This will likely be my go to clay lube and used for quick debugging of front grill.
    It won't replace the ech2o I used for waterless washes and quick detailing, it just doesn't seem as good.
  30. Aug 29, 2018 at 8:19 PM
    #60
    War Machine
    No, but it’s pretty good. There’s just better.
