Spotter Mirrors installed
Discussion in 'General Tundra Discussion' started by duece292, Mar 25, 2019.
  1. Sep 4, 2022 at 2:33 PM
    Musicmasterd12
    Musicmasterd12 New Member
    Southern Louisiana
    2011 4.6 Silver Sky Metallic DC
    Did you have to run wire from the mirror through the door into the interior in order to wire the mirror up?
  2. Sep 4, 2022 at 2:38 PM
    WillTunBlack20
    WillTunBlack20 New Member
    William
    Houston, Tx.
    2020 Tundra TRD PRO Midnight Black
    Grille Lights, Bumper Lights, Front Facing Camera, Interior Upgrade, Leer Topper
    @Musicmasterd12, yes sir, I did the short route, through the mirrors, to the plugs behind the tweeters in the door sail, posi-tap the wires #3 negative, #4 positive.
  3. Sep 4, 2022 at 2:41 PM
    Musicmasterd12
    Southern Louisiana
    so you just had to tap the wires in the bundle behind the door sail? Didn’t have to take full door panel off and run wire behind speaker into the interior by the kick panel?
  4. Sep 4, 2022 at 2:45 PM
    WillTunBlack20
    William
    Houston, Tx.
    Yes sir @Musicmasterd12, kinda, I had time to take the door panel completely off, but I didn’t want to mess with the kick panel, or the rubber boot, so just the bundle next to the tweeter, in the sail.
    Taco-Spike and Musicmasterd12 like this.
  5. Sep 5, 2022 at 6:18 AM
    COTundie
    COTundie Whoa Black Betty
    Trey
    Black 5.7 DC TRD 4x4
    Pretty things
    Forgive my ignorance...
    What the hell is a door sail? Kind of sail shaped plastic cover for the mirror mounts?
    Picture posted appears to be the harness for the door mirrors. Is this the harness you tapped into for your indicator signal? Obviously that would be almost too convenient.
    I would have to run a lead into the cab for puddle lights anyway. Just curious where you're picking up the signal wire.
    WillTunBlack20 likes this.
  6. Sep 5, 2022 at 6:47 AM
    Taco-Spike
    Two Trucks
    Yes. You got it.
    I did mine the same time I added puddles and front turn and mirror signals
    643D7811-40C4-4C7C-97D6-90755DE00367.jpg EC90235C-FEF4-4343-A553-FF41EEACB004.jpg F61E4AE5-227D-400F-8F0B-FA95AC267763.jpg
    mav7021234 and WillTunBlack20 like this.
  7. Sep 5, 2022 at 6:58 AM
    COTundie
    Trey
    Pretty things
    Very cool. Thank you.
    I'm debating the same thing right now. Don't have any issue with the factory mirrors, but the indicator is really nice since there are no others along the side of the truck.
    Also kind of worried I may break the factory mirrors while removing, so it might be nice to have replacements. :monocle:
  8. Sep 5, 2022 at 7:08 AM
    Taco-Spike
    Two Trucks
    Just take your time popping them out and in.
    Mine felt a little stuck first time removing them but stick with it and they will come out.
    if you break anything I can send you my stock ones if needed.
  9. Sep 5, 2022 at 7:48 AM
    COTundie
    Trey
    Pretty things
    That is a very kind offer I hope not to take you up on :D
    I picked up a cast aluminum speed square a while back and think it should do nicely.
    We shall see.
  10. Sep 5, 2022 at 8:15 AM
    WillTunBlack20
    William
    Houston, Tx.
    @COTundie, I was hesitant, at first, but once I put the plastic pry tool, under the mirrors, added some pressure upwards, mirrors tilted down, bottom of mirrors in, top of mirrors forward, @Taco-Spike, great work, puddles, and signals, will be my next steps, would have yesterday, but rain was in the area.
    Taco-Spike likes this.
  11. Sep 5, 2022 at 8:57 AM
    COTundie
    Trey
    Pretty things
    Ah. You must have jbl. My mirror panels don't have a tweeter in them.
  12. Sep 5, 2022 at 9:10 AM
    WillTunBlack20
    William
    Houston, Tx.
    20 TRD PRO, Midnight Black Metallic, upgrade from 14 Platinum MGM, do miss all the bells and whistles, but @RainMan_PNW, has put some great information out, and this forum, is awesome, someone has a answer, and can/will walk us through any issues, We All Rock.
    RainMan_PNW likes this.
  13. Sep 5, 2022 at 12:15 PM
    WVI
    WVI New Member
    @008 Tundra Limited
    I have a question about the P-side mirror..
    Is the main, large piece of mirror, flat?
    As in no distortion for field of view?
    I hoping the etching that state" Objects closer than they look" applies to the small spotter portion?
    I have stock mirrors, and I can't stand the stock convex mirror on the p-side. I've used big tow mirrors for years that had the main portion, just flat so the field of view is normal.
    TIA
  14. Sep 5, 2022 at 12:22 PM
    WillTunBlack20
    William
    Houston, Tx.
    I’m getting a great view from both, I think the warning involves both views, when I look the larger mirror, shows a good field of view behind the truck, the smaller mirror, shows the view, down the side, and eliminates my blind area, while backing, I can view the rear wheels, without any problem, @WVI
    WVI likes this.
  15. Sep 5, 2022 at 12:59 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It is the big mirror that has the 'warning' on it..
    I love these mirrors..
    My 2014 SR5 did not have the turn signal feed wiring in the mirror plug.
    It had the wires, but they had no power, same for the puddle light feed.
    D7816C05-2B0B-4CA8-BDD2-C8AD2BF259F5_zps_1da6a0f89accd13e9f0591c8f2f36b2c271f00bd.jpg
    I had to run it 6 years ago for my MUTH mirrors.
    Then I took it apart again a couple of years later to run my puddle light feed..
    3CA25F21-87C0-4191-A9F6-D753C3996F42_zps_f36506107c931b0615ad96b21cee6acf57e1e2da.jpg DC04B57D-2DE6-44DB-BD2A-368CF62A2F3E_zps_fa4058c35b74a905f4db23726360fb94061cfe42.jpg
    I put connectors in the door in case I need to remove the mirror..
    A61B7FEC-CDB0-4011-B300-14702C83CE41_zps_42200272b1d7d4fc13125c77d212be4e4272ad7e.jpg
  16. Sep 5, 2022 at 1:17 PM
    WillTunBlack20
    William
    Houston, Tx.
    My wires were #3 negative, and #4 positive, TRD PRO, were wired for signals, I’ll go back later, and add puddles, and signals on the outer side of the mirrors, maybe try some switchbacks led lights.
  17. Sep 5, 2022 at 1:42 PM
    1lowlife
    DADA
    2014 MGM DC SR5
    Yep, that's what the schematic shows.
    But I had nothing..
    Here is the puddle light if you need it, but it's a 2015 diagram.
    + 6 - 5
  18. Sep 5, 2022 at 6:25 PM
    WillTunBlack20
    William
    Houston, Tx.
    Thank you, I’m thinking, the puddles will require a little more attention, that will be the kick panel, and rubber boot, PRO not wired for puddles.
  19. Sep 8, 2022 at 11:03 AM
    #49
    WVI
    WVI New Member
    @008 Tundra Limited
    @1lowlife, Thanks for the pic from th cab. That's what I was wondering.
    1lowlife likes this.
  20. Sep 8, 2022 at 11:13 AM
    #50
    1lowlife
    DADA
    2014 MGM DC SR5
    You're welcome...
    Here is the other side..
    Much better than the little mirror I had on my other mirrors..
    CB6EF9C5-3C11-48AF-B36D-53378D177D6D_zps_2ddbc4dc64c4e8745df5b91b6b086b3155e57c33.jpg
  21. Sep 8, 2022 at 6:13 PM
    #51
    WVI
    WVI New Member
    @008 Tundra Limited
    Thanks again. I'm still on the fence about getting a set as I really like a reg view mirror on the pass side.
    I can see that these would be much better than stock.
  22. Sep 8, 2022 at 6:21 PM
    #52
    WillTunBlack20
    William
    Houston, Tx.
    @WVI, I know the feeling, it was a minute, before I did the order, and you can always, switch back, to your original mirrors.
  23. Sep 9, 2022 at 5:48 PM
    #53
    WVI
    WVI New Member
    @008 Tundra Limited
    The problem is my originals have the convex glass on the p side..
    I'll still prolly get a set of those
