Spiker Engineering Lower Ball Joint Bolt Test (1st Gen)
Discussion in '1st Gen Tundras (2000-2006)' started by NickB_01TRD, Aug 19, 2022.
  1. Aug 31, 2022 at 9:02 PM
    #61
    richsadams
    richsadams New Member
    Northwest
    2000 SR5 AC 4x4 4.7L
    Just saw that. Too late to cancel my order online. These were about $50 shipped and it cost $10 to return the others. I'll try calling in the morning to see if they can cancel the order. if not I guess I'll measure them when they get here too.
    In my case - not taking it off road and not even a daily driver, just wanted to be proactive - I probably should have just stuck to the ones I received from Toyota. First world problem though, so not a big deal. We'll see how things turn out!
  2. Aug 31, 2022 at 9:03 PM
    #62
    NickB_01TRD
    NickB_01TRD [OP] You don't need less cars, just more driveway.
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    Do you have new lower ball joints on hand already? Could you measure how many mm deep the hole is on it?
  3. Aug 31, 2022 at 9:34 PM
    #63
    richsadams
    Northwest
    Two are flat on both sides and 2 have a "collar" for lack of a better term.
    "Flat" side (2) = 16.65mm
    "Collar" side (2) = 21.09mm
    The last photo shows the "collar" up close. The Toyota "green" bolt in that hole has about 7 or 8 threads left exposed.
    Hope that helps!
  4. Aug 31, 2022 at 9:36 PM
    #64
    NickB_01TRD
    Nick
    KY
    With the flat side being 16.65mm surely the shank is not that long. It doesn't appear to be. I haven't yet found any website that lists the shank length yet.
    richsadams[QUOTED] likes this.
  5. Aug 31, 2022 at 9:43 PM
    #65
    NickB_01TRD
    Nick
    KY
    Yeah if that shank were 16mm of the bolt then it would be over half way up the bolt. It seems that with the washer on the bolt theres no way that would be longer than 16mm probably at least half that. I think you should be fine
    richsadams likes this.
  6. Aug 31, 2022 at 9:45 PM
    #66
    richsadams
    Northwest
    So the ARP 663-1004 is listed as 35mm which, if it's measured like the others, would include the "shank". If so, that would still leave about 18mm of thread with the "flat" holes and about 14mm with the "collared" holes. I don't know if ours has the hardened washers that @spiker mentioned, but that would add another 1mm?
    Do I need to buy washers now? Sheesh! :confused:;)
  7. Aug 31, 2022 at 9:47 PM
    #67
    NickB_01TRD
    Nick
    KY
    They are included. If you look real close you can see them. One underneath each bolt.
  8. Aug 31, 2022 at 9:48 PM
    #68
    richsadams
    Northwest
    Oh... phew!
    I already boxed up the shorter ones to be returned so couldn't look at them.
    Good to know. :thumbsup:
  9. Aug 31, 2022 at 9:50 PM
    #69
    NickB_01TRD
    Nick
    KY
    Looking forward to what you find out. If the 35mm bolts clear like they should let me know then I'll order some for myself.
  10. Aug 31, 2022 at 9:51 PM
    #70
    richsadams
    Northwest
    So bottom line, it sounds like the ARP 663-1004 should work out okay? They're supposed to be here Friday, so I'll have a chance to measure them and post back.
    Guess I'll stick to my "Use these ARP bolts, but if they don't work for some reason, use the Toyota bolts instead" plan.
    BTW, the Toyota bolts did not come with washers so I guess they'd reuse the ones on it.
  11. Aug 31, 2022 at 9:59 PM
    #71
    NickB_01TRD
    Nick
    KY
    My Toyota ones didn't come with any and I didn't use any either.
    Seems like 1004 should work yes. No promises of course as I haven't gotten my hands on anything but just from an eyeball look at the shank length compared to thread length compared to the hole depth you measured it seems right.
  12. Sep 1, 2022 at 7:35 AM
    #72
    REESE77
    REESE77 New Member
    Reese
    03' 4x4 v8
    this is thread is great. keep us updated on the 1004. I am ready to order
  13. Sep 2, 2022 at 3:04 PM
    #73
    spiker
    spiker New Member
    Leon
    Portland
    I think it should work fine with the unthreaded shank, that portion will be inside the LBJ. What's really strange is that the 663-1004 bolts I bought last month were fully threaded, so ARP must have changed the design. Either that, or the pictures are old and you will actually get the fully threaded bolts - I'm really curious to find out!
    ETA: I just checked the ARP website, and while the photo shows an unthreaded portion, the dimensions suggest that it's fully threaded ("thread length = 35mm". So one or the other is wrong:
    G_unit3000 likes this.
  14. Sep 2, 2022 at 8:26 PM
    #74
    NickB_01TRD
    Nick
    KY
    Yes I saw that chart on another website too and thought that was weird. Yeah maybe pic is inaccurate. Seems like that would be something they want to get right.
    richsadams and spiker[QUOTED] like this.
  15. Sep 3, 2022 at 10:48 AM
    #75
    richsadams
    Northwest
    Received the ARP 663-1004 bolts yesterday. They don't have the shank that the online image shows... threads top to bottom. They appear to measure exactly 35mm per the description. (My measurement's a little off due to the shrink wrap).
    Here are comparison photos with the Toyota 90080-10066 bolts. Seems like with the hardened washers in place, they should be just about Goldilocks, perhaps just a tad longer?
    [​IMG] [​IMG]
    G_unit3000 and JasonC. like this.
  16. Sep 3, 2022 at 1:37 PM
    #76
    NickB_01TRD
    Nick
    KY
    Sweet, just what I was hoping for. I'll have to get mine ordered soon.
  17. Sep 5, 2022 at 8:25 PM
    #77
    Sunnier
    Sunny
    San Diego, CA
    Yeah, that was me. True story.
  18. Sep 5, 2022 at 8:27 PM
    #78
    NickB_01TRD
    Nick
    KY
    Thought so. Didn't want to tag you and be wrong. :thumbsup:
    richsadams and Sunnier[QUOTED] like this.
  19. Sep 13, 2022 at 11:31 PM
    #79
    NickB_01TRD
    Nick
    KY
    @richsadams
    Got my bolts installed. They work perfect with washers. Used a bit of blue thread-locker as well. Just took out one bolt at a time and replaced. No shank on my bolts either.
  20. Sep 14, 2022 at 1:29 PM
    #80
    richsadams
    Northwest
    Terrific news Nick! Thanks for posting. In the end I decided to have a bunch of stuff done on ours including replacing the timing belt, water pump, etc. so I'm taking it in on the 21st to have the LBJ's and CV axles replaced all at the same time. My wallet's gonna sting, but when all is said and done I'll have some peace of mind that everything's right, has a warranty for a while and that my back won't be aching for a week or two. ;)
    Now go out and drive 'er! :thumbsup:
  21. Sep 27, 2022 at 5:27 PM
    #81
    richsadams
    Northwest
    jsvwx and JasonC. like this.
  22. Nov 1, 2022 at 12:22 PM
    #82
    NickB_01TRD
    Nick
    KY
    Forgot to post this a couple days ago. Here are the results of all the bolts.
    LINK
    richsadams and spiker like this.
  23. Nov 1, 2022 at 2:19 PM
    #83
    richsadams
    Northwest
    Great news! Feelin’ good about the ARP bolts we used. Thanks for the update! :thumbsup:
  24. Nov 1, 2022 at 2:54 PM
    #84
    bfunke
    bfunke Tundra Curmudgeon
    South Carolina
    @NickB_01TRD - wifey agrees shaft length counts but also head size counts
  25. Nov 1, 2022 at 2:59 PM
    #85
    richsadams
    Northwest
    :eek2: :rofl:
    Tundra2 likes this.
  26. Nov 2, 2022 at 6:42 AM
    #86
    spiker
    spiker New Member
    Leon
    Portland
    @NickB_01TRD thanks for the shout out, hope you guys enjoy the read.
    BTW, I ran some tests on the Tundra M12 bolts as someone asked me to. The results are a little puzzling to me. If indeed the FSM torque is only 48 ft-lbs for them, then you'd have less preload (about 7,700 lbs) than you would with the M10 bolts at 59 ft-lbs (which had about 8,000 lbs). And that's two bolts vs four?
    I also did a reuse degradation study, these actually held up pretty well with reuse:
    I then tried to torque them to higher values to see what happens - the curve flattened out at only 10,000 lbs, which again is surprising because many of the M10 bolts did not flatten out until 12,000-13,000 lbs, and this one is much larger.
    Based on these results, I think you can safely torque an M12 bolt to about 80 ft-lbs, but I wouldn't go past that.
  27. Nov 2, 2022 at 11:03 AM
    #87
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Were these the early (00-04) or late (05-06) bolts?
    Edit: just realized it was a later M12 bolt. Which p# was tested? I think there are 3 different ones for the later model ones.
  28. Nov 2, 2022 at 11:31 AM
    #88
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I need to re-read this whole thread...
    FirstGenVol likes this.
  29. Nov 2, 2022 at 11:51 AM
    #89
    Mr.bee
    Mr.bee King Turdra
    SATX
    '02 AC TRD
    What? m10's are early, m12's are late. ?
  30. Nov 2, 2022 at 7:50 PM
    #90
    assassin10000
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    Yep. Larger for later year model '05+
