Speedometer Recalibration 05-06
Discussion in '1st Gen Tundras (2000-2006)' started by speedtre, Feb 8, 2020.
  1. Feb 8, 2020 at 7:14 AM
    speedtre
    speedtre [OP] New Member
    Dirty South
    So sent an e-mail off to Yellow Box about the 05-06 Tundra. This is their response. I can't get up under my truck at the moment (hurt my back at the gym), so I was wondering if any of you guys new the answer to their question?
    Hello,
    Are you able to check the Output Speed Sensor type, located on the
    transmission. If like attached photos, then yes, Yellow Box v5 is
    compatible. If has same 3-pin plug set then Plug-n-play Harness is
    available. For a "2-wire" sensor it will be Splice Harness only and
    require Yellow Box v5 "2-wire" unit.
    Thank you.
    Best regards,
    jennifer
    Toyota  VSS  connector _01.jpg Toyota  VSS connector  _00.jpg Toyota  VSS location  2.jpg Toyota 2-wire  sensor.jpg
  2. Feb 8, 2020 at 7:17 AM
    Professional Hand Model
    Hand Protectors
  3. Feb 8, 2020 at 7:44 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I believe it's the same pins, but from what 2 others in the past have said the 05-06 are set up differently and don't like calibration devices. Apparently the 5 speed trucks capture signal at the trans and the wheels and those signals hit the ECU from different points. If the ECU sees a different signal it assumes transmission slip and throws CEL.
    I don't know how true that is, I have seen guys run gears on 05-06 so I don't see why running a calibration would be any different. After seeing two guys report that on TS I can't advise it, but worst case if it doesn't work out you could easily sell it here to somebody with a 00-04 and recoup.
