Speedometer reading with larger tire
Discussion in 'Wheels & Tires' started by PeterB_Lost_Boy, May 30, 2019.
  1. May 30, 2019 at 10:06 AM
    PeterB_Lost_Boy
    PeterB_Lost_Boy [OP] New Member
    2019 Black TRD Pro
    Sorry if this has been covered, but does the digital dash speed pull from an analog source that feeds the speedo? Or does it pull from the GPS on the Nav? This is on a 19 with entune.
    I'm bumping up tire size and wondered what I would see on the dash. It's only a few MPH at Highway speed but that's enough to get the smookies mad sometimes.
  2. May 30, 2019 at 10:14 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Not gps or nav. Tire size in calculationd in ecu. The tire size setting can be changed with the right tools.
  3. May 30, 2019 at 10:16 AM
    Trooper2
    JR
    There are tire size calculators online that can tell you the difference in speed with change to tire size.
  4. May 30, 2019 at 10:59 AM
    PeterB_Lost_Boy
    2019 Black TRD Pro
    Saw those, just wondered if I'd be doing math in my head on the fly ;-)
  5. May 30, 2019 at 11:02 AM
    15whtrd
    15whtrd Mr. Blonde
    What size tire are you going to? I’ve heard that our trucks read a little fast on the speedometer. Bumping up in size might just put you right on or reading just slightly slow depending on the size tire you go to. I think 33’s put it right on the money if I’m not mistaken.
    Boerseun and Netmonkey like this.
  6. May 30, 2019 at 11:03 AM
    15whtrd
    15whtrd Mr. Blonde
    Just saying I’d see where you’re at comparing your speedometer to your GPS. Get the new tires and see where that puts you before you decide to put money into having it corrected.
  7. May 30, 2019 at 11:09 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    yeah. I went to 33's and my speedo matches what my gps shows.
    RBDTx, Rex Kramer and 15whtrd[QUOTED] like this.
  8. May 30, 2019 at 11:11 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    33’s are fine. I had 35x12s and used a hypertech device to change my speedo, setting the hypertech to 35s but that went too far the other direction.
    15whtrd likes this.
  9. May 30, 2019 at 11:22 AM
    Trooper2
    JR
    Difference will not be linear. The difference increases as speed increases. ex. .5 off at 35 mph but 2 off at 70 mph. if you can remember a few reference spots (mph) you can stay under speed limits. Also, by reading low, you are putting less miles on your truck.
    BlackSheep, Boerseun and 15whtrd like this.
  10. May 30, 2019 at 11:31 AM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    It’s really simple. You just need 2 baselines memorized. Street speed and highway speeds
  11. May 30, 2019 at 12:12 PM
    DvilleMafia
    DvilleMafia New Member
    DFW
    2018 Tundra SR5 4x4
    Same here, noticed from the day I got my truck I felt like I was going slow when set at 70. Sure enough checked with gps and I was 2mph under. Switched to 275/60R20 and now it’s dead on
    Netmonkey[QUOTED] likes this.
  12. May 30, 2019 at 12:30 PM
    Boerseun
    Boerseun New Member
    Ferdie
    Sarasota Florida
    2026 Limited, Wind Chill Pearl, CrewMax 4x4
    I just changed from the OEM tires (31.9") to a 34.2" tire. The OEM was about 1 or 2 MPH under and now I am about 2 miles over at 70 MPH highway speed.
    GPS shows 72 MPH when the truck shows 70. The way I typically drive (not 70) the difference would be irrelevant by the time they catch me. LOL.
    But, yes, at 70 there is about 3 MPH difference at highway speed. I am not running the GPS app all the time, so I have a mental note to stay at 3 MPH slower on Highway and say 2 MPH in the City if there is any suspicion of speed traps. I am not going to pay the $70 or so to have it recalibrated.
    Trooper2 likes this.
  13. May 30, 2019 at 12:48 PM
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Re calibrating the speedo is really more important for trans shifting than the mph number. Once you go to 35+ it really messes up your shifts
  14. May 30, 2019 at 1:02 PM
    DvilleMafia
    DFW
    2018 Tundra SR5 4x4
    I have to get a Hypertech to program right? And will that void warranty?
    Not concerned with speed but what you said, having correct shift points and mileage
