Speed sensative sunroof deflector?
Discussion in '2.5 Gen Tundras (2014-2021)' started by 996scott, Oct 10, 2017.
  1. Oct 10, 2017 at 10:40 AM
    996scott
    996scott [OP] New Member
    Scott
    Salt Lake City, Utah
    So since the time I got my Tundra I kept hearing a clicking sound coming from the sunroof if I had it opened. It was driving me crazy and then I realized the wind deflector was moving up and down depending on the speed. So am I correct that when the sunroof is open the wind deflector will drop down a bit when you hit about 40mph and then go back up again when you slow down below 40? At least that is what is what mine is doing.
  2. Oct 10, 2017 at 10:53 AM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    You got it. At least that’s what mine does too.
  3. Oct 10, 2017 at 1:14 PM
    Patriot
    Patriot Member
    Western NC, “Boondocks”
  4. Oct 10, 2017 at 1:14 PM
    McLovin
    McLovin New Member
    Harry
    Maryland
    17' QS CM Limited, 14' MGM T4R SR5 Premium,
    Mine does the same thing.
  5. Oct 10, 2017 at 1:27 PM
    996scott
    Scott
    Kind of annoying, but oh well. thanks guys
  6. Oct 10, 2017 at 1:31 PM
    Borgs
    Borgs New Member
    PA
    This was driving me nuts! I thought it was a defect and was going to raise it next time at the dealer. These trucks are smart! Although I am not sure this function is really necessary.
  7. Oct 10, 2017 at 2:57 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    yep, took me a couple of times driving with it open before I figured out what was making that noise.
  8. Aug 16, 2019 at 9:06 AM
    Twayt
    Twayt New Member
    2018 Tundra Crew Max
    The deflector adjusts to speed to prevent the annoying air pressure thumping in your ears. It does not adjust if back window is down on Crew max. No need to.
  9. Aug 16, 2019 at 9:15 AM
    SOB
    SOB Big Member
    Ohio
    2013 Red Crew Max Platinum
    Mine adjusts regardless of the back window position. 99% of the time if my sunroof is open so is the back window and the wind deflector most definitely moves.
