Speed Glampers Überfahrt: Big Bear June 22 - 25 2017
Discussion in 'California' started by osidepunker, May 9, 2017.
  1. Jun 12, 2017 at 5:23 AM
    osidepunker
    osidepunker [OP] OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    We lost Princess. Updated Roll Call.
    Anybody else want to roll with us???
  2. Jun 14, 2017 at 7:26 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    @Spvrtan Where are you homie??? You're not answering my emails and you never gave me your cell. Are you still coming???
  3. Jun 16, 2017 at 1:29 AM
    Spvrtan
    Spvrtan Amateur fabricator
    Kris
    San Diego, CA
    I don't see any emails. :notsure:
    I still plan on going but there's a chance I might have to back out -- I'll find out Monday. I'm having a few issues with my transmission and driver's side LCA.
    First, the transmission is heating up way too quick offroad. Yea, it's working harder because of the 40s but it only started happening in my last few trail runs and I've had the new tires for almost a month before it started. Engine temps are reading not super abnormal but they go to ~225 offroad and way too soon. I can probably remedy this with a set of pusher electric fans up front but there's no way I can get that done in the next week. Apart from that, I'll probably drain/fill the tranny fluids, too.
    Second, the driver's side LCA won't hold its alignment. The camber keeps going out. I'm thinking I might need to replace the alignment bolts altogether.
  4. Jun 16, 2017 at 5:57 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Well PM me your cell so you can keep me updated.
    I doubt electric fans are going to help you. The radiators can only radiate so much heat, airflow actually has very little to do with it. The stock fan provides as much airflow as is needed, more will not help.
    As for the LCA, you sure its not your spindle bending? The larger tires will only put even more force on a part that you already proved is kinda weak. If its not the spindle, do you have cam tab gussets? Those are a necessary mod if you off road. The stock tabs bend easy. I am not sure how new bolts will help. unless the current ones are stripped. Just make sure they are torqued properly.
  5. Jun 16, 2017 at 9:54 AM
    papasmurf
    papasmurf Savage Fabrication
    Bruce
    San Diego
    2007 4x4 Tundra
    07 Silver Sky 4x4 | Total Chaos LT | 2.5 King Coil overs & Bypasses | Camburg Bed Cage | 3.0 King Bypasses | 2.0 King Bumps | Custom Deavers | Nitro 4.88's | ARB Locker | Demello Sliders | 17" Double Standards | BFGKO2 37's |
    cam tab gussets are not needed with the BDS kit, they have super beefy cam tabs on the drop bracket. Id bet its the spindles.. the cam bolts dont make a diff either, you may have messed up the LCA bushing thats possible if you need a LCA @Spvrtan i have mine I can sell you one.
    Also most likely the issue you are dealing with on the trans is simple you are overworking with out the proper final drive ratio so its heating up, and you have probably boiled the trans fluid, which can happen with ATF fluid and once you over heat it, it will continue to overheat, the fluid starts to break down and looses its ability to cool and lude, also your factory trans cooler isnt designed to keep up with the excess heat you are putting into it with the parasitic drag caused by those wheels and tires. So you can either regear, or try and slap fixes on all these problems cropping up. And not to mention they will only get worse from here. Once one thing goes its going to be a cascading waterfall of issues. Those 40's are your problem, go back to 37's or continue to deal with issues until you build the truck properly.
  6. Jun 16, 2017 at 10:02 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    also considering the amount of money you have spend on the 40's and all the other assorted non-needed stuff on your truck you could have had gears and possibly lockers on it by now and wouldnt be having these issues. Maybe you should seek advice about proper steps to building a truck before spending money on stuff that will just cause problems..
    dragos28 likes this.
  7. Jun 16, 2017 at 10:15 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    lastly @Spvrtan if you are going to publicly post about potential sale of your truck @65k which is about 25k more than its worth... posting on a public forum about potential trans issues is probably not going to help your cause particularly since you are so active on social media...
  8. Jun 16, 2017 at 11:33 AM
    dragos28
    dragos28 New Member
    dragos
    tundra
    nothing much
    thats ok if he blows his transmission, i've got a gently used one i can sell him. hell, i'll even sell him the engine too, just as a back up.
    papasmurf likes this.
  9. Jun 16, 2017 at 11:36 AM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    i hear having spares is the way to go.
    dragos28[QUOTED] likes this.
  10. Jun 16, 2017 at 12:25 PM
    Spvrtan
    Kris
    San Diego, CA
    The cranking/pulling fan doesn't do much for both radiators (stock and SC) when you're constantly crawling/pausing at low speeds in at least 90-degree weather with no winds though. I've seen many dedicated crawler rigs that replaced their stock engine pulling fan with an electric one or augment with an electric pusher; it helps significantly according to the guy's I've spoken to. I'd have my fan hooked up to a switch in the cab so I can turn it on as an auxiliary fan when needed. I guess we'll see for the Tundra.. it might help.. it might not.. it really can't hurt to try and only costs a few bucks. I'll be able to monitor engine temps with my UltraGauge.
    Yea, it's not the spindle. I made a "jig" out of some scrap metal that conforms to a good spindle; that allows me to easily check of my spindles are bent and when I checked again recently it looks fine on both spindles. I have gussets, too, as they came with the bracket lift.
    There has to be play somewhere with the bolts is my guess.
  11. Jun 16, 2017 at 12:34 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    The real issue is the big tires and stock gears. I wheel hard and crawl rocks in the heat and my temps never change. As long as the clutch is engaged even at idle you have enough air flow. I'm telling you homie, electric fans won't help. Check your fan clutch, water pump, and fluid. If all good get gears
    As for the spindle your jig is no good. If it bends down low by the bearings you won't see a change in shape. Measure it like I showed you in Anza, from the wheel lip or sidewall to the uniball and compare to the other side. If both sides are bent then that won't tell you much either.
    If the bolt torque properly, then installing new bolts won't help
    CM-LENNY likes this.
  12. Jun 16, 2017 at 12:46 PM
    Spvrtan
    Kris
    San Diego, CA
    Gears are definitely the next major mod I'm already saving up for but I'm trying to work out a few things over this Summer with discount/partnership via a connection I have. The majority of my trail runs lately have been overlanding and I never have the transmission issues during those long hauls and mild trails (monitoring temperatures at a stable ~200). It's when I start to do slower or more technical trails in 4-low that it acts up sometimes.
    So being that I'll still be doing mostly overland runs over the next few months, I'm prioritizing doing a bunch of those mods while saving up for the gears/lockers because they're more functional for my immediate needs. The essential mods in progress are: 45-gallon auxiliary fuel system, 30-gallon water system, and triple-battery system. I need to finish these up by mid-July -- or try to.
    Yea, that method you showed me was actually the first thing I checked when I started investigating this a week ago (thanks!). It passed from various points and on both sides. I doubt both sides are messed up since it's only the driver LCA being funky whenever we check the measurements on shop's laser alignment rack.
    I'll check again on the torque though.
  13. Jun 16, 2017 at 1:08 PM
    papasmurf
    Bruce
    San Diego
    2007 4x4 Tundra
    SOOOOOOOO let me get this straight...
    you dont take advice on how to solve your problems, instead ....
    you claim adding 700lbs of Fuel/Water/Batteries and the housings to hold those is essential (adding more truck/sprung weight) which I know for a fact will also cost more than a set of nitro gears at 1100$ and can be installed yourself...
    and gears at a minimum are essential, but you know what isnt... 40's.... go back to 37's and avoid these issues until you can properly deal with 40's... or dont ....
    not to mention BDS is notably weak in a few areas, but what do I know I only had a BDS kit and ditched it for proper off-road suspension...
  14. Jun 16, 2017 at 4:22 PM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
  15. Jun 17, 2017 at 1:06 AM
    JBSTOY
    JBSTOY Was tired, so I woke up.
    Jack
    Unknown Origen
    2008 Toyota Tundra SR5 4x4 5.7litres of goodness
    Bilstein 6112s Front Bilstein Rear Fuel Rims
    Dang. Can't believe I missed this one.
  16. Jun 17, 2017 at 11:44 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    You didn't miss it! We leave Thursday! Roll with us!
  17. Jun 18, 2017 at 7:35 AM
    JBSTOY
    Jack
    Unknown Origen
    Cool. I think that I can make it for Thursday and Friday.
  18. Jun 18, 2017 at 4:23 PM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Right on homie! So you'll be camping with us thu and fri night? PM me your cell and email address
  19. Jun 19, 2017 at 6:59 AM
    #49
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Updated Roll Call and Meal Planning.
    I'm working on final routes now.
  20. Jun 20, 2017 at 6:25 AM
    #50
    osidepunker
    Alex
    2013 Tundra DC 4x4
    FIRE!
    As of midnight last night, 0% contained, 850 acres, on the NE side of the lake. This may affect our trip. I'm paying attention to InciWeb Holcomb Fire and I'll keep you guys updated. Cross your fingers and hope the firefighters stay safe up there.
    KevinK likes this.
  21. Jun 20, 2017 at 10:54 AM
    #51
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Updated first post, we lost Kris
  22. Jun 20, 2017 at 1:30 PM
    #52
    BestGen
    BestGen New Member
    Paul
    I'll be there Saturday. Not sure which truck I'll bring. Depends upon what trail we're running. Where will we rendezvous Saturday morning? :cool:
  23. Jun 20, 2017 at 2:18 PM
    #53
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Nice! Glad to have you roll with us. PM me your cell. I won't know where we'll be sat until we get camp spots
  24. Jun 21, 2017 at 11:57 AM
    #54
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Big Bear is a GO. We'll just have to avoid the Holcomb area.The smoke is heading north into the high desert so it won't be an issue. I'm not going to rigidly plan routes either, we'll just wing it.
    I'll be in Fawnskin around 2pm tomorrow. If anyone else want to roll with us, let me know.
    @BestGen PM me your cell and I'll text you sometime before Sat with a meet spot. @roypark is going to day run on Sat also
  25. Jun 22, 2017 at 7:07 AM
    #55
    BestGen
    BestGen New Member
    Paul
    I pm'd you over on T4R.
    osidepunker[OP] likes this.
  26. Jun 22, 2017 at 8:22 AM
    #56
    osidepunker
    Alex
    2013 Tundra DC 4x4
    updated first post. Added @BestGen , day running Sat
  27. Jun 25, 2017 at 9:53 AM
    #57
    BestGen
    BestGen New Member
    Paul
    Great day on the mountain! Thanks Alex for setting this up. Had a great time and it was a pleasure meeting you and your friends. First trail run in Moby Dick and he did fantastic! IMG_1356.jpgIMG_1358.jpg IMG_1362.jpg
  28. Jun 25, 2017 at 10:01 AM
    #58
    ReCKzX
    ReCKzX New Member
    2023 Tundra TRD Pro Ice Cap
    Who's grey tundra with the SDHQ bumper and fiberglass?
  29. Jun 25, 2017 at 11:14 AM
    #59
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    That's @roypark
    Nice rig with his fresh new LT frontend by Hollywood Fab!
    aka @papasmurf
    papasmurf and ReCKzX[QUOTED] like this.
  30. Jun 25, 2017 at 11:17 AM
    #60
    ReCKzX
    ReCKzX New Member
    Thats badass! He needs to post some more pics. I am going to PM him.
