Speaking of Tow Hooks....
Discussion in '2.5 Gen Tundras (2014-2021)' started by Triton19X2, Jan 10, 2022.
  1. Jan 10, 2022 at 7:11 PM
    Triton19X2
    Triton19X2 [OP] New Member
    2021 Silver 1794 Crewmax 4X4
    Been thinking about painting or powder coating my tow hooks on my 2021 1794. if you have done it, did you paint or power coat...pros or cons? Does anyone have any pictures of the final product?
  2. Jan 10, 2022 at 7:16 PM
    Bergy24
    Bergy24 New Member
    2021 Cement Crewmax Limited TRD 4X4
    Not the best picture but you get the idea. I painted these and so far they’re holding up well, but they don’t see any real use.
  3. Jan 10, 2022 at 7:23 PM
    Triton19X2
    Man that looks sharp.....just the right amount of pop in color. Did you prime it and then paint it or just paint? Also did you use a special paint or just Rustoleum or something?
  4. Jan 10, 2022 at 7:28 PM
    Bergy24
    Bergy24 New Member
    Thanks
    I just scuffed them up, and cleaned them with alcohol. I had some Rustoleum in a quart laying around and used a foam brush which didn’t leave any brush marks. I think I did 2 or 3 coats. They probably won’t last forever but didn’t take much time and easy to touch up. I also have the TRD front sway bar and skid plate with red letters to install when it warms up.
  5. Jan 10, 2022 at 7:35 PM
    Triton19X2
    Nice! that will look sweet with the TRD sway bar and skid plate! Post some pics when you get it done. Thanks for the paint info and your right it will be easy to touch up:hattip:....not planning on mine getting a lot of use but you never know....
    Anyone gone with blue? I like blue but not sure it will pop like the red does
    Bergy24 likes this.
  6. Jan 10, 2022 at 7:43 PM
    Bergy24
    Bergy24 New Member
    It may be a little while before I get them installed due to the weather. I also need to decide if I want to install them before I have the steering Recall checked/fixed.
  7. Jan 10, 2022 at 7:48 PM
    Triton19X2
    Understood....good luck with the steering recall and hope all is taken care of quickly. I have had several trucks over my lifetime with the last 3 being Tundras, 2007, 2016, 2021 for a reason....I like these trucks. Thanks for the pics....it looks sharp with those painted tow hooks!
    Bergy24 likes this.
  8. Jan 10, 2022 at 8:00 PM
    RobertD
    Robert
    DFW, Texas
    Not gonna lie, I absolutely loved the addition of the blue painted tow hooks. I did it initially cause it was cheap and I wanted to do something. But every time I walked to the truck from the front you can see the color peaking out at you and it just made me smile. Really added a lot for how simple it was.
    I just used some Rustoleum 2X primer and paint followed by their clear. I never attached anything to them but that combo worked well and no issues after a year.
    Make sure you check the frame where they mount. I had some minor surface rust that I wire wheeled and then just sprayed with black Rustoleum.
    bulldog93, FREEK, Badknees and 3 others like this.
  9. Jan 11, 2022 at 5:58 AM
    Triton19X2
    Man that looks awesome too! Perfect color of blue too....now I'm struggling on which way to go. I really like how the red stands out but that blue will look good on my silver metallic 1794 as well.
    Where did you get the blue grill emblem?
    Thanks to both you guys for posting pics....I'm definitely doing it once I decide on the color:cheers:
    RobertD likes this.
  10. Jan 11, 2022 at 6:39 AM
    RobertD
    Robert
    DFW, Texas
    If you have the red sway bar and other red accents, I'd say go with red hooks to tie it together. If that is not the case, go blue! So many folks have done the red.
    The grille emblem was a vinyl overlay. Unfortunately its no longer sold from a Cease and Desist from Toyota, same reason steering wheel emblems are no longer sold by companies. Some folks have just put dark tint over the entire grille emblem (the whole oval) which works pretty well and I haven't seen reports of it negatively affecting the sensor.
    Triton19X2[OP] likes this.
  11. Jan 11, 2022 at 6:46 AM
    Triton19X2
    Thanks man....I don't have any plans to add sway bar or other lettering at this time and your right about there being a lot of red out there....Blue may win out for sure
    RobertD likes this.
  12. Jan 11, 2022 at 6:50 AM
    Coloradonative75
    Coloradonative75 New Member
    Dave
    Aurora Colorado
    2020 4x4 limited
    Are-z series topper, bedrug,
    Painted mine. Definitely adds just a little bit of color.Used Rustoleum spray red, a couple coats.
    Triton19X2[OP] and RobertD like this.
  13. Jan 11, 2022 at 3:24 PM
    Triton19X2
    Man that looks sharp....wish I had thought about doing this before Xmas when it was crazy 75* around here:frusty:. Just need a few warm days now
  14. Jan 11, 2022 at 3:56 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    0FA1FB2F-0B9A-4181-9383-62AD61FE1AC9.jpg These big things make it look like it’s on casters!!!:) also have a picture of the stock ones that are grey but you can’t see them very well. I do not know if these will fit with the TRD front skid but I am fixin to find out. If not the stock ones will be touched up and reapplied.
  15. Jan 11, 2022 at 4:19 PM
    Midnite72
    Midnite72 Anything DIRT !!
    Bill
    Northern MD
    18 SR 5.7 4x4
    2” level P&P sliders
    C4790CD7-7636-4DAB-9047-C45ED86018B9.jpg One of my first mods
    took them off and had them painted at my work by are sign shops painter two coats of clear and are holding up well
    but full disclosure they have never been USED ! - truck will be on a trail once I can afford the correct lift tire combo and it has a little more AGE
  16. Jan 11, 2022 at 4:23 PM
    Triton19X2
    Now that's different....better patent that and sell to the 2022 owners:rofl:
    Retired...finally likes this.
  17. Jan 11, 2022 at 4:24 PM
    Triton19X2
    Now that pops for sure! Really stands out on the black truck
  18. Jan 11, 2022 at 4:25 PM
    Black@Blue19
    Ken
    SE Texas
    Nope those were a present but I can not remember where my daughter bought them. Rough Country Suspension,, had to go look.
  19. Jan 11, 2022 at 5:31 PM
    Mine are red with the TRD.
    Badknees and Triton19X2[OP] like this.
  20. Jan 11, 2022 at 8:45 PM
    Triton19X2
    That looks sharp with all the other red going on....Like it!
  21. Jan 11, 2022 at 10:38 PM
    NorcalHntr
    NorcalHntr New Member
    Nor cal
    2018 Sr5 Tundra Trd Crewmax Mgm
  22. Jan 12, 2022 at 7:03 AM
    Ronster
    Ronster New Member
    Ron
    2017 Tundra Crewmax
    where did you find your colored logo in the grill?
  23. Jan 12, 2022 at 7:29 AM
    RobertD
    Robert
    DFW, Texas
    @Ronster
    Adding @NorcalHntr
    Ronster likes this.
  24. Jan 12, 2022 at 7:36 AM
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I know they're not, but in the pic., your tow hooks look like they are part of the front sway bar! Optical illusion.
  25. Jan 12, 2022 at 7:48 AM
    Badknees
    Badknees New Member
    South Carolina
    Just rattle-can spray painted mine with Rustoleum red (cherry red I think - don't recall exactly) Nice contrast I think on the 040 white trucks:
  26. Jan 12, 2022 at 7:55 AM
    NorcalHntr
    Nor cal
    I want to know the same thing
  27. Jan 12, 2022 at 8:27 AM
    normagene
    normagene New Member
    Normagene
    New England
    2021 Cement DC Limited Texas Edition
    Texas Edition
    Painted mine……but never considered Speaking to my Tow Hooks. :)
  28. Jan 12, 2022 at 8:38 AM
    snowman19
    snowman19 New Member
    Scott
    Cypress, Texas
    2019 White Tundra CM
    Katskin leather seats, painted engine cover, fuse box cover, Rigid 30" light bar in bumper, Method 605 wheels, Bak roll up bedcover, Rhino lined grill surround and bumper caps
    Did mine awhile back with Rust-Oleum cherry gloss red. The sway bar is powder coated..
  29. Jan 14, 2022 at 11:28 AM
    Triton19X2
    Well, got it done. Went with blue....it is a little more subtle but I like it. Thanks for all the pictures and advise guys...much appreciated!
    FREEK, normagene, Badknees and 2 others like this.
  30. Mar 20, 2025 at 8:47 PM
    FREEK
    FREEK New Member
    Darren
    Olathe, KS
    2019 Tundra Limited Crewmax 4X4
    What? No Super White for us white Tundras? Mine might be a first when I spray them this weekend.
    RobertD likes this.
