Speakers humming/white noise with new everything from tech12v
Discussion in 'Audio & Video' started by Millerlowlife, May 26, 2021.
  1. Jun 27, 2021 at 9:29 AM
    #61
    jpotter
    jpotter New Member
    Josh
    2016 TRD Off-Road
    did that seem to help any? I was thinking about doing that too in the rear doors and just unhooking the added tweeters on the fronts. The tweeters def are most of my noise.
  2. Jun 27, 2021 at 9:34 AM
    #62
    Millerlowlife
    Millerlowlife [OP] New Member
    Toe-knee
    CM 4x4
    i haven't worked on it yet that is what im going to do next weeknd
  3. Jun 27, 2021 at 5:53 PM
    #63
    jpotter
    jpotter New Member
    Josh
    2016 TRD Off-Road
    Ok, so I pulled one of the rear door panels again and connected the Hertz tweeter to the stock tweeter plug (FYI, green is + blue is -). Way less hiss, but also way less volume. The stock tweeter hisses too, but more of a quiet deep static noise that’s much less noticeable. The stock tweeter is also not as loud. I may just run the stock tweeter in the back and disconnect the added on Hertz tweeters up front until I can figure this out.
    I also rechecked my ground and tried separating my power wire as far away from the speaker wire harness as I could at the amp, no difference.
    While I had the door panel off, last thing I tried this evening was using a spare piece of speaker wire and running it straight from the amp to the door speaker…still hissing just as bad.
    Also to be 100% sure, I went ahead and dremeled the bare metal under my ground again just to make sure. I am pretty confident my ground is good.
  4. Jun 27, 2021 at 7:31 PM
    #64
    FirstTruck
    FirstTruck New Member
    18 Tundra MGM CM TRD Sport
    Stock, for now
    After re reading some post, my guess is that you have an extra ground connected to the amp. Maybe you have a remote that is not needed.
  5. Jun 29, 2021 at 8:44 PM
    #65
    jpotter
    jpotter New Member
    Josh
    2016 TRD Off-Road
    I ended up getting ahold of Tech12v again and he had me turn down the gains on the actual LOC and not the amp. I turned them back about 1/3 of a turn. That made a big difference, there’s still a hiss, but it’s not near as noticeable. I would love for it to go away completely, but not sure that’s going to happen with my stock HU after talking to him.
  6. Sep 4, 2021 at 9:41 PM
    #66
    Mgmtundra
    Mgmtundra MGM Crew
    OP did you ever get your issue resolved?
  7. Sep 4, 2021 at 10:42 PM
    #67
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    It's in the post above yours...:eek2:
  8. Sep 5, 2021 at 8:31 PM
    #68
    Mgmtundra
    Mgmtundra MGM Crew
    I think the OP has a different problem, replaced the stock head unit so not sure why the loc would be in there. @Millerlowlife
  9. Oct 8, 2021 at 3:03 PM
    #69
    DerfM
    DerfM Knows nothing about trucks
    South Dakota
    2021 TRD Pro MBM
    So how's this going guys? I was about to drop $1200 and decided to run around the forum quickly and ran into this post.
