speaker water shields?....
Discussion in 'Audio & Video' started by Eric32444, Apr 24, 2019.
  1. Apr 24, 2019 at 6:16 PM
    Eric32444
    Eric32444 [OP] "Pick up your balls and load up your cannons..."
    Eric
    Panama City FL, Lynn Haven
    anyone with ideas other than foam baffles wanna post them here?
    this is my attempt using ********* adapters and some flexible plastic and JB quick weld...i dont see much posted about protecting new speakers. I guess no one bothers?
    8A3ABBEB-20D3-40A2-986E-3013B09F8EEB.jpg FFF7F5A3-6083-4584-BCA9-92A782FF215E.jpg
  2. Apr 24, 2019 at 6:27 PM
    Stumpjumper
    Stumpjumper New Member
    Fate, Tx
    2017 Tundra TSS 4x4
    I close my doors when it rains.
  3. Apr 24, 2019 at 6:35 PM
    muisejt
    muisejt New Member
    2017 Sunset Bronze 1794 Edition 4x4
    Auburn LSD, TRD rear sway bar, LED interior lights, Weathertech floormats, Fumoto valve
    I've never seen water damage on any of my speakers before...
    Trooper2 and Eric32444[OP] like this.
  4. Apr 24, 2019 at 6:44 PM
    Eric32444
    Eric
    you are smarter than you look!
  5. Apr 24, 2019 at 6:50 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
  6. Apr 24, 2019 at 7:25 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Looks good to me. Nice job
  7. Apr 24, 2019 at 7:30 PM
    Trooper2
    JR
    Houston, TX (Suburban South)
    2007 Tundra 5.7 L Double Cab TRD 2WD
    TSS 20's with Cooper ATP ll's, N Fab 3 Step Nerf Bars,, Pioneer AVIC-8100NEX, Masters Tailgate Replacement Latch with Camera, 1" Maxtrac Shackles, LED Interiors/Brake/Reverse/Cargo/Fog Bulbs, Fumoto Drain Valve, Toyota Aluminium Oil Filter Housing, TRD Shift Knob, Courtesy Door Projector LEDs with Toyota Emblem, Console Tray and Lower Divider.
    It vould help protect when hosing out the interior....
    :notsure:
  8. Apr 24, 2019 at 7:37 PM
    Pudge
    CT
    Rain water that gets between window and gasket. Most car manufacturers put some kind of shield on, and they all use plastic sheets between the inner metal door skin and the interior door panel. Pull the panel off after driving in the rain, there will be water in there, that why they also have weep holes at the bottom of the doors.
    Eric32444[OP] likes this.
  9. Apr 25, 2019 at 4:52 AM
    Eric32444
    Eric
    isn't OCD a requirement for this forum?
  10. Apr 25, 2019 at 5:29 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    When I changed my speakers out, I had a little water inside of my door as it had recently rained. You couldn't tell the speakers had any water damage to them, and my new speakers are just fine as well. I don't have a shield on them at all. Are the speakers designed to handle a little bit of water on them? Or does it just not get onto the speakers themselves?
  11. Apr 25, 2019 at 5:44 AM
    Eric32444
    Eric
    i am sure they are designed for it...i am probably overkill....probably only an issue as the vehicle ages....the stock speakers have a little shield over them
    Pudge likes this.
