Speaker systems
Discussion in 'Audio & Video' started by aag5, Nov 9, 2017.
  1. Dec 17, 2017 at 6:51 PM
    TuffTundra
    TuffTundra New Member
    Missouri
    2016 MGM SR5
    4" Rough Country Lift - Fuel Assault 20x10 - Nitto Ridge Grapplers 33x12.5x20 - 2018 LED Headlights - LED Lights all around - No Chrome - Tinted Windows & Tail Lights
    Mind providing a ebay link to the company that built your box?
  2. Dec 17, 2017 at 7:03 PM
    Tundra Fan
    Tundra Fan Got 17's?
    Toby
    Nor Cal (Placer Co.)
    Ha, reminds me of my favorite quote from The Mechanic, "Good judgment comes from experience and a lot of that comes from bad judgment."
    birdman076[QUOTED] likes this.
  3. Dec 17, 2017 at 8:00 PM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
    Sunnier likes this.
  4. Dec 17, 2017 at 8:12 PM
    Rica25
    Ricardo
    Tulare
    I installed Memphis highs and Addictive Audio 600 rms 10 inch sub with 1000 rms Audio pipe pushing the 10 inch sub with custom made box behind the seats ....sounds amazing and looks great
  5. Dec 18, 2017 at 6:53 PM
    TuffTundra
    Missouri
    2016 MGM SR5
    Does anyone besides ********* provide a plug n play amp that goes underneath the passenger side seat the subwoofer and front and rear door? I would really like to use a plug n play versus having to run speaker wire all over the truck.
    Sunnier likes this.
  6. Dec 18, 2017 at 6:58 PM
    birdman076
    Chuck
    Montana
    http://autoharnesshouse.com/41112.html
    The link is for the harness that plugs into the factory amp harness to interface with an aftermarket Line Out Converter, then you can hook an aftermarket amplifier in.
    Pudge likes this.
  7. Dec 18, 2017 at 8:03 PM
    Filthy13
    Filthy13 New Member
    NorCal
    2017 White 1794 TRD OR
    A few goodies
    @Danimal86 Did you do the install yourself or pay to play?
  8. Dec 18, 2017 at 9:27 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    did it myself
    no need to run new speaker wire unless you are pushing a bazillion watts to each speaker (seriously....you are fine wit the stock wiring)
    Here are some things to consider:
    no matter what, you need to run a power wire from the battery to the front passenger seat. Not very hard at all to do.
    The harness (tech12volts also sells them, i recommend them) bypasses the stock amplifier so it can be removed. It provides the speaker level output from the head unit that will go on the input of your amp, and the wires that go the door speakers that will be hooked up to the output of your amp.
    Filthy13[QUOTED] likes this.
  9. Dec 19, 2017 at 8:52 AM
    stripperclip
    stripperclip New Member
    COS
    2016 White Tundra DC SR5 TRD
  10. Dec 19, 2017 at 9:28 AM
    Filthy13
    Filthy13 New Member
    NorCal
    A few goodies
    Great feedback. Thanks man
  11. Dec 19, 2017 at 4:22 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    tech12volts
  12. Dec 19, 2017 at 4:45 PM
    aperezsh
    aperezsh Blessed are the peacemakers
    Ali
    cal-exit landed in GA
    16 Tundra SR5 4x4 Crew Max Magnetic Gray Metallic
    A little this and that...Broke now
    Two is One and One is none! Rock On!!!!!!!
  13. Dec 23, 2017 at 7:16 AM
    birdman076
    Chuck
    Montana
  14. Dec 28, 2017 at 3:42 PM
    TuffTundra
    Missouri
    2016 MGM SR5
    Hey guys...got a question. I'm slowing putting together a speaker system in my truck. I already installed some Infinity front/rear door speakers/tweeters and just ordered 2 10" subs for behind the rear seats. When I ordered the subs the guy told me that I needed to rewire the whole truck because the stock wiring would not be able to handle anytime over 40 watts. Is this true or was this guy just trying to sell me some extra stuff I really don't need? I was really hoping to buy the harness to use the stock wiring into the input side of the amp instead of running speaker wire all over the truck. Let me know your thoughts. Here is some speaker info:
    Front 90 watts RMS
    Rear 65 watts RMS
    Subs 50-300 watts RMS dual 2 ohm voice coils
  15. Dec 28, 2017 at 3:48 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Vendeta2k likes this.
  16. Dec 28, 2017 at 3:50 PM
    TuffTundra
    Missouri
    2016 MGM SR5
    I want to keep my stock head unit.
  17. Dec 28, 2017 at 4:11 PM
    Juanjoolio007
    Juanjoolio007 New Member
    Oregon
    24 Blueprint Sequoia Platinum / 23 Tesla MYP
    What size amp are you planning to use?
    Anything over 50 Watts per channel then yeah that’s a good idea.
    Let’s just say your spending $500 or more for an amp maybe closer to 750. Is another 20 bucks in speaker wire going to break the bank? Probably not.
    Will it add to your install time of course but it will be worth it. If you run a big enough amp and try to use the stock wiring you will have a voltage drop over the length of wire.
  18. Dec 28, 2017 at 4:16 PM
    Berdine
    Berdine Voodoo Sport
    Binghamton, NY
    2020 VooDoo Blue Trd Sport
    You'll be fine, but you have to run heavier speaker wire from the amp to the subs.
  19. Dec 28, 2017 at 4:29 PM
    #49
    TuffTundra
    Missouri
    2016 MGM SR5
    I’m thinking of either of these two amps:
    Kenwood KAC-7005PS
    5-channel car amplifier — 40 watts RMS x 4 at 4 ohms + 500W x 1 at 2 ohms (New Stock)
    Kenwood Excelon XR900-5
    5-channel car amplifier — 60 watts RMS x 4 at 4 ohms + 600 watts RMS x 1 at 2 ohms (New Stock)
    Yes I will run heavy wire to the subs :)
  20. Dec 28, 2017 at 4:44 PM
    #50
    Juanjoolio007
    Oregon
    For the first one stock should be ok. Second one I would say is borderline depending on actual gauge of stock wiring.
    Either way that would be a personal preference at that power level.
    However looking back at your speaker power rms if it was feasible I would go with the bigger amp. Under powering speakers is bad for them too.... when you try and rail on them.
  21. Dec 28, 2017 at 4:47 PM
    #51
    Danimal86
    Daniel
    Sacramento, CA
    I'm running a JL Hd900/5 that outputs 75w rms per channel and used the factory wiring. You will be fine. You most likely wont have it cranked to 11.
  22. Dec 28, 2017 at 4:56 PM
    #52
    Juanjoolio007
    Oregon
    I have the same amp. What size and color is factory? Color is to check against mine. I highly doubt it’s factory.... however I could be wrong.
  23. Dec 28, 2017 at 5:46 PM
    #53
    Danimal86
    Daniel
    Sacramento, CA
    ?? Not sure what you are asking
  24. Dec 28, 2017 at 6:04 PM
    #54
    Juanjoolio007
    Oregon
    I was asking what the size and color wire coming out of your amp to the speakers is. Mine does not appear to be factory so I was going to compare it to what your factory wiring was to see if in fact when the install was done(on mine) if they did run new speaker wires to the speakers. It was supposed to be done.
  25. Dec 28, 2017 at 6:08 PM
    #55
    Danimal86
    Daniel
    Sacramento, CA
    I think there's a picture in my build log showing the wiring. Link in my signature
    Juanjoolio007 likes this.
  26. Dec 28, 2017 at 6:31 PM
    #56
    Juanjoolio007
    Oregon
    Ok i checked out the build and the pics. Looks like our wiring is the same as far as I can tell. It looks the same between the amp and the Fix. Mine is all covered in wrap though. They said they ran new wires all the way to the speakers. I don't feel like ripping that apart to check. However on the other side of your plugs it looked like about the same gauge if not the same. I read somewhere that the factory used 22...thats pretty freaking thin. If it is what looks to be 16-18 then I would agree that is plenty to handle the amps we are talking about.
    Unrelated I am going to check how my amp is set because I too have that low volume hiss. It was worse and they dialed down the gains and that helped but its still there. I am sure it can be fixed. If not I have another reason to upgrade to in dash dvd and gps.
  27. Dec 28, 2017 at 7:30 PM
    #57
    UseEveryColor
    UseEveryColor Full-time artist and author
    Saint Augustine
    2018 CM TRD OR Limited 4x4 Cavalry Blue
    Toytec Boss 3" coilovers, SPC UCAs, Toytec 1.5" rear shackles, BFG T/A KO2 in 295/60/R20, Fuel Shok Matte Bronze wheels, Prinsu rack, Black Oak 40" Pro Series 2.0 lightbar in yellow, ARB Touring 8' awning, Eylar 53" cargo box, Lamin-X bed liner, console gun safe, Stealth running boards, Gator FX tonneau, Tundra badges shaved from doors, LaminX yellow fogs, short antenna, V-Leds in ALL exterior lighting, black-out tint, Tufskinz interior kit, matte black Tundra tailgate inserts, K&N air filter, Coachbuilder front bumpstop extensions.
    Just traded my 2015 Tacoma which had amazing sound for a 2018 Tundra (with Nav) and it sounds terrible. I adjusted the EQ but different FM and HD stations are at different volumes, I get very little bass from a CD, and Bluetooth from my phone is very quiet even when turned up. How could the Tundra sound so much worse than the Taco?
    geno0506 likes this.
  28. Dec 30, 2017 at 6:38 PM
    #58
    TuffTundra
    Missouri
    2016 MGM SR5
    Working on getting everything for my stereo upgrade. I just have to get my amp, processor, and sub box then I'll be ready to tackle this project....that and some warmer weather here in Missouri. I plan on installing everything under the passenger seat but was wondering what amp rack you guys used with installing your after market amplifier/processor? I would love to hear what you guys used and photos if you could post them that would be great. Thanks!
  29. Dec 30, 2017 at 6:40 PM
    #59
    birdman076
    Chuck
    Montana
    Watch the video in my build thread about adjusting the hiss. You basically need to take the hiss out with the LOC then adjust your amps accordingly. Clean signal into the amp == clean signal out of the amp.
    Juanjoolio007[QUOTED] likes this.
  30. Dec 30, 2017 at 6:41 PM
    #60
    birdman076
    Chuck
    Montana
    Industrial grade velcro, attached it right to the carpet.
