SPC UPC arm help
Discussion in 'Suspension' started by cain0725, May 6, 2021.
  1. May 6, 2021 at 4:51 PM
    cain0725
    cain0725 [OP] New Member
    had bilstein 6112 set at 2.5 height and SPC UPC arms. Stock wheels. The upper control arm sticks out further and is rubbing tire. I thought these solved problems. Shop installed it all
  2. May 6, 2021 at 4:55 PM
    What size tire?
  3. May 6, 2021 at 5:01 PM
    cain0725
    right now the factory is sticking out above the tire, new tires were falkin wildpeaks 295/60/r 20
  4. May 6, 2021 at 5:02 PM
    Post a pic.....I went with 1.25" wheel spacers to fit LT275/70/R18's with stock TRD wheels. Zone Off Road UCA's. Great alignment. No issues. Plenty of clearance from the UCA's. Some members are using Bora wheel spacers at 1" with clearance but there is a lead time on them.
  5. May 6, 2021 at 5:07 PM
    cain0725
  6. May 6, 2021 at 5:10 PM
    cain0725
    more pics
  7. May 6, 2021 at 5:12 PM
    cain0725
  8. May 6, 2021 at 5:13 PM
    Where is the UCA making contact with your tire? At full droop? Is the spindle making contact at static?
  9. May 6, 2021 at 5:14 PM
    cain0725
    i will not use spacers, i just cant see how this is right, is it a tire rim issue now ? Or did they install them backwards or upside down? lost???
  10. May 6, 2021 at 5:19 PM
    20210506_181835.jpg Here's a pic of my driver's side with my setup with LT's and different coilovers set at 3" lift. Wheels straight.
  11. May 6, 2021 at 5:28 PM
    cain0725
    are those SPC uppers
  12. May 6, 2021 at 5:29 PM
    cain0725
    i bet there flipped or upside down then, makes no sense
  13. May 6, 2021 at 5:29 PM
    It's all about wheel offset. TRD wheels are +60mm. TRD wheel back spacing comes into play bigtime depending on the tire you use and UCA. Nothing wrong with your SPC's. Who did your alignment?
    BlueRibbon4x4 and Backslider like this.
  14. May 6, 2021 at 5:31 PM
    Zone Offroad with 3 degrees caster to offset lift. Your SPC's are adjustable. They can't be flipped upside down.
  15. May 6, 2021 at 5:31 PM
    cain0725
    surely there marked somehow
  16. May 6, 2021 at 5:32 PM
    cain0725
    my i assume this is not normal
  17. May 6, 2021 at 5:35 PM
    cain0725
    shop who installed then
  18. May 6, 2021 at 5:35 PM
    cain0725
  19. May 6, 2021 at 5:38 PM
    Will another member please chime in now? I gave it my best shot. OP...wait. Another member will take over soon......I have to feed my grandson now.
    BlackSheep and MS22 like this.
  20. May 6, 2021 at 5:38 PM
    cain0725
    numbers
  21. May 6, 2021 at 5:38 PM
    Barrett50
    Barrett50 New Member
    Barrett
    Wisco
    2015 DC silver
    Did they give you an alignment sheet? (Print out)?
    Black Wolf likes this.
  22. May 6, 2021 at 5:42 PM
    cain0725
    no way tires are fitting with this crap
  23. May 6, 2021 at 6:53 PM
    cain0725
    any help here experts?
  24. May 6, 2021 at 7:05 PM
  25. May 6, 2021 at 7:08 PM
    cain0725
    well that is funny but not helpful
  26. May 6, 2021 at 7:09 PM
    blackoutt
    blackoutt YEAH BUDDY!
    Indy
    07 DC Long Bed - Old Man Tan
    OEM+
    The SPC ball joint can be slid outward to adjust camber. You look like you've got plenty of adjustment on the lower control arm to counteract the upper camber adjustment, pull that upper ball joint out board!
    Next the ball joint appears to be on setting C? I'd go for setting B and tell them to shoot for 3.5-4 degrees of caster on the re-align. It'll handle much better.
  27. May 6, 2021 at 7:10 PM
    ScenicRoute
    ScenicRoute New Member
    2021 Tundra CM Nightshade
    Eibach stage 2 (JUNK), SmartCap, Airbags, CoachBuilder Stuff, Bora spacers, 35” falken AT3W tires.
    You’ve yet to point out an issue or post a pic of your perceived problem. What do you want help with...? Looks fine to me. It’s not upside down and I don’t see any contact and your alignment is within spec.
  28. May 6, 2021 at 7:12 PM
    Yep^^^ I gave up...
  29. May 6, 2021 at 7:13 PM
    blackoutt
    Indy
    OEM+
    This is also true, your first picture looks like there's a mile, I don't see any rubbing either.
    I'm also really enjoying that I found out snip/copy/paste works on here. I'm having so much fun.
    Barrett50 and Black Wolf like this.
  30. May 6, 2021 at 7:16 PM
    Upside down was interesting too.....heh...heh...:rofl: :thumbsup:
