SPC UCAs to fix poor alignment?
Discussion in 'Suspension' started by CaptObvious, Aug 14, 2017.
  1. Aug 14, 2017 at 3:43 PM
    CaptObvious
    CaptObvious [OP] New Member
    Patrick
    2015 Black Tundra SR5 Crewmax TRD
    2015 SR5 TRD package: I have a 2.5" spacer lvl kit on the front and had my truck aligned at a Toyota dealer however I am still getting wear on the outside shoulders. I have noticed it looks like the wheels have a slight angle \ /. I recently put on load range E LTX2s. They have about 5000 miles on them. I do want to get myself some Open Countrys and the BOSS kit but not just yet, just bought a travel trailer.
    I think from what I have read alignment is tricky with our trucks with the stock UCAs. Are the SPCs from TOYTEC the way to go? IMG_0020.jpg
    CJ21 likes this.
  2. Aug 14, 2017 at 3:48 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    At 2.5" you shouldn't have problems. Maybe the dealer doesn't know that the alignment numbers aren't stock after the lift.
  3. Aug 14, 2017 at 3:51 PM
    CaptObvious
    Patrick
    That's what I thought, tat at 2.5 I should be ok...I'll have to check with them again.
  4. Aug 14, 2017 at 3:52 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I ask for .1 toe .1 camber and 2-3 degrees of caster. I've currently got 6 degrees of camber and can't reduce it because of my Camburg UCA's (i think). I'm not an alignment guru but @jberry813 knows his poop.
  5. Aug 14, 2017 at 4:04 PM
    joem1cha3l
    joem1cha3l New Member
    Albany, NY
    2016 Double Cab SR5 Blazing Blue Pearl
    BOSS Suspension, DB Customz Grill, 35's, Spyder, Tint, Color matched corners
    SIX degrees?
  6. Aug 14, 2017 at 4:17 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Yep, just had it redone Saturday. Dave (coachbuilder) told me 2-3 for clearance with his steering kit and I can't get there. Camburg UCA's move the top of the wheel farther back than any other (from what I've been told). It looks like I'm gonna have to switch UCA's. It drives nicely with 6 degrees but I can't fit my pinky finger between the spring perch and the tie rod.
  7. Aug 14, 2017 at 4:21 PM
    Sefferston
    Sefferston #37sandlongtravel
    Seth
    Commufornia (not by choice)
    ERMERGERD TOYOTA
    Picture please.
    6 degrees seems a bit much.
    OP, first off, ditch the spacer lift and get a Toytec Boss lift. Much better lift, much better ride quality. Secondly, any UCA over stock will help your alignment issues. I'm partial to Total Chaos uniball, but it's not for everyone.
    Toytec Lifts and T-Rex266 like this.
  8. Aug 14, 2017 at 4:23 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    I agree it's too much.
  9. Aug 14, 2017 at 4:26 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    It's causing a lot of rubbing, driver side cab mount. What would you like a picture of? I'm happy to snap a photo.
  10. Aug 14, 2017 at 4:29 PM
    Sefferston
    Seth
    ERMERGERD TOYOTA
    Spring perch/tie rod.
    Could always do the cab mount chop, but I'd get your alignment in check.
  11. Aug 14, 2017 at 4:58 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    You're right. I will do the CMC and TC UCA's. Grand canyon 522.jpg Grand canyon 523.jpg
  12. Aug 14, 2017 at 6:50 PM
    Toytec Lifts
    Toytec Lifts New Member
    Denver, CO.
    The SPC uppers are nice since they are a daily driver/ weekend warrior or light off road style control arm.
    Factory style arm, greasable, facotry style ball joint designed to be adjustable to insure your alignment is within spec the first time without any issues.
    The chaos arms are more or less a higher end performance style control arm, full tubular design, reinforced trussed style mounting points at the poly bushing, greasable zerks at the poly bushings to insure proper flow of the arm and a stainless steel 1" uniball. Proper caster specs are built into the arms themselves so no adjustments are needed but more maintenance I required to keep them at least at par.
    -David
    CaptObvious[OP] and Sefferston like this.
  13. Aug 14, 2017 at 6:50 PM
    Joeshaker
    Joeshaker New Member
    Amado
    Evergreen, Co
    13 dcsb trd4x4
    Bilstein 6112/5160 trd sway bar and ride rite bags. Black and burnt orange wet okole seat covers.
    Yeah, general consensus is that you don't need ucas until 3" lift or more. Not necessarily true, my alignment was really close with 2.5" lift. But going to the spc's seems to have fixed my trac issues and the truck drives way better. Every truck is a little different, so you may need them.
  14. Aug 14, 2017 at 7:15 PM
    CaptObvious
    Patrick
    Thanks for the breakdown on the different UCAs you have. I don't do a lot of extreme off roading, but she does spend time off the paved surfaces. I do tow, just picked up a travel trailer. Looking to upgrade the suspension after the stocks are done.
    Does the BOSS have any issues with having airbags? I have the ride rite kit installed.
  15. Aug 14, 2017 at 7:32 PM
    No. Toytecs Tundra has the AAL, and block with air bags too
