SPC Cam Kits
Discussion in '1st Gen Tundra Parts Marketplace (2000-2006)' started by CodyP, Jul 19, 2021.
Thread Status:
Not open for further replies.
  1. Jul 19, 2021 at 12:35 PM
    CodyP
    CodyP [OP] Such a n00b
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    *SOLD*
    SPC Control Arm Alignment Bushings
    Ended up going OEM and didn't use these kits. Spent just over $100 for them both which covers both front wheels.
    SPC 25445.
    Should fit 2000-2006.
    Brand new and only looked at one kit so there may be a smidge of dirt on them lol
    $70 plus shipping
    mcharfauros likes this.
  2. Nov 29, 2021 at 3:30 AM
    CodyP
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    any interest?
  3. Dec 8, 2021 at 11:11 AM
    CodyP
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    someone's gotta want these
  4. Dec 8, 2021 at 6:16 PM
    daveeasa
    David
    I still need to research what they are / what they do :)
  5. Dec 8, 2021 at 7:31 PM
    CodyP
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Haha. They are for when you replace your lower control arms and/or bushings. These typically sieze in place and have to be cut out and replaced. These are the replacements. I ended up getting a good deal going OEM so I stuck with those instead but couldn’t return these.
  6. Dec 8, 2021 at 7:45 PM
    daveeasa
    David
    So I’d need LCA’s to make use of these?
  7. Dec 8, 2021 at 7:51 PM
    CodyP
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    You already have them on your truck but the bushings in them wear out. You have to press the old ones out and press new ones in so people normally just buy new control arms with the bushings already installed to make things easier. These camber adjustment pieces are typically only able to be cut out so new ones are required. OEM are like $160 for the front two wheels which is why people use these SPC kits.
  8. Dec 8, 2021 at 7:54 PM
    daveeasa
    David
    Ah, sorry, remove LCA, cut out bushings, replace with these?
  9. Dec 8, 2021 at 8:11 PM
    CodyP
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    No. These connect the control arms to the frame and they go through the LCA bushings
  10. Dec 8, 2021 at 8:57 PM
    Jdtuned
    Jdtuned New Member
    Jorge
    SoCal Whittier
    01 AC sr5 4.7 2wd
    No mods besides regular maintance and up keep. Required to carry 200lbs of tools for work.
    I want to replace my oem with same oem not looking for anything fancy these should work right? I am in for oe replacement deal!
  11. Dec 9, 2021 at 7:35 AM
    CodyP
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Yep. These are nothing fancy. Just gets you back together with stock adjustability
  12. Dec 10, 2021 at 6:21 AM
    CodyP
    Cody
    CDA, ID
    2006 Tundra 4x4 DC
    Sold
    des2mtn likes this.
Thread Status:
