Spark plug suggestions?
Discussion in 'General Tundra Discussion' started by TXRailRoadBandit73, Aug 14, 2016.
  1. May 15, 2019 at 6:05 PM
    Hooptytrix
    Hooptytrix Squeaky Chicken
    Dirty South
    2000 AC 4x4, 2001 AC 4x4 Sold. 2005 DC SR5 2WD
    This is correct. The OEM Denso iridium is the best way to go. My experience with Toyota is "do what Toyota say's, when Toyota say's" and you will have a vehicle for a long time
  2. May 15, 2019 at 6:08 PM
    bfd300
    bfd300 New Member
    What he said
  3. May 15, 2019 at 6:08 PM
    arctictundra8577
    arctictundra8577 New Member
    Eric
    Ontario, Canada
    2005 tundra sr5
    ok sounds good, thanks for the help.
  4. May 15, 2019 at 10:31 PM
    marbleville
    marbleville Agent Provocateur
    Yep, last name too.
    State of Confusion
    2002 Thunder Gray Metallic TRD.
    Air freshener died, washer fluid empty, wipers streak.
    I am in agreement with OEM, where and as practical. It's when Toyota wants a 300% to 400% markup that I balk at this wisdom. It's a fine line between reputation and price, if another has a good rep and its price is down, then by all means buy it over OEM. But if OEM is only a little bit more, I go OEM, as they were designed into the rig.:welder:
  5. May 16, 2019 at 4:34 AM
    Professional Hand Model
    Hand Protectors
    I switched back to the NGK OEM copper cores from the service shop installed NGK’s Iridiums (pictured with only 30k miles).
    The copper cores are under $2 each whereas the Iridiums are around $8 each. Huge price difference when multiplied by 8 cylinders!
    I also had about 3 cracked coil packs so purchased 8 new direct from Denso for half the cost of OEM Toyota branded Denso.
    OEM 2002 manual specs copper core
    Iridiums not worth their cost IMO unless your manual specs them.
    Denso Coils direct from Big Gurl from Brasil website. Half cost of Toyota Denso.
    TokerJoker likes this.
  6. May 16, 2019 at 5:02 AM
    Hooptytrix
    Dirty South
    Copper plugs actually conduct electricity better than the iridium but if the manufacturer specs iridium then the vehicle is tuned for the electric of the iridium. Copper plugs should be swapped out around the 30k mark where as the iridium last around 100k. So you really aren't saving any money.
    I believe the tundra spec calls for the iridium plugs. The copper plugs will work and will produce a hotter spark and in theory should give you a bump in performance but the CPU may adjust itself and negate that. I dunno.
  7. May 16, 2019 at 12:38 PM
    marbleville
    Yep, last name too.
    State of Confusion
    I just changed my plugs using OEM Denso K20R-U, and replacing same. Those Denso plugs I replaced looked like the originals, in the sense that their electrodes were worn down considerably with only a tiny bit showing through the porcelain tip - I estimated the gap at around .080, huge by any standard. If those plugs were still firing consistently and no misses, worn as they were, I am sold on them as the ONLY plug to buy for my rig. My rig had 125,000 miles when I changed them out.:muscleflexing:
