Spark plug change, how difficult?
Discussion in '3rd Gen Tundras (2022+)' started by Oldandfat, Jan 31, 2023.
  1. Jan 12, 2024 at 9:19 PM
    #91
    Black widow TRD
    Black widow TRD New Member
    Manuel
    2023 Black Tundra SR5/TRD
    Love me some Rockauto !!
  2. Jan 12, 2024 at 9:57 PM
    #92
    Tom976
    Tom976 New Member
    Tom
    Nobody is using antiseize on the plugs anymore? I would pop the plugs just to put that on. Well maybe.
  3. Jan 12, 2024 at 10:40 PM
    #93
    HLR_NM
    HLR_NM New Member
    Harry
    Antiseize can prevent thread galling but it also lowers the torque spec by 10-20% - use with care. Modern iridium plug threads are already plated and there’s no need to use antiseize. NGK for example has a nickel chromium plate (IIRC) and are designed to be installed dry.
    Any time you have dissimilar metals in contact there will be a redox reaction. In the old days of steel plug threads and cast iron heads all you needed was a little engine oil. The plating or antiseize is intended to act as a sacrificial metal barrier that separates and protects the threads of the aluminum head and steel plug (prevents galling).
    That said I’ve been known to use a tiny dab of copper antiseize on spark plugs but I’m super careful not to over torque the plugs.
  4. Jan 13, 2024 at 4:47 AM
    #94
    raylo
    raylo not so new member
    Frederick, MD
    DashCam, amp & sub, DIY rear seat delete, cat shield, AMP power boards
    I used to really love them back in the day, but their shipping has gotten very $$ and very slow. At least last couple times I used them. So now I look elsewhere first.
  5. Apr 26, 2024 at 11:11 AM
    #95
    KA22TRD
    KA22TRD New Member
    Kevin
    2022 White Tundra SR5 TRD
    Level lift
    This thread helped!! Pretty easy job (except for #6) knocked it out in an hour and a half. 58K miles reference picture
  6. Apr 26, 2024 at 4:57 PM
    #96
    lapoolboy
    lapoolboy New Member
    Run any better?
  7. May 10, 2024 at 6:17 AM
    #97
    904pizza
    904pizza New Member
    2022 Tundra SR5 TRD
    My service tech said last week since I have an extended warranty if I do this myself I need to submit a letter, and show part receipts. Dealership wanted about $500 to do job I got the parts at Rock Auto like most.
    Since this is the emissions warranty and not engine warranty, seems pretty aggressive to even state that the entire 125k extended warranty can be voided over air pollution.
    Anyone else written up a letter to prove they did home maintenance? I plan to do my plugs once it's not 90F+ and miserable outside. I have 2k miles till 40k.
  8. May 11, 2024 at 9:54 AM
    #98
    cgpollack
    cgpollack New Member
    My Tundra just hit 40K and the manual requires spark plug replacement due to emissions control warranty. The right side (passenger side) is fairly straight forward and the left side (driver side) has a lot more stuff in the way. I opted to have the dealer do it for me. It cost me 509.00 and that was with a 100.00 off coupon. At O'reilly's the plugs cost 26.00 each and at RockAuto they were 15.00 each. To me it is a shame to have to change out plugs at 40K, I wasn't expecting that.
  9. May 11, 2024 at 10:25 AM
    #99
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Meh, read your manual and it won't be a surprise. Don't wanna pay, do it yourself.
  10. Oct 26, 2024 at 9:31 AM
    #100
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    Finally got around to ordering these. Still $13.02 at Rock Auto. I’ll have them next week sometime. I know I am getting a new engine but I am not expecting to get that for a year or 2. I just turned 53k so I am a bit behind.
  11. Nov 19, 2024 at 7:39 AM
    #101
    aoteri983
    aoteri983 New Member
    2022 TRD Sport
    I just tried doing mine, the 3 on the passenger side were not too difficult with the information in this thread, however the 3 on the driver side were pretty buried in there. I ended up taking the car to the dealership to see if they could just change those three, they said they would do it for just labor as long as the parts were OEM and I had a receipt to prove that. I took it in, and the tech looked at it and quoted me 5.5 hours for labor just for the driver side. They wanted almost 800 for the work. Something doesn't add up there, so I declined that. They said that they need to remove the entire intake to get to the plugs. Something smells fishy there.... Anybody have any recommendations on getting to those last 3 plugs on the drivers side? No way I'm paying nearly 800 in labor for them to do this. Others have claimed 500 for the complete job including parts, so is this tech just not qualified? or are they trying to rip me off? FYI this is Harr Toyota in Worcester MA. For those in the area, to give warning to others.
  12. Nov 19, 2024 at 8:19 AM
    #102
    Linesman
    Linesman New Member
    David
    2023 Smoke Mesquite Tundra Double Cab limited
    Dealer will charge about $700 for plug change on 3rd gen
  13. Nov 19, 2024 at 8:22 AM
    #103
    eddiefromcali
    Eddie
    100% Stock
    5.5 seems high. Are you sure they said intake as in intake manifold or just intake as in the air box? Go to a an independent shop or put your purse down and do it yourself.
    AZBoatHauler likes this.
  14. Nov 19, 2024 at 8:31 AM
    #104
    aoteri983
    2022 TRD Sport
    Is that really necessary? I have no problem doing most things myself, but there are a lot of probably very expensive things that need to be removed, disconnected, etc. to get access to those plugs. I don't have small hands, and even with everything removed it's very difficult to access for me. As for the intake, what the tech said to me was that the procedure was updated recently and requires them to remove the "entire intake" to access the plugs. I call BS on that. I have no problem taking it to an independent shop, I just don't know who to use, since I've done all the maintenance on all my cars for the last 25+ years.
    graf_von_tundra likes this.
  15. Nov 19, 2024 at 8:38 AM
    #105
    AZBoatHauler
    So.Arizona
  16. Nov 19, 2024 at 9:38 AM
    #106
    virgilus11
    virgilus11 New Member
    2022 Tundra Capstone
    1/2" front spacer 37" Cooper ATX
    Parts are $120
    Patience and few beers get this done in less than two hours.
    You need a good set of extensions and flex heads. You will have to unclip few things, specially on the passenger side but you can do it
    Really no need to get ripped off.
  17. Dec 10, 2024 at 7:20 PM
    #107
    Robbelk
    Robbelk New Member
    Robert
    Springfield, MO
    2023 sequoia limited
    What’s the torque on 2023 sequoia (hybrid) plugs?? Thanks
  18. Dec 10, 2024 at 8:05 PM
    #108
    virgilus11
    I believe is 15 lb
    Robbelk likes this.
  19. Dec 11, 2024 at 3:59 AM
    #109
    Robbelk
    Robbelk New Member
    Robert
    Springfield, MO
    Great, thank you!!
  20. Dec 14, 2024 at 10:48 AM
    #110
    Robbelk
    Robbelk New Member
    Robert
    Springfield, MO
    Just changed plugs 1st time at 90,000 miles. 2023 to Toyota sequoia, V6TT
    / Hybrid. Took about 3 hours, but I’m very methodical, and next time should be able to do in about 1.5 hours or so. Part of the problem is you have to basically climb up into the engine bay. I also spent a lot of time just figuring out what clips needed to be removed and what brackets needed to be taken off. Now that I know exactly what to do next time should easily cut that three hours in half.. also, I don’t know why they say do it at 40,000 miles, but I never experienced any change in fuel mileage or engine running rough, and with the new plugs, I noticed zero change.
    Tundrastruck91 and 22whatwedo like this.
  21. Dec 14, 2024 at 10:54 AM
    #111
    eddiefromcali
    Eddie
    100% Stock
    Mind posting pics of your plugs? Hybrid is a bit more complicated than non....very interesting it only took you that long when dealers are claiming it's like a half day job. Lol
  22. Dec 14, 2024 at 3:11 PM
    #112
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I bought the prepaid maintenance up to 85K. Plugs are included. Got a ways to go till their done.
  23. Dec 14, 2024 at 5:58 PM
    #113
    Breathing Borla
    AZ
    emissions BS
  24. Dec 14, 2024 at 7:08 PM
    #114
    iforceAZ
    iforceAZ New Member
    Your service tech is an utter liar.
  25. Dec 15, 2024 at 3:16 AM
    #115
    Robbelk
    Robbelk New Member
    Robert
    Springfield, MO
  26. Dec 15, 2024 at 3:17 AM
    #116
    Robbelk
    Robbelk New Member
    Robert
    Springfield, MO
    Those are the pics of the plugs at 90k miles. 2023 sequoia hybrid.
    22whatwedo likes this.
  27. Dec 15, 2024 at 3:35 AM
    #117
    BIGUGLY
    Paul
    2018 Limited
    Just for context, my 2022 F-150 work truck says to change plugs at 60k miles. It took the dealer an hour to do the work and cost was $411.
    The plugs also ran about 20 bucks a piece but they also replaced the boots, they said the plugs looked great and they even wonder why they have such a short life under the ford manual.
    So if your in the 500 dollar realm probably not out of line compared to what a Ford will cost as well
    Tundrastruck91 likes this.
  28. Dec 15, 2024 at 9:29 AM
    #118
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    90K on the originals?
  29. Dec 15, 2024 at 10:39 AM
    #119
    Robbelk
    Robbelk New Member
    Robert
    Springfield, MO
    Yes, 90,663 miles! Original plugs!
  30. Dec 15, 2024 at 10:40 AM
    #120
    Robbelk
    Robbelk New Member
    Robert
    Springfield, MO
    Yes!
    ARB1977[QUOTED] likes this.
