Spare tire
Discussion in 'Wheels & Tires' started by Local46er, Mar 5, 2017.
  1. Mar 5, 2017 at 11:02 AM
    Local46er
    Local46er [OP] New Member
    Neil
    Ontario Canada
    2016 Tundra SR5 TRD double cab
    What are you to do with the stock spare tire if you need to use it on your lifted truck?
    Can you get a spacer
    Buy a steel wheel with the correct offset
    Just don't like the idea of not being able to use it now.
    Thanks Neil
  2. Mar 5, 2017 at 11:04 AM
    I asked this ther shud b a thread I forgot name of thread but I run 35s I need same size spare n they say it will fit but I need to take some brackets out so it can fit
    Local46er[OP] likes this.
  3. Mar 5, 2017 at 11:15 AM
    Local46er
    Neil
    Ontario Canada
    Thanks.
  4. Mar 5, 2017 at 2:18 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Maybe I'm missing something. Lifting your truck and or adding taller tires should not render your factory spare useless. Obviously you wouldn't want to drive long distances or use 4wd while running the shorter spare, but it should be fine to get you home or to a tire shop.
    rons23 likes this.
  5. Mar 5, 2017 at 4:38 PM
    Local46er
    Neil
    Ontario Canada
    it may hit brakes or something. If the stock wheels don't work I assume the spare will not.
  6. Mar 5, 2017 at 4:43 PM
    Thegr8punkin
    Thegr8punkin A G.D.M/Sofa King Cool/COTJ's dreamboat
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    ??? Why would stock wheels hit the breaks?
    bobeast likes this.
  7. Mar 5, 2017 at 4:44 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    What's the offset of your wheels now?
  8. Mar 5, 2017 at 4:45 PM
    Local46er
    Neil
    Ontario Canada
    I maybe wrong, but the offset won't work with the new setup I have.
  9. Mar 5, 2017 at 4:45 PM
    Local46er
    Neil
    Ontario Canada
    +18
  10. Mar 5, 2017 at 4:47 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    What did you change when you lifted? The only thing I can think of is maybe the tire rubbing on the uca
  11. Mar 5, 2017 at 4:52 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
  12. Mar 5, 2017 at 4:54 PM
    Local46er
    Neil
    Ontario Canada
    Just the lift. Maybe I will try it when the weather breaks. Just for my own curiosity.
    Thegr8punkin likes this.
  13. Mar 5, 2017 at 4:59 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    Your spare should fit fine. You just don't want to drive on it for an extended amount of time because of the size difference. Diameter, not offset. And you might want to see if your new lug nuts fit or if you need to carry around a set of your original lugs.
    rons23 likes this.
  14. Mar 5, 2017 at 5:03 PM
    Thegr8punkin
    Connor
    Northern Colorado
    08 blue sr5 2wd
    2 +5 hp stickers
    I think that the best thing you can do. Let the rest of us know what you find out
  15. Mar 5, 2017 at 5:22 PM
    Buy a +18 wheel and 35" spare. No more worries and work it into the rotation.
    joonbug and Thegr8punkin like this.
  16. Mar 5, 2017 at 8:26 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Unless you changed your hub or brakes, your stock wheel can't possibly hit anything. But like you said, your best bet is to convince yourself one way or the other by trying it.
  17. Mar 6, 2017 at 7:22 AM
    U just don't want different sized tires on ur truck. Could cause some harm to the
    Diff
  18. Mar 6, 2017 at 7:43 AM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    And if the size is different enough, VSC and TRAC will freak out since it will think the tire is loosing traction.
  19. Mar 6, 2017 at 8:13 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    If you don't have the full size matching spare and need to use it I would leave in 2wd and make sure it is up front.
    If you don't want to pony up for a matching 5th wheel just get a cheap wheel with matching offset and 35" tire then. Probably could get that done for under $300.
    joonbug likes this.
