Spare tire max size ?
Discussion in 'Wheels & Tires' started by TheBeast, Mar 8, 2018.
  1. Oct 23, 2020 at 2:01 PM
    #61
    TheBeast [OP] The Beach
    couple write ups on the forum but yeah remove/cut the rivets that hold the guides, remove the guides then spray some paint over the bare surfaces to protect from rust.
    if you run aftermarket shackles lilke CB they are on the wider side so 295 might be the max you can run. if TC or MCM shackles, 35's should fit.
  2. Oct 23, 2020 at 2:02 PM
    #62
    kevinrath
    kevinrath New Member
    Kevin
    2021 Lunar Rock Tundra TRD Pro
    295/70R18 Nitto Ridge Grapplers
    i also heard just hitting them with a hammer or something to bend them a bit works too. I’ll do some research, but this helps!
    Skey44 and TheBeast[QUOTED][OP] like this.
  3. Oct 23, 2020 at 2:03 PM
    #63
    yes you can do that too. My method pretty much trash the old guides :)
  4. Oct 23, 2020 at 2:25 PM
    #64
    kevinrath
    Kevin
    im just wondering if my tire shop will mess with it for me or if I’ll be left to fuck with it /:
  5. Oct 23, 2020 at 3:58 PM
    #65
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    There are 2 rivets holding each of the tire guides. I drilled out the rivets, moved the guides out and then reinstalled using 1 bolt to hold them in place. 35's fit fine and having the guides helps to keep the tire from shifting and hitting the shackles.
  6. Nov 13, 2020 at 7:48 PM
    #66
    November Sun
    November Sun New Member
    Huntsville, Alabama
    2018 Limited Crew Max
    Pro Comp 7" Stage 1 Lift, 20" Fuel Wheels, Nitto Terra Grapplers, Bak Flip Tonneau Cover, King 2.5's, Custom Alcan Leafs, Coachbuilder Steering Kit, CBI Baja Front Bumper, NSV Light Bar, TRD Pro Intake, Southeast States Wireless Phone Charger Coachbuilder Plus 3 Shackles, Wheeler's Bumpstops, BAM 8" Exhaust, BAM Bomb Tip, Headlight Revolution LEDs everywhere, Warn EVO 12K Winch, Diode Dynamics SAE Fogs and Combo Light Bar
    Has anyone tried to fit a 35-12.50-20 with cutting the tabs?
  7. Mar 16, 2021 at 8:22 AM
    #67
    TundraDDS
    TundraDDS New Member
    2020 White Tundra Limited 4x4
    I respect the fact that you took the time to reinstall the guides to accommodate your larger spare. Hoping to do the same. Is your spare a true 35/12.5?
  8. Mar 16, 2021 at 8:32 AM
    #68
    Badknees
    Badknees New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    I used a side grinder to take the top off the inner-most rivets and drill out the remaining rivet...a bit of a PITA. Then pry open and slide approx. 1/4" spacer between the front brackets/frame. Install new bolts/nuts and touch-up paint. Result are the two brackets tilted back enough for a larger OD tire. Nice tight fit for spare Cooper Discoverer 295/70 R18 XLT AT3 on steel wheel. Assume the same would work on 35s, but might need a little more than 1/4" spacer.
  9. Mar 16, 2021 at 9:00 AM
    #69
    Skey44
    Skey44 GreenvilleOverland
    Scott
    Greenville SC
    2018 GX 460
    Lift, tires, wheels, roof rack
    Will fit, won’t have to do anything special.
  10. Mar 16, 2021 at 9:05 AM
    #70
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    I am running 35 x 12.5 x 18 Ridge Grapplers. Nitto lists the actual size as 34.76 x 12.52. It is a new tire so about as close to 35 as as you can get.
    GodlessPro and joonbug like this.
  11. Mar 16, 2021 at 9:13 AM
    #71
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    My local shop who also did my suspension knocked back the tabs to fit my 285/75R18. Not sure every tire shop would do this, but they did it for me.
    biebs96 likes this.
  12. Mar 16, 2021 at 5:22 PM
    #72
    TundraDDS
    Perfect! I just ordered that very tire last week. I'll plan to do the same as it relates to the spare mount then. Thank you!
    sr5shark[QUOTED] likes this.
  13. Mar 16, 2021 at 5:32 PM
    #73
    sr5shark
    Alan
    Walnut Creek, CA
    2016 SR5
    Good luck. Drilling out the rivits was a pain and I went through 2 or 3 cheap bits from Amazon. I almost gave up and cut the brackets - really glad I didn’t.
    GodlessPro likes this.
  14. Mar 16, 2021 at 6:58 PM
    #74
    biebs96
    PA
    would you mind providing some photos of this? Is it mounted on the original spare rim?
  15. Mar 16, 2021 at 7:12 PM
    #75
    Skey44
    Scott
    Greenville SC
    2018 GX 460
    On a TRD off-road rim ($75 on CL) I don’t have a good pic of the actual bent tab. But I have one of the spare up there. I agree that it does help to have someone guide the tire up while someone else cranks it back in. I am running a five tire rotation. Just bought the 5th TPMS to instal in it to finally get rid of the pesky TPMS light when the original spare is on the ground, which is pretty frequently. A3F0B87E-2DF9-4EAB-852C-0351879818C9.jpgFBEEA7D5-E0A6-4464-B8F2-E87C35356B58.jpg
  16. Mar 16, 2021 at 7:17 PM
    #76
    Funnyguy713
    Funnyguy713 I can't get Jiggy with this Sh!t
    Houston TX
    2017 Tundra 1794 4x4
    35s on 20s with 6" Pro Comp
    I bought a used 35x12.5x20 and fits like a glove. After cutting the guides off.:sawzall:
    Skey44 likes this.
