Spare tire max size ?
Discussion in 'Wheels & Tires' started by TheBeast, Mar 8, 2018.
  1. Apr 18, 2018 at 10:14 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Yeah best to just run a full spare if you like to play. @Jsena time for a chase rack!!
    Watt maker and 15whtrd[QUOTED] like this.
  2. Apr 18, 2018 at 10:45 AM
    Unlimited
    Unlimited New Member
    2017 Tundra Crewmax Limited TRD Offroad
    TRD dual Exhaust, TRD Pro Skid Plate, TRD CAI, Demello Hybrid Sliders, Bilstein 6112/5160, Total Chaos UCA, Toytec rear Shackle lift @ 1.5", SCS Ray10 18" with spare, Cooper STT Pro 295/70r18 with spare, Extang Solid Fold 2.0 Tonneau, KB Voodoo Hi Rise Crossbars Oh Sh!t handle add
    Some guy has TRD rims for sale in the marketplace just saying...
    15whtrd[QUOTED] likes this.
  3. Apr 18, 2018 at 10:51 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    So does the wheel size matter then?? Like if I get a 35 tire with 18 wheel or 20 wheel?
  4. Apr 18, 2018 at 10:53 AM
    Jsena
    Jay
    Las Vegas, NV
    A Bad Bissshhhh
    Cause of thats the case, I can stuff a 35 under the truck and call it cool??
  5. Apr 18, 2018 at 11:18 AM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Like Kris said, you can run the 35 as a spare but only in the front. So, you're switching 2 tires if you get a flat in the rear. I'm not sure about your lift but you just wanna be sure the spare clears your UCA.
    boardude likes this.
  6. Apr 18, 2018 at 11:20 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Using a 35" spare for a 37" setup will be ok. Think of like cars and how much smaller their spares are, kinda like that but again, just make sure to always put the spare up front. Don't want to put 2 different size tires in the back as it will mess with the gearing.
    The wheel will matter if it doesn't clear with your setup. If you use a stock wheel the offset will be completely different and most likely will not clear your UCAs and suspension. What's your offset now, like -44? Just get something comparable to that and you'll be ok. Make sure an 18" wheel will also work with your suspension. I think some kits specify the use of at least an 18" wheel and maybe a 20".. not sure though
    831Tun and Jsena[QUOTED] like this.
  7. Apr 18, 2018 at 11:23 AM
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    With all that in mind I ended up just buying the same wheels for my spares since they would be the same size and offset. To find a wheel with comparable offset for cheap was proving hard and it was actually the cheaper option for me to just buy the same wheel. #cheapProCompwheelsFTW
    831Tun likes this.
  8. May 31, 2018 at 8:40 PM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Thought the 295/70 would fit under without modifying the brackets. I have CB+3 and the brackets were poking my tires and not allowing them to sit tight up there. Cut the brackets so they don’t stick out and the tire fits much better. Tight but fits. Can’t fit anything much bigger than this size. Also close to the resonator from my BAmuffler. I want to get rid of the resonator so it can fit a bit better with more space to breath.
    E51BEC09-CCA0-454A-9F8B-A725717F2BB2.jpg BB96C2FA-100D-486D-B27A-3998CA2CC99A.jpg
    Fish2eat88, AggiePhil, equin and 2 others like this.
  9. May 31, 2018 at 8:44 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Dang, that thing is sooo clean under there, looks like it's never seen anything but the garage floor. But, I know better, I've seen it on the road............. twice.
  10. May 31, 2018 at 8:45 PM
    finn
    finn New Member
    Ryan
    Are you using the oem spare rim?
  11. May 31, 2018 at 8:58 PM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Haha right!
    No. I have a full size scs ray10.
  12. May 31, 2018 at 9:11 PM
    Achuop
    Achuop Stormtrooper 5.7
    Anthony
    Orange County, CA
    2015 Tundra Crew Max TRD 4x4
    TRD Pro grill, Magna Flow Exhaust, 3/2 leveling kit, TRD sway bar, black out emblems, Bakflip G2 cover, 20” ProComp wheels and Tires and lots of love and affection.
    Looks like I will be putting a full-size spare under the truck. 35x12.5x18
    Skey44 and Mountun Goat like this.
  13. May 31, 2018 at 9:25 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Think I could squeeze a 37/12.5r17 under there? Without depressuring it that is.
    It’s not a real big deal if I can’t, would just be a bonus. I’ll just box mount it if not.
  14. May 31, 2018 at 9:46 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    I don't think so. Just put a 295 70 18 (34.4") tire under there today. It fits but not much room to spare. I can't see your size fitting.
    Mountun Goat likes this.
  15. May 31, 2018 at 9:49 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks for the reply. Ah well box it is! Or maybe a roof rack.
  16. May 31, 2018 at 9:57 PM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Good thread, I'm trying to fit a 20 in my spare..lol
  17. Jun 1, 2018 at 3:04 AM
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    Does the chain or anything scratch the face of the rim? I’m worried about putting my 5th wheel under there, right now it’s just in the bed.
  18. Jun 1, 2018 at 6:30 AM
    BlueBottle
    '16 Platinum 4x4
    See fine print
    The chain goes through the hub. Not worried about that. It’s the bracket that scratches the wheel. I already have some scratches where the brackets contacts the hub opening of the wheel. Don’t think you can get away from that unless you put some kind plastic protection on the bracket or wheel.
    What the!? and Mountun Goat like this.
  19. Aug 3, 2018 at 2:34 PM
    #49
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Bump, having a brain fart as my offset is +18 and the 295/70R18's do not rub anywhere with my mud flaps removed, liner pushed in. Does a 295/70R18 on the stock spare +60 18" steely rub anywhere?
    I just measured my tire 42mm inwards, seems to clear the UCA, not sure if any issues during movement.
  20. Aug 6, 2018 at 11:40 AM
    #50
    Unlimited
    Anyone ever try like 5 coats of Plastidip?
  21. Aug 9, 2018 at 8:34 AM
    #51
    HBdirtbag
    HBdirtbag New Member
    Walnut Creek, CA
    2017 limited cm
    to confirm, 295/70r18 will fit on the stock spare?
  22. Aug 9, 2018 at 8:49 PM
    #52
    BlueBottle
    '16 Platinum 4x4
    See fine print
    I had to chop both brackets under there.. and it was a pita to line up while you raise it. but it fits!
  23. Aug 17, 2018 at 4:23 PM
    #53
    jordanpop1
    jordanpop1 New Member
    Bump, if I put 35x12.50r18 on the truck and I left the stock spare the only issue I would have is that the spare would need to be in the front correct? TRD pro
    I ask because, If I am going to play in the truck, I will just strap in the matching wheel and tire in the truck bed, but most of the time I am just on road and I need my truck bed space.
  24. Aug 17, 2018 at 4:54 PM
    #54
    lionix
    lionix The Grey Moose!
    Cape May, New Jersey
    2017 Tundra TRD Pro CM Cement
    BD Lights, Any Time Fog, Coachbuilder, Pelfreybilt, Bakflip, Custom Bed Rack w/ Tent
  25. Aug 17, 2018 at 6:20 PM
    #55
    jordanpop1
    Yeah. I’m just not crazy about that look. No offense to your setup. Just not for me. That’s is ideal though
  26. Aug 17, 2018 at 8:06 PM
    #56
    myt1
    myt1 New Member
    Richard
    Scottsdale, AZ
    2010 Tundra DC TRD SR5 Desert Sand Mica
    OME Lift, 275/70R 18
    Thanks for the posts.
    If I bend or remove the tabs will 275/70R/18’s fit on a stock aluminum wheel?
    Thanks.
  27. Oct 21, 2020 at 12:57 PM
    #57
    DavidWooderson21
    DavidWooderson21 New Member
    Did you ever fit this?
  28. Oct 21, 2020 at 1:17 PM
    #58
    saybng
    Gary
    Ventura CA
    Nope..changed wheel/tire size.
    TheBeast[OP] likes this.
  29. Oct 21, 2020 at 1:19 PM
    #59
    TheBeast [OP] The Beach
    my 295/70/18 on method 18" fits with room to spare after the guides were removed. 35" should fit
    I need the bed of my truck to do truck stuff...
    SC_TRD, Flyinryank and saybng like this.
  30. Oct 23, 2020 at 8:55 AM
    #60
    kevinrath
    kevinrath New Member
    Kevin
    2021 Lunar Rock Tundra TRD Pro
    295/70R18 Nitto Ridge Grapplers
    How did you remove the guides? Not sure how common it is to have to do this for other trucks. If I get my tires installed at a local tire shop, do you think they'll be able to get the spare to fit back there doing whatever you had to do, or do you think I'll have to do it myself?
    I'm doin 295/70/18's on the TRD wheels (I bought an extra wheel and tire to use for spare)
