Sound System Upgrade
Discussion in 'Audio & Video' started by YotaBro, Jan 12, 2021.
  1. Jan 13, 2021 at 8:39 AM
    bsktball55
    bsktball55 New Member
    Ryan
    Missouri
    16 Tundra TRD Pro
    Bakflip MX4 Toneau cover Esp storage Audio system (Helix speakers, JL audio amp and sub) Front windows and windshield tinted LED interior and bed lights
    I would talk to Randy at Tech12 volts. Especially if you don't really know what you are doing. Tell him your goals and your budget and he will set you up. I went through him and he saved me a bunch of money over Amazon/crutchfield and it was an easy install. He was great to work with. I kept my headunit, but changed out amps, front and rear speakers and added a sub. Much better sound. He has a harness that allows the amp to be plugged into the factory amp wiring so you aren't cutting any wires or anything and everything can be reversed.
  2. Jan 13, 2021 at 8:40 AM
    YotaBro
    YotaBro [OP] This forum will make me broke
    Calvin
    FL
    Lots of shenanigans.
    Do you know what you used for the plug in play?
    Rica25 likes this.
  3. Jan 13, 2021 at 8:41 AM
    YotaBro
    Calvin
    FL
    Sounds good! I'll hit him up. Thanks for the info!
  4. Jan 13, 2021 at 8:42 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    On mine, he sent a harness that he made up that plugs into the the harness for the factory amp. You then attach that harness to RCA connectors that plug into the amp.
    YotaBro[QUOTED][OP] likes this.
  5. Jan 13, 2021 at 5:07 PM
    Jbehredt
    Jbehredt Burgeoning member
    Westminster, CO
    2020 TRD Pro DC White
    Same here. Hardest part for me was crimping the terminal on the power wire. Messed one up but had another in the kit.
    Rica25 likes this.
  6. Jan 13, 2021 at 5:29 PM
    The Californian
    The Californian Good Vibes Only
    Eric
    2020 Super White Tundra TRD Pro Crewmax
    I went to my local car audio shop, and I really wish I would have gone with @james@tech12volts. From what everyone has said, Tech12Volts sounds super solid, and much cheaper than what I paid.
    Saltyhero13 and Rica25 like this.
  7. Jan 13, 2021 at 5:31 PM
    619Tundra
    619Tundra New Member
    San Diego, Caifornia
    2017 Black Tundra Double Cab SR5
    Where did you go?
    Rica25 likes this.
  8. Jan 13, 2021 at 5:48 PM
    The Californian
    Eric
    This place in Redlands called "Tune Time Stereo". Super nice dude that runs the place, my system is great - I just think I could have got one that bangs just a good through Tech12Volts for about a third of what I paid, but then again - that wouldn't include installation.
  9. Jan 13, 2021 at 5:52 PM
    619Tundra
    What do you have?
    Rica25 likes this.
  10. Jan 14, 2021 at 1:02 AM
    preacher35
    preacher35 RIGHTEOUS MEMBER
    2018 MGM Platinum Crewmax 4x4
    YotaBro, you've got to give us more to go on what you are looking for. Budget is usually the first question and biggest decision maker, so let us know what it is and we can help you decide on the best setup possible. Second question would be, how much volume and bass do you want? If you want a ton of volume and a lot of bass, then you are going to require at least one amp (the Tundra amp is nothing but a POS paper weight) and possibly a sub box. Third question would be are you going to install this yourself or have a professional do it? Your fund of installation knowledge will give us a better idea on what you are actually capable of handling/installing. Granted, stereo installation is not rocket science, but it is NOT something that you want to rush through, or cut corners on.... ESPECIALLY in a $40k-plus truck. Even if you choose to do a complete system swap, you can pull it off with little to no experience. It just takes time, patience and probably a little help from your friends on Tundras.com.
    And finally, I too recommend James @ Tech12volts for professional advice and sales. He answers all questions via Email and responds very quickly.... Even in the middle of the night! He built me a ported dual 10" sub enclosure for behind my back seat and it is awesome!
  11. Jan 14, 2021 at 1:14 AM
    619Tundra
    Did someone say middle of the night?
  12. Jan 14, 2021 at 6:40 AM
    YotaBro
    Calvin
    FL
    Hey! So no set budget yet because I am just doing research rn and probs won't buy anything until I finish with exterior mods. My guess would be 1k or less (honestly don't know if that would get me anything decent or not) as for volume, I don't listen to music very loud or tbh music at all. I usually listen to audio books or podcasts. My girlfriend on the other hand loves music so I'd like to get something better than the stock sound system for our long trips.
    I am not an electrical engineer by any means but can usually figure things out if it has a detailed instructions. I would prefer a plug in play though.
  13. Jan 14, 2021 at 7:13 AM
    619Tundra
    Good luck.
  14. Jan 14, 2021 at 9:33 AM
    bsktball55
    Ryan
    Missouri
    16 Tundra TRD Pro
    You will be able to get a significant upgrade for $1000. You aren't going to win any competitions, but that doesn't seem like what you want. I spent a little more than that, but not a ton. I have Helix front speakers and JBL's in the rear. I was looking at JL c2's and Randy recommended the Helix's for the same price. JBL's in the rear are not the highest quality, but better than what was there and many people don't even worry about the rears. I have a JL audio xd700/5v2 amp and a jl audio 10 TW3 subwoofer with a box built by James. He included all harnesses and wires that I needed as well. This was about 4 years ago. Now I believe he is a Hertz dealer and recommends their products a lot, but before I went with Randy at Tech12volts I was piecing this system together with some from Amazon, some from crutchfield, harnesses from taco tunes etc and Randy beat the price that I was able to come up with by a couple hundred dollars. He also provided customer service that I never would have gotten out of Amazon. I had never done any kind of audio install before, but a couple videos on youtube and instructions from Randy it it wasn't bad at all. The hardest thing to do was to fish the amp wire through the grommet in the firewall and that was just trying to shove a thick ass wire into a small hole.
    YotaBro[QUOTED][OP] and MTRock like this.
  15. Jan 14, 2021 at 2:34 PM
    YotaBro
    Calvin
    FL
    Thank you for sharing your experience! I'll have to call them once I'm ready to pull the trigger. Need to buy some tires and finish my bumper before I deep dive into audio.
  16. Jan 14, 2021 at 3:20 PM
    MillMatter
    MillMatter New Member
    Pensacola, FL
    2014 1794 Edition 4x4 CrewMax Super White
    6” pro comp lift, 35x12.50 Toyo R/T, 22” chrome Fuel Hostage, Magnaflow custom dual in dual out exhaust with OEM chrome tips w/ Toyota logo, tint, smooth finish color matched fender flares, color match grille surround and hood bulge, 14-17 TRD Pro grille custom painted all white (letters remain matte silver), classic Toyota tri-color logo in grille (blue color scheme), chrome step bars, Century Sillhouette tonneau, Pendaliner drop in bed liner, custom company graphics, chrome TRD decals custom painted to color match company graphics (blue), ESP under seat storage, center console organizer, BumperShellz color matched front bumper end caps. Tech12Volts/Taylor's Audio Sound System: Kenwood DMX1057XR head unit, Infinity Reference 5-ch amp, Hertz CK165L front, Hertz K170 rear, 2 JL Audio W0 10" subs in ported box behind seat, bass knob.
    With your $1k budget, I would go with some higher end 6.5" components up front like Helix or Audiofrog, something average for the door speakers in the rear like the base model Hertz (only $99/pair) then a mid-level 5 channel amp like Infinity/JBL and a single 10" or 12" sub in a ported box. The vocals will scream and you'll have solid thump as well. And definitely go with @james@tech12volts like everyone else is saying. That might exceed your budget but it would be close.
  17. Jan 15, 2021 at 10:42 AM
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    2023 Black SR5 Crewmax Long Bed
    Just lucked into a Kenwood DMX907s the other day for $250 brand new so I picked it up. I called Tech12v and he got me a whole package of what I needed to get it installed for a good price. I got it put in last weekend and I'm already planning my full buildout. Go ahead and budget to at least do the head unit and speakers together at the same time. If you put a H/U only in, there is an improvement, but it just amplifies how poor the stock speakers really are.
    MillMatter, MTRock and AZBoatHauler like this.
  18. Jan 16, 2021 at 12:35 AM
    619Tundra
  19. Jan 19, 2021 at 6:49 AM
    #49
    King R 808
    King R 808 New Member
    Ryan
    2020 White Tundra TRD Pro
  20. Jan 19, 2021 at 6:52 AM
    #50
    619Tundra
    Stereo Depot in El Cajon. I bought mine from Ali.
    King R 808[QUOTED] likes this.
  21. Jan 19, 2021 at 7:32 AM
    #51
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  22. Jan 19, 2021 at 7:36 AM
    #52
    619Tundra
    Not yet. I'm going to do sound deadening first. Then Cameras. Then Audio system. I have everything I need.
  23. Jan 19, 2021 at 7:37 AM
    #53
    Danimal86
    Daniel
    Sacramento, CA
    I'm still holding strong with my factory non-jbl, but dang that price is tempting!
  24. Jan 19, 2021 at 7:47 AM
    #54
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    I have a 2016 SR5, Non JBL. Kept the head unit and door speakers.
    Replaced the dash speakers, amp.
    New stuff is Kenwood 5 Channel, AudioControl LOC and Sub
    All plug and play. Hardest part was running amp wire from battery to pass side seat.
  25. Jan 19, 2021 at 7:58 AM
    #55
    BecauseRacecar
    BecauseRacecar New Member
    Ohio
    '20 Tundra SR5 DC 4x4 Magnetic Gray
    Anyone have any issues with dealership service after a head unit upgrade? I got my truck back after some warranty work and noticed the stock radio was in "service mode", and I wasn't sure how swapping in an aftermarket radio might impact the technician's work.
  26. Jan 19, 2021 at 9:16 AM
    #56
    vl184009
    vl184009 Cheers Boys!
    Vicky
    Southern, Ca.
    2016 MGM CM SR5 4x4 w/Tow Pkg
    That's what I want to do, maybe swap out speakers too but all plug and play. So how does it sound compared to completely stock?
  27. Jan 19, 2021 at 3:31 PM
    #57
    619Tundra
    There's going to be a shortage in available units due to chip factory burn down.
  28. Jan 19, 2021 at 3:38 PM
    #58
    Danimal86
    Daniel
    Sacramento, CA
    didn't know that happened.
    I'm gonna try to see how the factory head unit plays with my dsp first.
  29. Jan 19, 2021 at 5:28 PM
    #59
    SloppyJ
    SloppyJ New Member
    NW Arkansas
    Anyone on the fence.... I just sold my stock head unit on ebay for $490 shipped.
    #59
    AZBoatHauler likes this.
  30. Jan 19, 2021 at 5:34 PM
    #60
    MillMatter
    Pensacola, FL
    Wow! I’ll have to give that a try.
    #60
