Sound matting worth it?
Discussion in 'Audio & Video' started by Stumpjumper, Mar 12, 2018.
  1. May 5, 2019 at 6:56 PM
    #211
    CenTexTundra
    CenTexTundra New Member
    2017 Tundra Limited
    BDS 7" Coilover lift; BDS UCAs 37" Nitto Ridge Grapplers; 20" Fuel Tactic Wheels Smittybilt 10k Winch; Smittybilt M1 Bumpers WeatherTech Mats; EPS Rear Vault, TRD Pro Grille Genesis Offroad Dual Battery (Optimas)
    Nice man! Yours is blue right?
  2. May 5, 2019 at 7:49 PM
    #212
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Yes sir. Blue ribbon metallic
  3. May 5, 2019 at 8:49 PM
    #213
    TheBeast The Beach
    got my new HU coming soon too ;) been a long project to get everything done.
    CenTexTundra and Pudge like this.
  4. May 6, 2019 at 7:55 AM
    #214
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Baby mods doo doo doo doo doo doo
    Audio/Lift/Tires
    @Pudge did you happen to post how many square feet of MLV and CCF you used?
    jmdaniel and Pudge like this.
  5. May 6, 2019 at 8:03 PM
    #215
    Pudge
    CT
    I'm not exactly sure but i can check my ebay account. I think about 100sq ft of each. I had to order twice I do know that.
  6. May 6, 2019 at 9:52 PM
    #216
    diableri
    diableri New Member
    Central CA
    16' 1794
    Wanted to thank you guys for the pics, helps as I'm planning things out.
    Tundyfundy and jmdaniel like this.
  7. May 7, 2019 at 6:57 AM
    #217
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    Did that come in at around $300? And was it any of the stuff in the picture below?
  8. May 7, 2019 at 8:32 AM
    #218
    Pudge
    CT
    I think I spent less than that by shopping around maybe closer to 200ish total. I ended up doing 2 separate orders cuz I didnt get enough the first time. The MLV is the expensive part obviously, you want the 1lb/ft MLV and 1/8" CCF is good.
  9. May 7, 2019 at 8:36 AM
    #219
    Ynot_tonY
    Ynot_tonY Merciful
    Tony
    Audio/Lift/Tires
    Thanks @Pudge I may be pushing my lift back another month to knock this out. Maybe.
    Pudge likes this.
  10. May 7, 2019 at 9:06 AM
    #220
    diableri
    diableri New Member
    Central CA
    16' 1794
    So @Pudge I've never done this the "right way" in using the layers. I've always used a product or straight up insulation and tap back in the old days. I've had a pretty good outcome every time.
    Knowing what you know now, would you go with a single stage product again on a big job like our trucks or do you think you'd layer in again? For context, have you had a chance to ride in someone's Tundra that used a single product?
    Thanks for all your posts in here, extremely helpful.
  11. May 7, 2019 at 9:09 AM
    #221
    Pudge
    CT
    If I could do it again I would do it the same way with the layers. The mass is what keeps the noise down and other than lead sheets the only way to get that mass is MLV.
    I have not been in a tundra with a single layer of deadening, just a stock tundra, so I may have done some serious overkill for all i know
    Toyotoholic and diableri[QUOTED] like this.
  12. May 7, 2019 at 10:29 PM
    #222
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Pro suspension, sways
    I love overkill.
    I actually used lead plenum sheets in my truck...
    Lol
    Not kidding
    Pudge[QUOTED] likes this.
  13. May 20, 2019 at 8:30 PM
    #223
    jmdaniel
    jmdaniel Spending too much time here...
    Leander, TX
    2018 Tundra CrewMax SR5, 1977 FJ40
    DSI Conversion, including 6" ProComp lift, Fuel Assault Rims, ProComp tires, SunTek protective film, BAK Revolver X2 tonneau cover, Bedrug bedmat, OEM Audio+ Reference 500Q
    Looks great! How much material do I need to do the doors and back wall?
  14. May 20, 2019 at 8:42 PM
    #224
    diableri
    diableri New Member
    Central CA
    16' 1794
    I just did the back wall on mine and it took 3 sheets of 18"x32".
    jmdaniel[QUOTED] likes this.
  15. May 20, 2019 at 8:56 PM
    #225
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    I went 3 layers on the doors 1 layer 80 mil kilmat on the outside door skin 120mil mat66 on the inside with a layer of 394 mil uxcell foam ontop of that uxcell 394mil 16.36sqft Car Noise Sound Deadener Deadening Insulation Mat Waterproof and Moistureproof 60" x 40" https://www.amazon.com/dp/B01I4F0J76/ref=cm_sw_r_cp_apa_i_xy34Cb1H30Q1Q
    It was overkill but I love it
    Toyotoholic and Pudge like this.
  16. May 21, 2019 at 4:02 PM
    #226
    CenTexTundra
    2017 Tundra Limited
    The sheets I used were 9.8x15.7 inch and it took me about a box and 1/4 of these to do all the doors and the back wall. I used the final 3/4 of a box on the floors.
    Here's a link to the stuff I used on Amazon: https://www.amazon.com/gp/product/B0751CBXBT/ref=ppx_yo_dt_b_asin_title_o08_s00?ie=UTF8&psc=1
    I ordered a total of two boxes of this.
    _SP_, Trooper2 and Pudge like this.
  17. May 21, 2019 at 5:07 PM
    #227
    tundraal
    tundraal New Member
  18. May 22, 2019 at 9:54 AM
    #228
    jmdaniel
    Leander, TX
    Thanks, fellas! I bought the silver Noico; 1 - 36 and 1 - 18 square ft. quantities.
  19. May 26, 2019 at 11:00 PM
    #229
    Toyotoholic
    Toyotoholic -4Life-
    Jmz
    17' MGM
    Finally got a solid block of time to get my front floors, tranny tunnel, and firewall sealed up with lead!
    Remove all the wires and sensors
    Laying the lead
    Ready to go.
    Driver's side getting quiet.
    The wall of lead!
    Going under everything is the most time consuming, tedious, pain in the ass, ocd only, if you're an audiophile you understand, and most expensive way to do this. But it is the most effective barrier for road to cab sound improvement. These three sheets took 10 hours to complete. From carpet to completely naked. Then fully lay the lead, then poke all fastener and bolt holes. Then reassemble and check all fitment points.
    I used 9 sheets total in the truck.
    The whole front is done with two full uncut sheets of lead, then I put a top piece all the way up the top of the tunnel that overlaps the sides. The fire wall is another full sheet cut in half to do both sides, and one sheet for small fit points I and around the corners. Sheets are 36"x49" so they are big and heavy~15lbs each.
    I did 4+ sheets for the back wall and floors all the way up to the fronts. The fronts overlaps the back pieces. so, from high up on the firewall, at full width, all the way up to the rear window, is a lead barrier... silent bliss.
    Here's a link to the lead!
    https://www.amazon.com/Cascade-VB-3-Acoustic-Barrier-Pad/dp/B000PPU2UI
  20. Jun 3, 2019 at 7:11 AM
    #230
    jmdaniel
    Leander, TX
    Knocked out the sound deadening this weekend, and it is a simple, but tedious job. Thanks all here for the good info! I have a 1-1/2 sheets left, out of my 36sf and 18sf order, and used almost 2 rolls of the Noico tape. While a roller was handy, there are a lot of places it wouldn't fit, so I used the smoothing tools at the end of my arms. One thing I want to mention is that, when you are tearing off the plastic on the doors, a quick yank will pull almost all of the adhesive off at the same time. Use the plastic to remove any that didn't come off, by pressing the plastic over the adhesive, then giving it a quick yank.
    Back wall, did the inside as well:
    Passenger side rear door, showing the deadening that Toyota places during the truck build, (and not very well). Interestingly, these pieces were in the rear doors, but not in the front doors. I did this door first, before I discovered that yanking the plastic pulls the adhesive clear as well:
    Just before slapping the driver's door back together. I decided to put my OEM Audio + system in at a later date; the deadening took up a lot of time, and I wanted to change just one thing at a time, to hear the effects of deadening by itself:
    A quick thump check, halfway through. First and third taps are driver's door, no deadening. Second and fourth, passenger door, with deadening.
  21. Jun 3, 2019 at 8:25 AM
    #231
    effektz
    effektz New Member
    Fort Worth, TX
    2017 Tundra CM TSS Offroad
    @Pudge Ive already added Dynamat Extreme in my doors and my back wall. With this already laid down, can I still put MLV and CCF over that? I think it shouldnt cause an issue but wanted to just make sure before I made the jump.
    Pudge likes this.
  22. Jun 3, 2019 at 9:24 AM
    #232
    CenTexTundra
    2017 Tundra Limited
    Well....whats your verdict? Makes a huge difference right?
  23. Jun 3, 2019 at 9:32 AM
    #233
    jmdaniel
    Leander, TX
    I only drove it around the neighborhood, as I was pretty baked from being outside most of the weekend, but I'd have to say yes! Can't wait to install the OEM Audio+ stuff, in a couple of weeks. Thanks for your help!
    CenTexTundra[QUOTED] likes this.
  24. Jun 3, 2019 at 8:24 PM
    #234
    Pudge
    CT
    Yes you can absolutely put down foam followed by MLV. Itll cut down on road noise and really make the truck more comfortable for long drives. I used spray adhesive to bond the CCF and MLV together but you don't have to glue them together.
  25. Jun 4, 2019 at 12:33 PM
    #235
    effektz
    effektz New Member
    Fort Worth, TX
    @Pudge What did you do for your headliner? I was thinking of covering it with Killmat and then put on a layer of Dynaliner.
    Also does anyone know where I can go buy some replacement plastic tabs that hold the doors and panels on? I broke a couple taking the door panels off and am sure I will break one or two when I drop the headliner this weekend. Id rather buy a large pack of them so I can replace as needed.
  26. Jun 4, 2019 at 2:56 PM
    #236
    Pudge
    CT
    I actually have not done my roof yet but some day I will get to it. @1UPPER did a nice job on his roof.
    The dealer has those tabs and they are really cheap but I have also seen them on Amazon. @Roman will know the part numbers
    Roman and 1UPPER like this.
  27. Jun 4, 2019 at 3:34 PM
    #237
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I did the dyna mat extreme on my roof and then dynaliner over that. It definitely makes the truck quieter and a lot cooler from the heat on the roof.
    17F3136C-059B-4E3D-B7E6-73FCA66002A1.jpg 739FC30D-4845-48C3-9F0D-6E78D8B26749.jpg
    airosey, jack_yaj, JoshuaA and 2 others like this.
  28. Jun 4, 2019 at 3:44 PM
    #238
    Jerry311SD
    Jerry311SD New Member
    Jerry
    Ramona San Diego CA
    05 Tundra
    I did 80 mil all over the place. Doors,floor,roof ,behind the dash,
    It made a big big difference. Totally worth it! Anyone thinking about at least do the doors you will be surprised
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
  29. Jun 4, 2019 at 4:18 PM
    #239
    effektz
    effektz New Member
    Fort Worth, TX
    Any tips that you can give when doing the roof? How much dynaliner did you need?
  30. Jun 4, 2019 at 4:57 PM
    #240
    Mgmtundra
    Mgmtundra MGM Crew
    Looking at taking the plunge as well, how much of the tape is needed? Assuming this is to keep all the seams nice and tight. Thanks for all the pictures and commentary loving all the OCD. Last time I seen led sheets was for sealing up an X-ray room, next level right there.
    Pudge likes this.
