Sound matting worth it?
Discussion in 'Audio & Video' started by Stumpjumper, Mar 12, 2018.
  1. May 1, 2018 at 5:26 PM
    #61
    Pudge
    Pudge Sap Wizard
    CT
    2015 Blue Ribbon Platinum
    TRD PRO grille, OCD consol organizers, DIY wireless phone charger, 33" Michelin Defender LTX MS, Bak revolver X2 tonneau, weathertech liners, 20% tints. DIY pop n lock, 2018 LED headlights, morimoto fogs, TRD shift knob
    What areas of the doors did you apply it to? My plan was behind speakers on outter skin and a little bit on the inner skin for rattles.
    I'll then apply CCF and MLV over that inner skin of the door, and I'm starting to think some Relfectix to the inside of the door panels for heat purposes.
  2. May 1, 2018 at 6:25 PM
    #62
    Lift Gate Gus
    Lift Gate Gus New Member
    Beaverton, OR
    2018 CM
    Vehicle Modifications:
    Where did you purchase the competition bulk ballistic from?
    I have had a hard time finding it online.
    Pudge likes this.
  3. May 1, 2018 at 7:12 PM
    #63
    1794TRD
    1794TRD It is, what it is!
    Little Rock, AR
    2015 Super White II TUNDRA 1794
    TRD EXHAUST TRD INTAKE Lift 3” front 1.5” rear TRD SKIDPLATE UNIFLEX TRIFOLD BED COVER UNIFLEX SWINGBOX POP & LOCK POWER TAILGATE LOCK TUNDRA BED LIGHTS LED HEADLIGHTS / FOG LIGHTS / PUDDLE LIGHTS / INTERIOR LIGHTS WHITE DOOR HANDLES WHITE MIRROR COVERS TOYTEC BOSS REAR SHOCKS CRUX AVITY-01 VIDEO INTERFACE AJT KEY FOB COVER
    I placed a small square behind each of the speaker magnets inside the door & all over the metal behind the door panel. On the back glass panel, I took the insulated mat down and stuck it to the entire metal cover. The bulk kit was just enough. Not a whole lot of room for error. This stuff is good though and can’t really mess up if you take your time.
    B737 and Pudge like this.
  4. May 1, 2018 at 7:14 PM
    #64
    1794TRD
    Little Rock, AR
    I did some searching on the interweb, but think I found my best deal on ebay.
  5. May 1, 2018 at 7:49 PM
    #65
    Beerdude77
    Beerdude77 New Member
    2018 Silver Sky Tundra Limited TRD CM
    Linex bed, "Toyota" Console Safe
    I am early in my system install and so far have only done the 25% rule using sound deadening showdown tiles on rear wall outer skin (closest to bed) then wrapped the metal access panel to rear window and the surrounding inner rear wall in Soundskin Pro then reinstalled the PVC liner and today when I went to open the rear window I had to look in the rearview mirror to see if it had gone down because it was so quiet....pics to come later when I finish my build...
    Pudge likes this.
  6. May 13, 2018 at 11:17 AM
    #66
    robstruck
    robstruck New Member
    2016 Tundra Trd
    Pro comp leveling with 305/65r18 bfg ko2, magnaflow exhaust, tanneu cover, alpine speakers
    Hey guys i was looking at the noico 80 mil, wich appears to be the best bang for your buck. Jad pretty good reviews, anyone have any experience with it? Is it a good choice?
  7. May 13, 2018 at 11:19 AM
    #67
    Pudge
    Pudge Sap Wizard
    CT
    I have some i still haven't installed. A few guys here have used it and have good reviews, which is why I got Noico as well
  8. May 13, 2018 at 1:56 PM
    #68
    robstruck
    2016 Tundra Trd
    Cool, can’t wait to see your results. Im very i terested in the same project. So far i replaced the door speakers non JBL and installed some dynamat extreme. Its ok but im so disappointed in how much exterior noise in these trucks
  9. May 13, 2018 at 2:12 PM
    #69
    Pudge
    Pudge Sap Wizard
    CT
    Noico or any CDL material doesn't really help with ambient noise, its mostly for vibration. Look into mass loaded vinyl and other types of sound proofing. I suggest googling sound deadener showdown, some great ideas there
  10. May 13, 2018 at 7:51 PM
    #70
    Beerdude77
    I'm pretty damn happy with how much ambient noise reduction I got out of the Soundskins I did it in the doors and rear wall. I installed it more for sound system improvement but today was the first day since I installed it that I took a road trip with the fam (aka music at level 5 max) and even my wife who never rides in my truck noticed how much quieter it was. That said, if you really want to quiet the cabin I also recommend the sound deadening showdown method and you should check out his website, it isn't though I will say that.
    smslavin, B737 and Pudge like this.
  11. May 14, 2018 at 12:11 PM
    #71
    robstruck
    2016 Tundra Trd
    Thanks, im interested in both ambient noise reduction and better sound quality as i do plan to ad a couple of subs. Nothing to crazy but hoping to do it all at once.
    Beerdude77 and Pudge like this.
  12. May 14, 2018 at 4:13 PM
    #72
    Beerdude77
    That Soundskins stuff knocks out 2 steps in one so I chose it just from a time saving standpoint. I was very close to doing the raammat though which wouldve been cheaper but the extra steps to install steered me away. Once I get my last door matted and speaker installed and then put in my new head unit I will post a build thread with pics and thoughts
    Pudge likes this.
  13. May 14, 2018 at 5:20 PM
    #73
    Pudge
    Pudge Sap Wizard
    CT
    I wish I had known more about Soundskin before I bought all my stuff would have saved me time and aggravation I'm sure
  14. May 16, 2018 at 12:13 PM
    #74
    Pudge
    Pudge Sap Wizard
    CT
    Got my drivers door done today. Took about 2 hours.
    CLD in a few places and behind speaker (pic doesn't everywhere I used it. I put it on inner and outer skins of the door.
    Then cut the closed cell foam to fit. Used that as a template for the MLV. Spray adhesive to bond them together. Used Velcro attached to MLV with a hole cut in foam to attach it. It holds strong and perfectly.
    The door feels and sounds so solid now and there are no vibrations whatsoever.
    Took a good bit of fine tuning and trimming to get the door panels back on, its a tight fit now.
    Trooper2, smslavin and Beerdude77 like this.
  15. May 16, 2018 at 12:19 PM
    #75
    Beerdude77
    @Pudge I can't remember, are you not replacing the speakers?
    Pudge likes this.
  16. May 16, 2018 at 12:32 PM
    #76
    smslavin
    smslavin On a plane...
    Denver, CO
    2016 Tundra CrewMax SR5
    i'm pretty happy with the soundskins in my truck. did the inside/outside of the doors, rear wall and floor. i have 3 tubes left that will eventually go on the roof but, to do that, i have to get super motivated to pull the cap and the headliner. i also put some of the soundskins rings around the door speakers.
    i see you did the bottom of the outer skin but, did you add a strip to the middle section? there's another section in there, in between the two cross braces.
  17. May 16, 2018 at 12:59 PM
    #77
    Pudge
    Pudge Sap Wizard
    CT
    No plans to do speakers at this time. I don't have the budget for an amp and dsp to make this stupid JBL system work right. I doubt just doing speakers and leaving everything else stock is worth it?
    My hope is some improvement with the sound deadening I'm doing.
    Beerdude77 likes this.
  18. May 16, 2018 at 1:01 PM
    #78
    Pudge
    Pudge Sap Wizard
    CT
    I got some on the upper section above the brace, what you see in the pic is the middle section between the brace and some kind of round pipe brace. I did not do any below the round pipe at the bottom of the door.
    smslavin likes this.
  19. May 16, 2018 at 1:12 PM
    #79
    Beerdude77
    That lower section was a PIA to do...
    Pudge and smslavin like this.
  20. May 16, 2018 at 1:16 PM
    #80
    Pudge
    Pudge Sap Wizard
    CT
    It looked like it would be, so I skipped it. I think I for enough on to cut down on vibration and rattles. Time will tell I supposed
  21. May 16, 2018 at 1:23 PM
    #81
    Beerdude77
    smslavin and Pudge like this.
  22. May 16, 2018 at 1:24 PM
    #82
    Beerdude77
    For some reason my response to @smslavin ended up in the "quoted" section...
  23. May 16, 2018 at 1:36 PM
    #83
    Pudge
    Pudge Sap Wizard
    CT
    Soem day when i finally get all the doors, floor and back wall done, is like to do my roof with something. Drove home in a nasty rain storm yesterday and noticed how loud it really is.
  24. May 16, 2018 at 1:51 PM
    #84
    smslavin
    Denver, CO
    that's alright. everyone gets a couple of free fat finger moments...
    i actually wound up with 10 rolls. i used 4 on the doors then another 3 for the rear wall and floor. a lot of the scraps from the doors got used to fill in the small areas on the rear wall and around the trans tunnel. the soundskin was super easy to work with until it got hot then, it just got all over everything.
    Pudge likes this.
  25. May 17, 2018 at 11:11 AM
    #85
    robstruck
    2016 Tundra Trd
    So is soudskin supposed to have the same ambient noise reduction as the three step process wilth mlv? If so how well did it work and how much$?
  26. May 17, 2018 at 11:33 AM
    #86
    Pudge
    Pudge Sap Wizard
    CT
    I believe Soundskin is a combo of closed cell foam and butyl and foil. I do not believe it contains mass loaded vinyl which is what really is supposed to kill ambient sound
  27. May 17, 2018 at 11:54 AM
    #87
    smslavin
    Denver, CO
    james, over at tech12volts, has kits. you can also get it by the roll at abt. you'll need one roll per door. i used another 3 to cover the rear wall and floor up to the pedals. the rings i had to order direct from soundskins. took forever to get here.
    this. however, there is a significant reduction in road noise. not sure how it would to compare to what pudge has done with the mlv. i'm sure once i do the roof it will be even better.
    Pudge likes this.
  28. May 17, 2018 at 2:31 PM
    #88
    Beerdude77
    I suspect MLV does a better job just based on what it is but I was very satisfied with the reduction of ambient noise with the soundskins
  29. May 17, 2018 at 8:57 PM
    #89
    Pudge
    Pudge Sap Wizard
    CT
    I wish I had done more research and gotten the Soundskin. I'm in too deep with what I have to look back so I'm going to plug away one area at a time. I suspect that the back wall and floor is where I'll find the greatest improvement ?
  30. May 17, 2018 at 9:37 PM
    #90
    robstruck
    2016 Tundra Trd
    Cool, thanks for the info guys. I guess il have to compare cost and ease of install. I get vibration noise around the inner door handle/latch with loud music even after the dynamat. Do u guys have this problem after your installs?
