SOS - Fox 2.5 Suspension
Discussion in 'Suspension' started by Aggie2002, Apr 14, 2023.
  1. Apr 16, 2023 at 8:42 PM
    DeesCrewMax
    DeesCrewMax New Member
    Deric
    2018 Cement Crewmax SR5
    Accutuned Fox 2.5 DSC/2.0 rr, SnugTop Rebel, Alpine Amp, OEM LED headlights, LED fogs, Remote Start, RB20 steps, RCI Skids, 10" BA Muffler, 17" Icon Alloy Six Speeds, 15" Tint, Pro-clip mount
    I agree with shackling the rear. If that still doesn’t cut it, do the 500lb. I’ve got that setup and it’s nice. (I have the 2.0 r in the rear though.
    My 500lbs aren’t soft so I can’t speak on the 700lbs. I have no sway bars and on full soft(open) up front it still feels pretty planted.
    Aggie2002[OP] likes this.
  2. Apr 17, 2023 at 3:09 PM
    Aggie2002
    Aggie2002 [OP] New Member
    Arlington, VA
    2017 Tundra Limited TRD Offroad
    so I called Fox regarding 500lb vs 700 and said for highway, the 500 would be fine but if offroad, they may bottom out. Fox did state they have a 600lb coil available.
    That being said, how do your shocks with the 500lb coils do on the fire roads, bumpy gravel roads, etc at speed?
    I’m not going to be doing anything crazy offroad but just want the truck to feel planted and handle well on fire roads etc.
  3. Apr 17, 2023 at 3:17 PM
    DeesCrewMax
    Deric
    Did you call Fox? or @AccuTune Offroad ? I went specifically with the 500lb at AccuTune's suggestion. I have 4x4 crewmax, aluminum skids (RCI engine, trans, cats), no big bumpers, no winch, but have a topper, and a family of 4. They didn't even push me into the 2.5 rear, just suggested the 2.0 rr. I opted for the "adventure tune".
    On the road they feel a lot like the 6112 with (650lb? coils that they ship with), but slightly more forgiving. Off-road testing has been minimal as I put them on right before winter, but so far they feel good (comfortable and controlled).
    I'm not jumping it with 1500lbs of gear/family in it. YMMV.
    Edit: I leave the DSC at the softest setting around town and highway unless I’m hauling weight. The dials seem to work well, but i’m no expert and ride quality to some degree is subjective.
  4. Apr 17, 2023 at 3:54 PM
    Aggie2002
    Arlington, VA
    Thanks so much for the good info!
    DeesCrewMax likes this.
  5. Apr 17, 2023 at 4:10 PM
    DeesCrewMax
    Deric
    If the ride quality and functionality are satisfactory then I wouldn’t over think it. Spending a bunch of money should yield what you hoped for, but maybe let things settle and see if the shackle lift in the back or a winch bumper are better options. I hope you make it work for your needs. Good luck and feel free to reach out if you have questions about my setup. Plenty of more knowledgeable folks on here than me, but I’m happy to help if I can.
    Aggie2002[QUOTED][OP] likes this.
  6. Apr 17, 2023 at 5:35 PM
    Aggie2002
    Arlington, VA
    Sir:
    Thank you very much. Everybody on here has been nothing but a great help. You’re right, I am probably overthinking it some. Thanks for offering to learn from your setup.
    texasrho83 likes this.
  7. Apr 17, 2023 at 5:57 PM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Here's the gap between my UCA and tire
  8. May 10, 2023 at 7:22 PM
    Aggie2002
    Arlington, VA
    Update:
    So I ordered the 500 lbs coils. Front end of the truck is still higher than the back even with preload backed off all the way- just not as bad as when the 700 lbs springs were on the truck. Will probably put a 3/4” shackle to level the truck out the best I can.
    I’m just baffled that the 500 lb coils didn’t allow the front end to drop more.
    Thanks again for everyone’s suggestions.
