Solved: proper TPMS sensors for 2020 Tundra TRD Pro with keyless entry and push-button start
Discussion in 'Wheels & Tires' started by Montana Mike, Dec 26, 2019.
  1. Dec 26, 2019 at 4:49 PM
    Montana Mike
    Montana Mike [OP] New Member
    Per the Toyota Parts Department at my local dealership, at the time of this writing (12/2019), it appears there is an error, or incomplete information, listed in the Toyota parts catalog when referencing the proper TPMS sensors for 2020 Tundra TRD Pro CrewMax with keyless entry and push-button start.
    After building a set of wheels (with winter tires) and new OEM Toyota TPMS sensors (Toyota part # 42607-0C091), the sensors would not register with the 2020 Tundra TRD Pro ECU as per the instructions described in the owners manual. As a result the TPMS light on the dash would not extinguish and the psi of each tire would not be displayed.
    Problem solved:
    Dealership installed new TPMS sensors (Toyota part # 42607-06030) and these sensors registered properly, with psi of each tire properly displayed in the instrument cluster.
    As an aside, I went with Bridgestone Blizzak DM V2 tires (275/65 R18), and I'm very pleased with an OBVIOUS improvement in acceleration, cornering, and stopping in winter conditions.
    murphysf and demon like this.
  2. Dec 26, 2019 at 6:45 PM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    2007 Tundra and 2011 Sequoia
    Are the Toyota part # 42607-0C091 ones what are used on 2019’s Limited’s. I’m looking at getting some, figured I’d ask.
  3. Dec 27, 2019 at 5:30 AM
    Kwe1982
    Kwe1982 New Member
    Wisconsin
    Aluminum
  4. Aug 2, 2020 at 7:10 PM
    Mitral
    Mitral New Member
    Tankereasy likes this.
  5. Nov 27, 2020 at 2:27 PM
    Zizyang
    Zizyang New Member
    2020 tundra pro army green
    Wow that a lot of work... i just got land cruiser heritage edition rim on my green 2020 pro amd its doing the samething. I guess ill have to make a trip to toyota
  6. Nov 27, 2020 at 3:12 PM
    jrquist
    jrquist Canon Shooter
    Carlton, Minnesota
    2020 Tundra Sport Super Bright White
    A trip to the dealer is going to cost you plenty. You can find the correct sensor for around $62.00 for 1 vs $100 at the dealer. Your truck will learn in the correct ones (Toyota part # 42607-06030) I used my Autel sensor reader and found that the difference is the length of the code. The correct ones are 7 digits and the 42607-0C091 sensor is 8 digits in length and the reason your truck can't learn them. The Autel sensors are $120 for 4 but you need the Autel reader in order to program.
  7. Nov 27, 2020 at 3:32 PM
    Zizyang
    Zizyang New Member
    I guess i got very lucky... discount use the oem tpms took 30 mins and it work all by itself. Thx I'll keep this post for future reference
  8. Apr 23, 2022 at 7:50 PM
    murphysf
    murphysf New Member
    I have a 2021 RAV4 and am running into a similar problem.
    It seems like the Toyota part # 42607-0C091 is for vehicles with a standard conventional key
    and
    Toyota part # 42607-06030 is for vehicles with a SMART key - (keyless entry and push-button start).
    Can anyone confirm this?
  9. Apr 23, 2022 at 8:11 PM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    Mike and MurphySF contact @Roman on the following thread...
    Ultimate OEM Toyota Parts Thread for 2nd gens (2007-21)
    Just make a post on that thread with your questions (addressing them to Roman), and he should be able to accurately answer your questions. He usually responds within 48 hours!
    Roman and murphysf[QUOTED] like this.
  10. Apr 23, 2022 at 8:14 PM
    murphysf
    murphysf New Member
    thanks... but I am new to this forum I just signed up and do not know how to find the thread you mention... can you please post a link? Thanks!
  11. Apr 23, 2022 at 9:11 PM
    Tripleconpanna
    Looks like you found it...
