2018 Lists 2 TPMS Sensors, Type 1 and Type 2, Which Do I need?
Discussion in 'Wheels & Tires' started by mrjohns2, Apr 9, 2018.
  1. Apr 9, 2018 at 7:26 PM
    mrjohns2
    mrjohns2 [OP] New Member
    How do I know which TPMS sensors work with my 2018 Limited?
    I looked them at Toyota of Cool Springs and they list all 2018 models for both types.
    I'm getting 18" wheels and want to know which type I need. Does anyone know? I know 2018 has different models from past years (based on some searches), but no one seemed to mention 2 types for 2018.
    Type 1
    https://parts.toyotaofcoolsprings.c...meT0yMDE4JnQ9bGltaXRlZCZlPTUtN2wtdjgtZmxleA==
    Type 2
  2. Apr 9, 2018 at 8:02 PM
    sr5shark
    sr5shark No matter where you go, there you are.
    Alan
    Walnut Creek, CA
    2016 SR5 CrewMax 4x4
    Bilstein 5100's |SCS SR8 w/ GY Duratrac | TRD rear sway bar
    I believe that the type 1 tpms sensor is for aluminum wheels and the type 2 sensor is for steel wheels.
  3. Apr 9, 2018 at 8:08 PM
    jrd347
    jrd347 New Member
    2018 Tundra Limited 4x4
    What kind of wheels you getting?
  4. Apr 10, 2018 at 4:43 AM
    mrjohns2
    I’m getting 18” alloy wheels off of a 2010 Tundra.
  5. Apr 10, 2018 at 5:52 AM
    jrd347
    jrd347 New Member
    42607-0C091 IS FOR ALLOY/ALUMINUM WHEELS
    42607-0C101 IS FOR STEEL WHEELS
  6. Apr 14, 2018 at 2:19 PM
    tt2323
    tt2323 New Member
    2018 White Platinum crewmax
    When it comes to the different ‘18 tundra stock wheels what rim style is what sensor? Contemplating a different stock wheel wanna make sure the sensors fit.
  7. Apr 14, 2018 at 7:33 PM
    jrd347
    jrd347 New Member
    Aluminum to aluminum the sensors will work. It’s if you go from factory steel to aluminum where you have issues.
  8. Apr 15, 2018 at 7:43 AM
    NCinCO
    NCinCO Is it Friday yet?
    Gary
    Thornton, CO
    2018 Smoked Mesquite Limited CM TRD
    @Roman is your go to guy for Toyota parts and questions.
  9. Apr 25, 2018 at 12:24 PM
    bpherbst
    bpherbst New Member
    2018 Toyota Tundra SR5 Double Cab
    are there any alloy rims that will fit 42607-0c101 (the tpms sensors for the steel rims). if none. which sensors should i buy that the 2018 tundra will pick up? I heard they switched they to 433 mhz sensors in the 2018 and older model tundras had 315 mhz so those dont work. is that true?
  10. Jun 14, 2018 at 3:31 PM
    thebest3
    thebest3 New Member
    CA
    2018 cement db
    line x bed, icon 2.5 stage 2 ,method nv bronze, softtopper.
    any update on this as im in the shoe..
  11. Jul 7, 2018 at 7:32 AM
    CrewmaxMoonTwp
    CrewmaxMoonTwp New Member
    To thebest3, did you ever get an answer to your question. What tpms did you need to buy? Thanks
  12. Jul 11, 2018 at 9:08 AM
    thebest3
    thebest3 New Member
    CA
    2018 cement db
    no I just install without sensor.
  13. Jul 11, 2018 at 9:13 AM
    CrewmaxMoonTwp
    Ok, I bought the ones ending 091, still need to have them installed
  14. Aug 2, 2018 at 9:20 AM
    TitanTPMS
    TitanTPMS New Member
    Both sensors are pre-programmed the same. Both are 315MHz. The difference between the 42607-0c101 (type 2 for steel wheels) and 42607-0c091 (type 1 for alloy wheels) is the valve angle - one has a 20deg and the other 40deg. They would both work on the same truck but they may not fit all the same wheels. (usually on a truck alloy wheel you can install the "steel wheel" sensor upside down and get away with it although not recommended since the sensor may be damaged if the tire goes flat).
  15. Aug 2, 2018 at 9:21 AM
    TitanTPMS
    42607-0c101 is for alloy wheels while the 42607-0c091 is for steel.
  16. Aug 2, 2018 at 10:07 AM
    CrewmaxMoonTwp
    Fyi, I was able to get the new ones programmed fine. 2018 requires a 7 digit id, while 2017 and older models have an 8 digit code, so that is why they do not work on an 2018.
  17. Aug 2, 2018 at 11:09 AM
    TitanTPMS
    That would be correct about 2018 vs 2017 + prior. Even then, there's a way around that :p The challenge is to use a sensors angled for a steel wheel vs alloy - again, they do work but valves are just angled differently.
    Great to hear you got it going!
  18. Jan 9, 2019 at 10:33 AM
    DP Tundra
    DP Tundra New Member
    2018 Tundra
    I am similar position with wheel swap. I purchased a 2018 Tundra with steel wheels, then bought a set of 2015 Alloy Tundra 18” wheels however I am having issues with tmps system. Tire shop installed my existing sensors from steel wheels, installing them upside down. Initially, the system recognized the sensors in new wheels, however, after 30 miles, got a warning stating “ tire pressure system malfunction, please visit dealer.” I am unable to reset system..frustrating. Any suggestions?
