SOLVED: Leaking brake fluid
Discussion in '1st Gen Tundras (2000-2006)' started by MrAristo, Mar 20, 2020.
  1. Mar 20, 2020 at 3:04 PM
    MrAristo
    MrAristo [OP] Hounty Bunter
    South FL
    ‘01 4X4 Limited TRD
    Need some assistance folks. My 01 has been great so far, but one pain in the ass has been my driver side drum brake. I successfully replaced the wheel cylinder about 2 months ago when I noticed it was leaking, hadn’t had any issues until now. I thought maybe it was faulty so I went back, exchanged it for another one and installed. Brake fluid leak continued, so I went back two more times, complained and replaced it. I’m sitting here after 3 wheel cylinders with brake fluid still leaking around and behind the drum. Any ideas? I believe it’s coming from the screw-on portion from the brake line, but other than that I’m stuck.
  2. Mar 20, 2020 at 3:12 PM
    remington351
    remington351 New Member
    2006 SR5 DoubleCab
    Exchanged for another one? You gotta go OEM these days aftermarket parts are crap.
    Your specific situation sounds like your not getting proper sealing between the brake line flare and the wheel cylinder nipple. Assuming you've seated it properly while tightening the flare nut on your failed attempts, I'd say you need to inspect the brake line flare. Best case, it's a piece of grit or rust stuck or embedded in the flare, worst case, the aftermarket nipple was not concentric and distorted your brake line when you tightened it down.
    Keep us updated.
    MrAristo[OP] likes this.
  3. Mar 20, 2020 at 8:56 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    Also check the flare on the brake line real good for any hairline cracks.
  4. Mar 21, 2020 at 4:25 AM
    tvpierce
    tvpierce Formerly New Member
    Maine
    One bad wheel cylinder: sure, it happens all the time. Two bad wheel cylinders: it's a fluke... but hey, anything's possible. Three bad wheel cylinders: the odds are against it.
    You have a leak at the connection between two parts. You've replaced one of the parts 3 times and the connection still leaks. What's the next logical step?:monocle:
    JohnLakeman and MrAristo[OP] like this.
  5. Mar 21, 2020 at 4:34 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    2017 Tundra 5.7L 4WD DC TRD
    2020 GD 2670MK Travel Trailer
    Is it possible that the rear axle seal is leaking on that side? If you are seeing oil splashed around on the inside of the drum/back plate and not directly observing leaking brake fluid from the wheel cylinder, I would check it out closely. Very typical place to leak.
    Buckaroo
  6. Mar 21, 2020 at 4:39 AM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    Not OEM, but I believe the part itself isn’t the issue after 3 attempts. Agree with the confirmation that it’s most likely the brake line flare. I’m going to jack her up today and try and get this resolved. Do you recommend maybe putting some loctite or tape on the thread?
    That’s my thought process, since odds aren’t against it being the wheel cylinder it only has two other points of entry/exit, the bleeder nipple or brake line valve. Mainly fishing for others who’ve had the same issue :annoyed:
    Nope definitely not seals (thank god). Brake fluid reservoir continues dropping after being topped off.
  7. Mar 21, 2020 at 4:56 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    Don't use loctite or tape on the fitting threads. It is a mechanical seal between the flare and the fitting - the threads do not provide the seal. The flare needs to be well formed, the mating surfaces need to be clean and the line/fitting need to be in alignment. Make sure the nut threads haven't been cross-threaded and it threads easily. You should not have to lean on it to tighten it but you may need to support the cylinder side with another wrench.
  8. Mar 22, 2020 at 6:03 AM
    foxtrapper
    foxtrapper New Member
    2003 SR5
    We’re it mine, while I’d look at the line and flare, I’d likely simply replace that line.
  9. Mar 22, 2020 at 6:55 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    Agree, this is likely where you would end up.....
  10. Mar 22, 2020 at 4:50 PM
    MrAristo
    South FL
    ‘01 4X4 Limited TRD
    So was able to solve today... Rather coincidental, but my diff is indeed leaking through the seal on the same wheel where I replaced the cylinder before, AND I’m also losing brake from my master cylinder. Good news is I got a free master cylinder, swapped it out and issue gone. Bad-ish news, I’m going to have to get down and replace the seal on my diff within the next month or two o_O
  11. Mar 23, 2020 at 5:57 AM
    Buckaroo
    Buckaroo New Member
    Central Ohio
    If I am understanding you correctly, that is the axle seal that I suggested in my first post. The gear oil from the diff floods the axle up to the wheels and seals that are on the axle at each wheel contain the oil. When they fail, you get gear oil splashed all over the inside of your brake drum. Very common problem. Due to that problem, I replaced rear axle seals & bearings on both sides on my 2000 T4R a number of years ago. You may be able to get away with just replacing the seals but many times, play in the bearings is what causes the seals to leak. Also, you will need to replace the brake shoes as they are loaded up with gear oil. If you just do the seals and the leak returns, you get to do the brakes shoes again. Depending on how long you were running with the rear diff low on fluid, you may end up replacing/rebuilding that as well. The noise will tell you. Glad you finally found the problem.
    Buckaroo
    mtntop likes this.
  12. Mar 23, 2020 at 12:22 PM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Actually the leaking seal causes the wheel bearing to fail. The gear oil gets into the sealed wheel bearing and washes out the grease which causes the wheel bearing to fail. That's why the two should always be replaced together.
    Also, make sure your axle vent is clear and working. A clogged vent is the main cause of the seals leaking. Now would also be a good time to modify the vent to a hose style if you haven't already done so.
    tvpierce likes this.
