SOLVED Auto headlights not coming on after 12voltsolutions remote start install
Discussion in '2.5 Gen Tundras (2014-2021)' started by sweatypowderpig, Sep 2, 2019.
  1. Sep 2, 2019 at 10:13 AM
    sweatypowderpig
    sweatypowderpig [OP] New Member
    sierra nevada
    2019 Cement Limited DC TRD Off Road
    title says it all
    ever since I installed their remote start, if it becomes dark and my headlights are set to Auto, they will not automatically come on. Have to manually turn them on by turning the stalk.
    any I can do or is this something I have to now live with? will be contacting them also
  2. Sep 2, 2019 at 10:25 AM
    GasGuzzler
    GasGuzzler New Member
    2019 Tundra
    6” Readylift AMP Research Power Step Sides Fuel Grenade wheels Toto Tire Complete Stereo Overhaul
    May have to reach out to them. Mine installed without any issues what so ever.
    Sorry to hear it. I hate Complications as a result of installing something simple.
  3. Sep 2, 2019 at 2:21 PM
    RollTide82
    RollTide82 New Member
    Michael
    2019 Tundra 4x4
    Mine works...email them they are helpful
  4. Sep 2, 2019 at 2:36 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Definitely email them. They responded very quickly on a weekend when I asked them a question a while back.
    You may want to check the connection to the left of the steering wheel. They call out being very careful with that one as it's easy to bend pins. Maybe take a look and see if that's the case.
    GasGuzzler likes this.
  5. Sep 3, 2019 at 3:42 AM
    BigdaddyII
    BigdaddyII New Member
    South Louisiana
    2019 Ram 1500
    I installed a Fortin Evo One and during installation I left the headlights in the "auto" position and had a situation where the headlights were always on whenever the key was turned. I scratched my head for a few days and then finally turned them to "off" and back to "auto" while the truck was running. A long shot but worth a try.
    Mountun Goat likes this.
  6. Sep 3, 2019 at 3:52 AM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    I had this issue with compustar. The remote start and alpine maestro were basically fighting each other for data.
  7. Sep 3, 2019 at 5:31 PM
    sweatypowderpig
    sierra nevada
    were you able to figure it out or did you just live with it?
  8. Sep 3, 2019 at 5:34 PM
    LT75
    LT75 Seasoned Pro
    Saint Charles, IL
    No mods yet
    The shop fixed it. They called compustar to get the fix. If you want I can give you the shop number to call and see what the fix was.
  9. Sep 5, 2019 at 8:23 AM
    sweatypowderpig
    sierra nevada
    SOLVED
    I installed the remote start system about 2 months ago and had just lived with it since I hadn't been driving in the dark it being summer and all. Hadn't even really noticed it wasn't working until I started doing this new weekly commute late at night. As days are getting shorter I figured I should finally figure it out.
    12 volt suggested I check all plugs and connectors and make sure they were all seated. That had been my plan as well once I had some time to pull apart all the trim, particularly since I had remembered pulling a plug during install that I thought had been the BCM but wasn't.
    First thing I did after pulling all the trim was push just a little bit on that plug. lo and behold, we have auto headlights again.
    crazy how it just needed a little pressure to complete contact on probably the one pin that controlled that feature. can't say I even felt the plug move appreciably
    Mountun Goat, TRDFerguson and Pinay like this.
  10. Sep 5, 2019 at 8:30 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Good news!!
  11. Dec 13, 2019 at 5:59 PM
    Genuine Cooling Systems
    Genuine Cooling Systems New Member Vendor
    Anyone having issues where door unlocks when you remote start the vehicle?
  12. Dec 13, 2019 at 6:08 PM
    Joe333x
    Joe333x Member
    Boston
    2019 Tundra CrewMax Platinum
    I just installed a 12volt solutions kit. It had a section with two wires in the harness and one wire required to be cut to work with autohead lights, it was in the instructions for which to cut. Also the doors are supposed to unlock and then relock when remote started. If they are staying unlocked something it's not right, it is an option in the remote start module to have the door unlock so that it disables the factory alarm then relock so you can unlock with the fob and enter with out the alarm going off, or you can have them stay locked or stay unlocked. I only know this because I bought the adapter to connect the module to a computer and reprogram to stay on longer than 15 minutes.
  13. Dec 13, 2019 at 6:24 PM
    I will have to contact them. For some reason it stays unlocked even if I hot the lock button. When I do hit the lock button my headlights flash once.
  14. Dec 13, 2019 at 6:37 PM
    Also, anyone have trouble putting the kicker panel back on? I can't seem to get the top bracket lined up to snap in.
  15. Dec 13, 2019 at 6:55 PM
    AZTundra
    Paul
    Phoenix, AZ
    Make sure that the retaining clips are not left behind the kick panel stuck into position. If so, pull them out and attach them to the rear of the plastic kick panel then reinstall.
  16. Dec 13, 2019 at 6:56 PM
    I will have to check that. The white clips on the frams of the truck are there, I didn't see anything on the panel itself.
  17. Dec 13, 2019 at 6:58 PM
    I also noticed on the 20 pin connector one of the pins on the factory connector is missing. Not sure if that is suppose to be missing or I broke something.
  18. Dec 13, 2019 at 8:37 PM
    Joe333x
    Joe333x Member
    Boston
    Make sure that they are line up, I had some issues snapping it down also, had to look where the clip on the plastic was and make sure it was going in correctly.
    If there is a wire on the other side of the pin, there should be a pin.
  19. Dec 13, 2019 at 8:39 PM
    Joe333x
    Joe333x Member
    Boston
    Just for reference on the auto lights.
  20. Dec 13, 2019 at 9:10 PM
    sweatypowderpig
    sierra nevada
    interesting. i have a 19 double cab limited. no mention of that in my kit. auto headlights work great after I made sure the connector I erroneously pulled was properly seated.
  21. Dec 13, 2019 at 9:13 PM
    Joe333x
    Joe333x Member
    Boston
    Maybe they changed their kits. Was yours the complete plug and play tpms with a flashlogic/Omega module? I ordered mine black Friday.
  22. Dec 13, 2019 at 9:23 PM
    sweatypowderpig
    sierra nevada
    you had me real confused for awhile. after some google-fu, lo and behold, there's another 12 volt solutions based in canada, which i think is the one you're talking about.
    This thread is about the kit from 12volt.solutions based in Oklahoma.
  23. Dec 13, 2019 at 9:26 PM
    Joe333x
    Joe333x Member
    Boston
    I ordered from the one in Oklahoma this is the kit I ordered https://www.12volt.solutions/produc...tart-kit-h-key?rq=yr_2019~mk_toyota~md_tundra
    My guess is their previous kits looking at pictures in the instructions used the Fortin modules, the new kits used FlashLogic/Omega modules.
  24. Dec 14, 2019 at 5:30 AM
    I did not cut this wire. I thought with the new kits 12voltsolutions sends this does not require to be cut. My auto headlights work fine as of now.
  25. Dec 14, 2019 at 5:31 AM
  26. Dec 14, 2019 at 5:35 AM
    Found someone on tundratalk who ran into the same issue I am having a few months ago.
  27. Dec 14, 2019 at 5:41 AM
    Borador
    Borador New Member
    Olive Branch, MS
    2016 Crewmax 4x4 w/1794 Interior upgrade
    Thanks for this (helpful) post. I have the same issue with mine.
  28. Dec 14, 2019 at 7:31 AM
    Well trying to troubleshoot the issue with the remote start I broke one of the clips under the molding to keep it in place. @Roman do you know the part number to this piece and the clips that hold the upper kicker panel?
  29. Dec 14, 2019 at 7:50 AM
    Joe333x
    Joe333x Member
    Boston
    The no cutting refers to wires on your car, you only have to cut this wire if your directions say to. In their kits that use Fortin modules you don't have to, I just bought my kit black Friday and it used a Omega/Flashlogic module and the directions said which wire in the harness to cut for auto headlights.
  30. Dec 14, 2019 at 7:57 AM
    I went back through and cut the wire it said to cut "yellow". Doors still stay unlocked while the engine is running unfortunately.
