Solution for underseat sound system?
Discussion in 'Audio & Video' started by SullyMoto19, Sep 14, 2017.
  1. Sep 14, 2017 at 11:52 AM
    SullyMoto19
    SullyMoto19 [OP] New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    So I've been thinking a lot about adding 2 more 10" to my system but I want them to go under the back seat. I currently have 2 shallow mount 10"s and a box behind the seats of my crew cab. don't get me wrong, they sound great as they are both 600RMS subs, but I want to "beat the block up" as the rappers say.:rofl: My buddies full size kicker 10"s at 300RMS each hit harder than my shallow Digital Designs 10"s at 600RMS each.
    Here my predicament:
    1. Zero space because of the foam under the seats. I've seen on YouTube and on some websites that you can cut the foam out pretty easily. They also make custom boxes to put in place of the foam but the ones I've seen are roughly $500 just for the box.
    2. If you do cut the foam out, you can only fit shallow mount subs with a mounting depth of about 4.25" and that will mount flush to the bottom of your seats.
    Solution?
    I noticed there are metal bars/brackets for where the seats meet the cab and mount. Now, tell me if this makes sense:
    If I get either some spacers or washers of some kind and raise the entire back seats up 1-2 inches, my mounting depth should increase because of more space, correct? Sounds pretty simple in my head, might make the back window a little smaller but I don't think it would hurt anything considering I have a back up camera or its usually rolled down anyways. Might have to get longer bolts for the seats, but I think that would be minor.
    I want to put full size 10"s under the seats, and the smallest mounting depth I can find it 5.25-5.75" and I'm ok with that.
    So in theory, my idea should work. Unless raising the seat height is much harder than I'm anticipating..... Does any one have any advice, pointers or information to tell me I'm an idiot and that my idea won't work?
  2. Oct 6, 2017 at 5:51 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    I'm putting a pair of 10" shallow subs behind the back seat. Did a easy mod so I can fold the setback down to access the area. Not a lot of room but should be able to get two .70 CF enclosed boxes back there. Will post Pics when boxes are done and installed.
  3. Oct 6, 2017 at 7:10 PM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    I would love to be able to just fold seat back down to access area behind seat. Not sure what the heck Toyota was thinking with not putting a latch on it.
  4. Oct 7, 2017 at 5:17 AM
    birdman076
    birdman076 Bird, bird, bird...bird is the word
    Chuck
    Montana
    2015 Brown Tundra Crew Max Limited
    Airbox with K&N Filter, 2" lift on 33's, Alpine iLX-F309 head unit, Pull out bed tool boxes, brown with black trim, rims, etc, black leather interior, matching topper. Muffler delete (too loud..) 62k miles!!!
