Solo Stock Length LCA
Discussion in '1st Gen Tundras (2000-2006)' started by Darkness, Mar 29, 2022.
  1. Mar 30, 2022 at 11:51 AM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Doing it without loosening the bolts can blow the bushings out too
    alb1k and Darkness[QUOTED][OP] like this.
  2. Mar 30, 2022 at 11:53 AM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    If you are careful, is it possible to loosen the bolts and not blow your alignment?
  3. Mar 30, 2022 at 11:55 AM
    Darkness
    Darkness [OP] Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I think if you mark all 4 discs you should be able to return it worst case. Might need some plastic dinner trays under the tires to allow wiggle.
    alb1k, Sunnier and FrenchToasty like this.
  4. Mar 30, 2022 at 12:02 PM
    Casper421
    In the woods
    06 DC
    Spintech is this weekend ;)
  5. Mar 30, 2022 at 12:51 PM
    daveeasa
    David
    I just looked at my box. And put it back.
    alb1k, FrenchToasty and Darkness[OP] like this.
  6. Mar 30, 2022 at 4:59 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @5now808 interesting thought.
    There are variables to be considered. Not all upper arms articulate the same. Uniballs will rise higher than stock arms. I'm not sure how high SPC arms go up. Bump stops matter too. When I had stock bump stops I was hitting my very chopped up pinch weld often. Since changing to super bumps I don't think I have hit them, but haven't looked either. They are soft enough that I'm sure I can still hit.
    All things considered, what works for one may not work for another unless you have identical model, parts, wheels, tire size, and similar enough tires. On the last mention, not all 285/75/16 (or what have you) have the same real outside diameter. You would think they would, but it isn't true.
    I still think that if you can stuff a 33 with stock lower arms, you have good chances to stuff a 35 of the same width with Solo arms.
    5N0W808 likes this.
  7. Mar 30, 2022 at 5:04 PM
    alb1k
    Left Coast
    It's good
    Fox 880-06-420 coilovers would be cool right now for the slight increase in adjustability over 25001-138EXT Kings. Obviously nothing to do with tire size.
  8. Mar 30, 2022 at 5:14 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’m the prince of speculation
  9. Mar 30, 2022 at 5:28 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Camber doesn't matter. The caster these lowers give is essentially a free benefit from moving the tire forward. The tire movement is a great game changer because the pinche pinch weld area on these trucks is so damn close to the tire when you turn and stuff. The added caster from it is sort of an unintended win for us since lifting by coilover tends to reduce caster.
    These guys have been pushing the wheel forward for about 10 years for tire clearance. It was a unique move at the time. They also had a really slick pocket style lower shock mount for added strength and you could have your truck sit lower without losing uptravel.
    https://btffabrication.com/products/99-03-2wd-tundra-longtravel
    FrenchToasty likes this.
  10. Mar 30, 2022 at 5:33 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Now that they have fixed the lower coil mount they would! You still may have to get creative with the reservoir mounts but thats the easy part.
    alb1k[QUOTED] likes this.
  11. Mar 30, 2022 at 5:40 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    SAS is a whole nother world. Let's keep those lunatics behavior put of this thread. :rofl:
    The wheel angle changes as the suspension cycles. Changing ride height by coilover is really the same as cycling the suspension, you're just changing the point of the cycle that it rests at.
    I highly recommend at least once that everybody with modified suspension lift their front end securely on stands. Then take your coilovers off, put your tires on, and cycle your suspension up and down to see what it does. Use a jack to lift it by the lower arm, its damn heavy. Turn your steering wheel about half way to lock, cycle uo and down again, turn full lock, cycle again. The best way to learn about your truck is to play with it.
    RUSTYNUTS and Sirfive like this.
  12. Mar 30, 2022 at 7:22 PM
    empty_lord
    05 rollover special
    Mark the bolts with paint pens.
    Darkness[OP] likes this.
  13. Mar 30, 2022 at 7:22 PM
    empty_lord
    05 rollover special
    Nein
  14. Mar 31, 2022 at 3:36 PM
    alb1k
    Left Coast
    It's good
    Updated up top today. I'll delete this post later
    Casper421 and 5N0W808 like this.
  15. Mar 31, 2022 at 11:07 PM
    alb1k
    Left Coast
    It's good
    I'm not promising anything. :anonymous:. Just sharing what I have learned or been told. @Casper421 may be able to say for sure at some point. But, pinch weld work at a minimum on 35's. And based on some feedback here, makes sense what they said about 05-06 DC.
  16. Mar 31, 2022 at 11:17 PM
    empty_lord
    05 rollover special
    I’m running 33s without a pinch weld mod or anything. Hell I still have front mud flaps (yes in the weird guy that likes how they look)
    MD0811, Sunnier and bmf4069 like this.
  17. Mar 31, 2022 at 11:17 PM
    Casper421
    In the woods
    06 DC
    Solo said only trimming and cutting the fender. He didn’t mention anything about the pinch weld but like you said, that’s a given so I didn’t ask. I’ll know in 2 weeks.
    5N0W808[QUOTED] likes this.
  18. Mar 31, 2022 at 11:19 PM
    alb1k
    Left Coast
    It's good
    35's. I did not get the offset, tire or wheel width. But I got this.
    Call us at (626) 966-7656 to get more information.
  19. Mar 31, 2022 at 11:27 PM
    #49
    alb1k
    Left Coast
    It's good
    Before I go to bed, you mighta walked into that; I didn't bold, just cut and pasted. And I know I'm dry at times. Weird humor of mine.
    5N0W808 likes this.
  20. Mar 31, 2022 at 11:36 PM
    #50
    empty_lord
    05 rollover special
    Skinny 33s. I’m not a fan of wider for my use case. Aired down I have enough footprint to get me where I want
  21. Apr 1, 2022 at 5:09 AM
    #51
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    There's a reason I bought OEM rear flaps from @shifty` and put em in my box.
  22. Apr 1, 2022 at 8:37 AM
    #52
    alb1k
    Left Coast
    It's good
    I've been looking at tiresize.com a lot and I think the 285/75/17 is right for me. 33.8" T 11.2" W for a 7.5-9.5 wheel. Which looks like a skinny 33 to me. But it's about 1.5" taller that what I'm on.
    5N0W808 and Darkness[OP] like this.
  23. Apr 1, 2022 at 1:49 PM
    #53
    Casper421
    In the woods
    06 DC
    Ive been on 285/75r17’s for 3 years. You won’t have a problem with the solo arms! Maybe a little pinch weld love!
  24. Apr 1, 2022 at 2:37 PM
    #54
    empty_lord
    05 rollover special
    I’m running 255/80r17
  25. Apr 1, 2022 at 2:40 PM
    #55
    alb1k
    Left Coast
    It's good
    10" wide vs. 11.2"
    You got the skinny.
  26. Apr 1, 2022 at 2:53 PM
    #56
    FrenchToasty
    Mo
    Bone stock
    Pizza cutters
    Darkness[OP] and alb1k[QUOTED] like this.
  27. Apr 5, 2022 at 8:40 AM
    #57
    Casper421
    In the woods
    06 DC
    Just a heads up but Solo is almost done powdercoating some big ball joint lca’s and might have a set available if anyone is interested. @FrenchToasty @des2mtn
    5N0W808, des2mtn and FrenchToasty like this.
  28. Apr 5, 2022 at 8:49 AM
    #58
    FrenchToasty
    Mo
    Bone stock
    shifty` and Darkness[OP] like this.
  29. Apr 7, 2022 at 8:46 PM
    #59
    alb1k
    Left Coast
    It's good
    I think the 35X12.50 could give me issues without spacers on my wheels. 285/75 seems to give me the best fit least work to get there.
  30. Apr 10, 2022 at 12:07 AM
    #60
    empty_lord
    05 rollover special
    hmmm... sooo tempting
