Solid Offroad custom motormount Group Buy for 2nd & 3rd Gen Tundras
Discussion in 'Deals & Group Buys' started by Bonzen, Sep 9, 2021.
Thread Status:
Not open for further replies.
  1. Sep 13, 2021 at 8:48 PM
    #61
    blackdemon_tt
    blackdemon_tt Battery Slayer
    Just came out the pockets too... Ive been debating on going solid mounts on my SC as well...
    Bonzen[OP] likes this.
  2. Sep 13, 2021 at 8:54 PM
    #62
    Bonzen
    Bonzen [OP] Solid Offroad motor & transmission mounts
    Lake Havasu City, AZ
  3. Sep 14, 2021 at 4:50 AM
    #63
    BlackSheep
    BlackSheep ol’ Reliable
    Scott
    Kansas City, MO
    2010 Black DC 5.7L 4x4
    2.5” shocks, 3/1 level, 37s, 5.29s, air locker, on-board air, bed cap, bed stiffeners, roof rack, steps/sliders, spare carrier, under seat storage bins, window tint
    Yup that’s one of the threads I had referenced. Seems that several of the guys on here who are most well known for pushing the tundra’s off road limits endorse the product, so I’m inclined to trust it, but I was hopeful to hear a response attempting to explain why Toyota built in so much freedom of movement with the OEM mounts.
  4. Sep 14, 2021 at 5:01 AM
    #64
    Harry
    Harry New Member
    Goldsboro, NC
    2008 Tundra 5.7L 4WD RCSB
    Ironman 4x4 Stage 3 Suspension, U-bolt Flip kit, Wheelers Superbumps, TrailToys Rear Bumper, Victory 4x4 front bumper with Ironman 4x4 12k Winch, Wet Okole seat covers, Cali-Raised ditch lights, Kicker Audio, Flowmaster 40 fab exhaust
    Well normally, Stock motormounts are made out of a rubberish material so it absorbs all the vibrations your engine makes for a smoother ride. Results in slight HP&TQ loss. These being pretty stiff should increase wheel HP but will likely make the truck vibrate more. Maybe make more noise.
    https://youtu.be/zL4QaTOG7zQ
    GODZILLA and Terndrerrr like this.
  5. Sep 14, 2021 at 9:46 AM
    #65
    Bonzen
    blackdemon_tt likes this.
  6. Sep 14, 2021 at 9:53 AM
    #66
    BlueCrushSC16
    BlueCrushSC16 New Member
    Charleston, SC
    Well, I guess I'll be dropping my RCI skidplate. Didn't really think about it.
  7. Sep 14, 2021 at 9:55 AM
    #67
    Bonzen
    Lots of threads Ive been apart of on this forum, but the main details are as follows...
    Polyurethane - Ive found that the extra harmonics, if they are noticed at all, only noticeable at idle and its very minimal. Ive never had a customer message me and complain about it. I'm talking over 15+ years of selling these and hundreds sold. An aftermarket exhaust system puts more vibrations and harmonics into the drivers senses IMO. Same with aggressive off road tires. Your aftermarket upper control arms use poly bushings and will add harmonics and squeaking to the drivers senses as well. Ive never felt anything extra in the steering wheel myself and never heard of that from a customer either. Ive had the same amount of customers message me on this forum, and on the Instagram page that the truck actually ran and shifted smoother once the upgraded motor mounts were installed. So its really a personal thing, there is not a fool proof way to judge what every different person would consider NVH. But remember, we are building off road trucks and modifying them away from the engineered plush OE specifications so if you want that, then leave it 100% stock.
    The 2nd gen tundra motor mount failure rate with offroading is pretty high, as is the case with all these OEM toyota motor mounts. 1st gen tundras were just as bad if not worse. The frame perches of the first generation are also prone to cracking and caving in, while the actual frame itself of the 2nd and 3rd gen is more prone to actually bending inwards and requiring frame straightening:eek2: Once that OE cheap rubber puck motor mount breaks or de-laminates, you have nothing holding your engine in place, and the frame rails have effectively lost their side to side support and can start to flex inward and bend.
    I started making custom fabricated drivetrain mounts back in 2003 when we were off road racing in the deserts of SoCal, Nevada and Baja. A solid mounted drivetrain is a standard setup on any off road truck that is raced or used as a prerunner. Running OEM mounts off road in a race would result in a broken race truck immediately and losing the race. Any of you guys that have ran your trucks in the desert know how abusive it can be. Bolting on long travel suspension helps and increases how fast you can go but will only add more stress to the truck because you are now going faster and hitting things harder. As stated, the factory mounts are mostly designed around noise cancellation of any sound that could be felt in the cab, and designed to meet the bare minimum requirements to hold the drivetrain in place on a flat paved road. This is why soft rubber is used. Its a dampener. Unfortunately it dry rots, cracks and de-laminates quickly. It also flexes heavily. This is fine for a factory truck that lives on the street. Or if you drive slow on flat dirt roads, then you will be fine with stock motor mounts for a while.
    I make parts for trucks that are used off road. Driven hard, fast, bounced around, jumped, raced, rockcrawling, over-landing in rough terrain, etc. Thinking your OEM mounts will keep your drivetrain held securely while doing that is a recipe for disaster. But theres more to it than just preventing frame and engine bay damage...there is a throttle response/power factor too. So all our motors will torque to the right (passenger side) when we accelerate. This is the rotating mass of the motor attempting to lift itself off the frame from the power it produces. Doing this over and over isn't necessarily bad, if this is occurring on the flat street. The only thing you'll have to worry about is the slow deterioration of the motor mount rubber over time. Just like any part it will eventually wear out. However, doing this over un-even, rugged, tooth rattling unpredictable terrain is a different story. Doing it at high speed is another story. Now you have the drivetrain trying to twist off the chassis, and the whole truck being tossed around, shaken, vibrated and possibly taking impacts that send shock through the vehicle. Any axle wrap and moments of traction loss from the tires leaving the ground is exacerbated by this as well. Basically, you are experiencing a decent degree of parasitic power loss thru your drivetrain as lost energy that isn't making it to the ground. So you are not "making more power" with upgraded drivetrain mounts, but you are losing less power and making more efficient use of the applicable power on hand produced at the flywheel. The weak stock OEM mount failing to hold everything tight and secure, will allow the engine to become a 400 - 600 lb slide hammer beating the frame into submission while at speed. The more the drivetrain flexes and rebounds, the more damage is going to occur.
    Polyurethane upgraded motor mounts put zero extra stress on a drivetrain. In fact, holding it tight and stopping all the flex actually helps keep things from breaking, such as stopping excess force that is applied against your pinion bearings from the driveshaft as it sends shockload force thru it from all the drivetrain flex and rebounding while offroad. Also, the driveshaft center support bearing (carrier bearing) will receive much less wear and tear if the driveline is spinning true and flexing all over less. Poly mounts are just all around a positive upgrade.
    Are you guys blind yet? lol. I am from typing all this. Hope it clears some things up as to why this is such a crucial upgrade for any truck used off road, or even heavy towing with lots of force applied against the drive line.
  8. Sep 14, 2021 at 10:18 AM
    #68
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Bonzen[QUOTED][OP] and 831Tun like this.
  9. Sep 14, 2021 at 1:11 PM
    #69
    Bonzen
    Peeeheeuuu likes this.
  10. Sep 14, 2021 at 1:13 PM
    #70
    Bonzen
    Or you remove the plastic inner fender well liners & take the wheel off and do it from the sides.
    This is exactly what this customer did, but he was also building custom shock hoops so he cut out the coil bucket...obviously pretty extreme but gives you a good visualization.
  11. Sep 14, 2021 at 7:28 PM
    #71
    Bonzen
  12. Sep 17, 2021 at 8:42 AM
    #72
    Bonzen
    Going to end the GB pricing this weekend, so if anyone else wants in on the $420 shipped, send your order in soon, or PM me.
    Other wise they go back up to $500 + shipping next week.
    Picking up the big batch of laser cut kits today, will be starting on welding up these orders next week:muscleflexing:
  13. Sep 21, 2021 at 12:16 PM
    #73
    Bonzen
    2 kits welded up so far, will be shipping this week.
    I am doing my best to build these in the order that I received payment from each perspective forum member. So if you paid early, you will receive your kit sooner. Sounds fair right?
    Appreciate everyone's patience, I am a one man op and all these are custom hand built by me. No outsourced fab or oversees junk:thumbsup:
    Terndrerrr, Peeeheeuuu, TG705 and 8 others like this.
  14. Sep 21, 2021 at 12:30 PM
    #74
    blackdemon_tt
    Waiting patiently
    Bonzen[OP] and Peeeheeuuu like this.
  15. Sep 21, 2021 at 12:40 PM
    #75
    BlackSheep
    Scott
    Kansas City, MO
    This is now on the list of mods I want to do. Don't know what the condition of my OEM mounts is, but if it helps get more power and torque to the wheels, I'm all about it. All my other mods have done the opposite :turtleride:
  16. Sep 21, 2021 at 9:50 PM
    #76
    Diesel_dave
    Diesel_dave New Member
    is this too late to add? i get paid friday lol
  17. Sep 22, 2021 at 7:18 AM
    #77
    Bonzen
    Technically the GB deal was closed on Monday. But I'll make an exception since you're waiting to get paid.
    GODZILLA, BlackSheep and Sundog like this.
  18. Sep 22, 2021 at 6:49 PM
    #78
    18" TRD Off Road Wheels
    Very classy. :thumbsup:
  19. Sep 22, 2021 at 7:11 PM
    #79
    vq35721
    vq35721 New Member
    2011 040 SR5
    Too much to list
    Legit Mounts! Got rid of tons of vibration at idle lol.
  20. Sep 24, 2021 at 8:53 AM
    #80
    Bonzen
    I try to keep it classy, we are all one big off road family!
    GODZILLA[QUOTED] likes this.
  21. Sep 25, 2021 at 8:09 AM
    #81
    SK_Tundra
    SK_Tundra New Member
    Stockton Ca
    2015 Tundra Mall Rated
    Can’t believe I missed this. :frusty:
  22. Sep 25, 2021 at 1:51 PM
    #82
    Bonzen
    Send the $420. I'll add you to the list.
    GODZILLA likes this.
  23. Sep 25, 2021 at 1:51 PM
    #83
    Bonzen
    Unless they are REALLY broke and have started causing damage like your headers are smashing into your coil buckets.
    joonbug[QUOTED] likes this.
  24. Sep 27, 2021 at 12:56 PM
    #84
    Kiddnapped Tundra
    Kiddnapped Tundra New Member
    Grand Island, NY
    2010 Tundra DC
    IMG_20211008_120908353.jpg Mine arrived today.
  25. Sep 27, 2021 at 1:48 PM
    #85
    blackdemon_tt
    We're all extremely jealous, lol.... or am I just speaking for myself... lol
  26. Sep 27, 2021 at 7:47 PM
    #86
    Bonzen
    I'm going full bore on the 5.7 kits this week. I had like 10 sets of 4.0V6 mounts to build and ship out from customer orders before this GB even started.
    Alotta stuff will ship by weeks end:thumbsup:
    SK_Tundra&Diesel_dave I'll still honor the GB pricing if you order this week.
  27. Oct 5, 2021 at 7:59 PM
    #87
    Bonzen
    At least 3-4 more kits shipping this week. Received more kits from my laser cutter today
  28. Oct 9, 2021 at 7:09 PM
    #88
    Peeeheeuuu
    Peeeheeuuu New Member
    Peter
    Elk Grove, CA
    08 Tundra CM 4x4. 21 Sequoia SR5 4wd
    Got my mounts in the mail today. Thanks @Bonzen
    Kiddnapped Tundra likes this.
  29. Oct 9, 2021 at 8:58 PM
    #89
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    Received 2 sets, thanks @Bonzen for running the group buy
  30. Oct 9, 2021 at 11:12 PM
    #90
    blackdemon_tt
    The reds look super nice
Thread Status:
