Solar panel recommendations for EcoFlow Delta 2
Discussion in 'Off-Topic Discussion' started by Tundra234, Oct 26, 2024.
  1. Oct 29, 2024 at 9:35 AM
    Tundra234 [OP] New Member
    I have no idea honestly. This is all new to me. I'm wondering if I'm better off going with the Rich Solar or Renogy. I'm open to suggestions :)
    Mater[QUOTED] likes this.
  2. Oct 29, 2024 at 9:37 AM
    SD Surfer
    Bruce
    So Cal
    If you have the real estate you might consider going with 200W panels, they're not that much bigger and not that much more money.
    Same number of mounting holes but double the power. More panel is the cheapest and easiest way to allow for less than optimum conditions.
    General rule of thumb is 200W of solar for every 100Ah of battery, so my original plan of 400W probably would've been sufficient for my needs, but a little overkill is nice to have and didn't cost much more.
  3. Oct 29, 2024 at 9:39 AM
    SD Surfer
    Bruce
    So Cal
    Probably won't need it, but might as well get a warranty with your panels.
  4. Oct 29, 2024 at 9:43 AM
    I'm looking at at Rich's site now. USA made.....
  5. Oct 29, 2024 at 9:47 AM
    SD Surfer
    Bruce
    So Cal
  6. Oct 29, 2024 at 10:40 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    Pretty cool setup....I was inquiring about how to pass solar cables inside my house. Im using my panels we normally bring camping to charge up my Delta2 & Extra Battery that powers my home server.
    For my travel trailer, i just keep the panels loose and put them out when i need to, i put my charger right next to the storage area so i just keep the flip door open.
  7. Oct 29, 2024 at 10:58 AM
    Danimal86
    Daniel
    Sacramento, CA
  8. Oct 29, 2024 at 11:14 AM
    SD Surfer[QUOTED] likes this.
  9. Oct 29, 2024 at 11:43 AM
    SD Surfer
    Bruce
    So Cal
    Cool!
    You told him specifically the Ecoflow unit you wanted to use them for? Thats' nice being able to actually speak to a human.
  10. Oct 29, 2024 at 11:48 AM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
  11. Oct 29, 2024 at 12:09 PM
    Danimal86
    Daniel
    Sacramento, CA
    i run a 200a bms, works fine for me. What are you trying to power?
    I dont remember seeing him do a teardown, but i'd imagine its similar/same as other budget batteries.
  12. Oct 29, 2024 at 12:20 PM
    Mater
    Mater New Member
    Nick
    SD
    2016 MGM Platinum
    :welder:
  13. Oct 29, 2024 at 1:03 PM
    Yes.
  14. Oct 29, 2024 at 3:21 PM
    Danimal86
    Daniel
    Sacramento, CA
    ohhhhhhhhhhhhhhhhhhhhhhhhhhh
    yeah, might need a little more chooch!
  15. Nov 19, 2024 at 6:33 AM
    So my setup is up and running. Thanks @Mater for all of the assistance. :hattip:
    EcoFlow Delta 2 powering the Davis Air Dryer at 130 watts
    Renogy panels 200 watts each wired in parallel
    Renogy 40 amp inline fuse (ANL)
    MC4 to XT60I adapter cable to connect directly to the EcoFlow. The EcoFlow has a built in MPPT controller.
    Mater likes this.
