SoCal Shennanigans Thomas Mountain Road Trail Run
Discussion in 'California' started by nishibot, May 26, 2019.
What do we want to do for food?
Poll closed Jun 11, 2019.
  1. Drive to Idlewild Pizza Company (aprox. 15 miles)(Delicious pizza)
    100.0%
  2. Pot Luck
    0 vote(s)
    0.0%
  3. Paradise Cafe (A little pricey for what you get but good food)
    0 vote(s)
    0.0%
  4. Drive back down to Red Hawk area
    0 vote(s)
    0.0%
  1. May 27, 2019 at 10:56 PM
    #91
    Sunnier
    Sunny
    San Diego, CA
    Makes sense!
    SoCalPaul[QUOTED] likes this.
  2. May 27, 2019 at 11:01 PM
    #92
    SoCalPaul
    SoCalPaul New Member
    Paul
    San Fernando Valley, CA
    2006 Tundra Access Cab Limited 4wd.
    Front Bilstein 6112 shocks & Bilstein springs. Rear Bilstein 5160 remote Reservoir shocks, Wheeler’s Off-road add-a-leafs. LED lighting. Pioneer Avic 7200NEX Nav Head unit. Borla cat back exhaust.
    When buying any compressor, the most important number is usually air flow in CFM (cubic feet / min.) the higher the airflow, the faster you’ll fill your tires. The compressor I bought claims 70 liters per min or 2.5 CFM. The inexpensive VIar 77P is rated at 1 CFM. Just an FYI. But of course any compressor is better then none when you need it.
    Bigboitundra and Sunnier like this.
  3. May 27, 2019 at 11:03 PM
    #93
    nishibot
    nishibot [OP] Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    Good point as well
  4. May 27, 2019 at 11:04 PM
    #94
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    2019 Tundra CM Super White
    wheels/tires suspension protection
    Lol. San Fernando Valley...
  5. May 27, 2019 at 11:09 PM
    #95
    SoCalPaul
    Paul
    Ok, I just checked and my 12 volt outlets are rated for 120 watts max. That's about 10 Amps. Your portable compressor is likely pulling 15-20 amps. That's why it's getting so hot. I'd hate to see the wires behind the dash.
  6. May 27, 2019 at 11:09 PM
    #96
    nishibot
    Perris, CA.
    That's going to be a tight window. You do realize where this run is?
    Pinay likes this.
  7. May 28, 2019 at 8:03 AM
    #97
    Sunnier
    Sunny
    San Diego, CA
    I woke up thinking about this stuff.
    You're a good human, Francis! :fistbump:
    I do!
    I kinda learned the info about 'duty cycle' last year when we worked through this in the Shenanigans thread, but I didn't (don't) really understand amps. I appreciate what @SoCalPaul shared about amp draw from a cig lighter; Eeeek!, now I'm afraid to look behind my dash... but more afraid to use my compressor again. If I'm reading the specs right, the one I have draws... 25 amps?!! :eek2:
    https://www.amazon.com/dp/B00CDW2MCM
    THIS ONE ^ SoCalPaul bought reads like it also draws 25 amps!?!! :eek:
    So now I guess I'll start wading through reviews and specs. Sure are a lot more options than there were last year. And, anyway, not much is more entertaining than reading information translated from Chinese to English by an algorithm bot! ;)
    eccracer104, BestGen and Pinay like this.
  8. May 28, 2019 at 8:07 AM
    #98
    nishibot
    Perris, CA.
    Just get the extension that connects to the battery to be safe
    Pinay and Sunnier[QUOTED] like this.
  9. May 28, 2019 at 8:40 AM
    #99
    Macreggg
    Macreggg TRD No
    Mel
    Los Angeles, CA
    Yes I do. So it really depends on the time.
    We have a house we can stay at in Idylwild as well Friday night to make it easier.
    nishibot[QUOTED][OP] likes this.
  10. May 28, 2019 at 8:46 AM
    #100
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    I got this one, was looking at it before @JDL17CM4x4 said he got the same one...you plug into your battery and run the engine and air up. Haven't tried yet, but I think I will practice before the next trail.
    https://www.amazon.com/gp/product/B000X9AXR8/ref=ppx_yo_dt_b_asin_title_o05_s00?ie=UTF8&psc=1
    JDL17CM4x4 and Sunnier[QUOTED] like this.
  11. May 28, 2019 at 8:49 AM
    #101
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Why did U go twin instead of single? Just curious
  12. May 28, 2019 at 8:59 AM
    #102
    Sunnier
    Sunny
    San Diego, CA
    :muscleflexing:
    JDL17CM4x4 and Pinay like this.
  13. May 28, 2019 at 9:13 AM
    #103
    nlaroy
    nlaroy New Member
    Nick
    So Cal
    2017 Inferno Crewmax
    LED bulbs, RCI Underwear, WKOR Sliders, Fox 2.5 w/ resi Front and back, Deaver leaf springs,
    Just wondering... Couldn't a person just a get a portable Air tank, Fill it at home with my own compressor, and use that for my trips. Doesn't help when i run out... but i wouldn't have to pay for a CO2 refill. Just curious :)
    Pinay likes this.
  14. May 28, 2019 at 9:16 AM
    #104
    Porschetech29
    Porschetech29 New Member
    Francis
    Rancho Cucamonga, CA
    2008 white double cab 4x4
    I don’t think you would have enough air volume in a 5 gallon portable air tank to air up all 4 tires especially when you upsize the tire and run a smaller diameter wheel.
    joonbug, Sunnier and Pinay like this.
  15. May 28, 2019 at 9:33 AM
    #105
    nlaroy
    nlaroy New Member
    Nick
    So Cal
    Gotcha
  16. May 28, 2019 at 9:37 AM
    #106
    nishibot
    Perris, CA.
    100% duty cycle..... Also got it when there was a group buy :spending:
    sdde4n likes this.
  17. May 28, 2019 at 9:40 AM
    #107
    nishibot
    Perris, CA.
    OK I just wanted to make sure :thumbsup:
  18. May 28, 2019 at 10:16 AM
    #108
    SoCalPaul
    Paul
    The Viair 77P you posted says 15 amps max draw, 50% above the 12 Volt outlet rating. The one I posted says 25 amps max draw - Don't use it in a cigarette lighter or standard 12 volt outlet.
  19. May 28, 2019 at 10:19 AM
    #109
    SoCalPaul
    Paul
    A twin will generally have twice the airflow of a single.
  20. May 28, 2019 at 1:30 PM
    #110
    KevinK
    KevinK SGU - High Speed Overlander
    Back in Arizona. Again.
    SGU - Speed Glampers Uberfahrt
    Tundras to Sedona
    It takes me longer to explain it in this video than it does to actually air up. Maybe someday I’ll time myself, but I’d guess it’s about 7 minutes from the time the wheels stop rolling to the time we’re driving away. All 4 37s from 20 psi to 37.
    https://youtu.be/IOOpyP76UOY
    joonbug and JDL17CM4x4 like this.
  21. May 28, 2019 at 2:06 PM
    #111
    JDL17CM4x4
    JDL17CM4x4 Adventure Mobile
    Daniel
    Riverside, CA
    2017 White Tundra TRD 4x4
    More to Come ...
    @nishibot mark me down for now as maybe. My calendar does not show anything but need to confirm with Ashlynn.
    Anyone camping at any of these Yellow Post spots that night?
    Sunnier likes this.
  22. May 28, 2019 at 2:14 PM
    #112
    nishibot
    Perris, CA.
    Added
    Probably no one camping due to Father's Day on the 16th. Those yellow post are all awesome spots though!
    nlaroy and JDL17CM4x4[QUOTED] like this.
  23. May 28, 2019 at 2:24 PM
    #113
    CaptSpaulding
    CaptSpaulding ...ain't nothin but nothin
    Jake
    2010 White DC 4x4
    May I join the club? I'm 95.5% sure I can make this run
    nlaroy, Sunnier, Pinay and 2 others like this.
  24. May 28, 2019 at 2:49 PM
    #114
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    :facepalm:It only took you 87.4 years to respond! :boink:
  25. May 28, 2019 at 2:54 PM
    #115
    nishibot
    Perris, CA.
    Added
    Pinay and CaptSpaulding[QUOTED] like this.
  26. May 28, 2019 at 3:02 PM
    #116
    CaptSpaulding
    Jake
    2010 White DC 4x4
    I was trying to build suspense!
  27. May 28, 2019 at 3:03 PM
    #117
    nishibot
    Perris, CA.
    You get your truck fixed?
    CaptSpaulding[QUOTED] and Pinay like this.
  28. May 28, 2019 at 3:09 PM
    #118
    CaptSpaulding
    Jake
    2010 White DC 4x4
    Not yet. I'm gathering parts before I dig in. So most likely 2wd for this run, I'll take lots of photos of everyone and maybe a few 1 armed Hoonigan sideways slides. I need a Kibbetech handbrake....wait, that would take 2 hands to operate :crazy:
    Pinay and Marty McFly like this.
  29. May 28, 2019 at 3:30 PM
    #119
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    The suspense is if you show up in clown makeup :rofl:
    Marty McFly likes this.
  30. May 28, 2019 at 5:12 PM
    #120
    Jackjack
    Jackjack New Member
    Jack
    White tundra
    Definitely a great time! Like the camping spots on Thomas Mountain for sure.
    Sunnier, Pinay and Marty McFly like this.
