SoCal '18 Cement Build
Discussion in '2.5 Gen Builds (2014-2021)' started by DividedSky, Apr 30, 2018.
  1. Jul 12, 2018 at 3:40 PM
    DividedSky
    DividedSky [OP] New Member
    Jeff
    '18 Crewmax - ADS Mid Travel
    ADS 2.5's (rear bypass) U748 Leaf Springs
    LOL..... I just noticed that we are ALSO both rockin a Tan RTIC cooler in the back!!
    I have the 65 in Tan and a new 110 in Blue. I keep it locked up using a master lock Python
    https://www.amazon.com/Master-Lock-...pID=51pS9bbVgoL&preST=_SY300_QL70_&dpSrc=srch
    GiantsFanDan[QUOTED] likes this.
  2. Sep 28, 2018 at 9:13 AM
    sdde4n
    sdde4n New Member
    People's Republic of California
    2018 CrewMax - Sierra Romeo Cinco
    Heavy, unnecessary offroad stuff.
    Dude, I have a very similar starting point ('18 SR5 cement CM) so I'm watching this for sure. Love the MT setup. I'm curious, what makes a suspension MT vs. LT?
  3. Oct 30, 2018 at 2:18 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Ok tell me about your front emblem. Is it a replacement that you found that keeps the sensor behind or is it a sticker/decal over the top of the stock one?
  4. Oct 31, 2018 at 2:57 PM
    DividedSky
    Jeff
    I'm a professional drinker sponsored by Stone!
    :drunk:
    It's just a sticker... It was originally a LARGE 9x14in sticker and I just used an exacto knife to trim it to size, then I put a very thin bead of black silicone around the edges to keep it from peeling. Has held up well for the 6mo I've owned the vehicle.
    csuviper likes this.
  5. Oct 31, 2018 at 2:59 PM
    csuviper
    Broomfield, CO
    Nice. I might look at a vinyl something to add.
  6. Oct 31, 2018 at 3:01 PM
    DividedSky
    Jeff
    Sorry for the late reply.
    MT is anything that keeps the stock lower control arm but uses an extended travel shock to get a few extra inches up front and added travel in back from new leaf-springs (Spring over axle)
    LT is new lower and upper control arms in front (with wider stance) and Spring under axle in back (most with shocks that go through the bottom of the truck bed)
  7. Oct 31, 2018 at 3:02 PM
    DividedSky
    Jeff
    Had ZERO effect on my TSS stuff
  8. Oct 31, 2018 at 7:48 PM
    Pigglet222
    Pigglet222 New Member
    Does this affect the airbag when needed?
  9. Nov 1, 2018 at 9:09 AM
    DividedSky
    Jeff
    It shouldn't... The Sequoia has an airbag in the same exact position and it works for them. This is a Sequoia handle after all.
  10. Dec 23, 2018 at 6:44 PM
    Offaxis2015
    Offaxis2015 New Member
    Shawn
    2018 cement crewmax TRD
    Color match hood bulge and surround grill more to come
    Did you get the one gallon kit?
    I wanna do front bumper end caps only just wondering if I can get tintable in less than a gallon
  11. Jan 2, 2019 at 11:26 AM
    DividedSky
    Jeff
    I only needed the Quart size and it was enough for both the front bumper ends AND the grill surround plus a little left over (prob enough for a rear bumper if needed)
    Offaxis2015 likes this.
  12. Jan 28, 2019 at 3:22 PM
    TheBeast The Beach
    I see they have .180 DOM. overkill you think ?
  13. Jan 28, 2019 at 3:52 PM
    DividedSky
    Jeff
    @osidepunker has the .188 and he swears by them. In retrospect, I probably would have gone with .188, but still happy with my .120
    osidepunker and TheBeast like this.
  14. Jan 28, 2019 at 4:09 PM
    TheBeast The Beach
    I'm in SoCal, do they do installs if you go to their shop ?
  15. Jan 29, 2019 at 4:04 AM
    osidepunker
    osidepunker OsidePunker
    Alex
    2013 Tundra DC 4x4
    Full LT, full armor, fully self contained Speed Glamper
    ask him!
  16. Jan 29, 2019 at 7:39 AM
    atl1glf
    atl1glf New Member
    ‘07 SR5 CM, ‘12 SR5 DC Supercharged, ‘19 Limited CM
    Too many TRD parts
    Very nice build.
  17. Jan 29, 2019 at 8:32 AM
    TheBeast The Beach
    I did. They don't but recommended a shop close by. How do you like your 0.188 ? bombproof ?
  18. Jan 29, 2019 at 8:39 AM
    osidepunker
    Alex
    2013 Tundra DC 4x4
    Super bomb proof. I take mega hits and they don't dent. My bumper is 120 wall dom and it dents fairly easily
    Install isn't hard, just tedious
    TheBeast[QUOTED] likes this.
  19. Jan 29, 2019 at 8:43 AM
    #49
    TheBeast The Beach
    sounds good to me. :thumbsup:
    osidepunker likes this.
  20. Jan 29, 2019 at 7:49 PM
    #50
    TRD_femi
    TRD_femi New Member
    2015 TRD Pro
    Well done!
  21. Feb 5, 2019 at 2:11 PM
    #51
    DividedSky
    Jeff
    Have a few updates to share!!
    Went out to Anza Borrego a few weeks ago. Ran Diablo Drop-off to Split Mountain, camped and then Ocotillo Wells OHV South to North to the Pumpkin Patch the next day. Here are some shots including my new set of skids!!
    Here are some close-up shots of the skid plates... I actually did a combo of P&P and RCI.
    I went with P&p for the front Engine skids because they are a little thicker/beefier than RCI. The mounting holes were slightly off, but I was able to get them to match up with a small amount of dremel/file work.
    P&P at the Pumpkin Patch!!
    Behind that, I went with RCI for the Transmission/transfercase. RCI sells it as a single unit that I got for about the same price as just the P&P transmission (Black Friday sale). Happy to report that the two brands play very nicely with each other. Only thing I had to do was make the front RCI bolt holes slightly bigger because P&P uses beefier hardware than RCI.
    So overall, I'm not sure which brand I think is "better". P&P is definitely beefier than RCI, but I was a little miffed that their bolt holes were not exactly correct. RCI was spot-on with the bolt holes, they are less $$ and they came pre powder-coated. They just are not quite as robust. I figured that most hard impacts would be to the front skid, so the beef was more important up there. Saved a few bucks (and weight) with RCI for further back.
    vanthesupreme likes this.
  22. Feb 5, 2019 at 2:13 PM
    #52
    TheGreyTundra28
    TheGreyTundra28 New Member
    2018 Grey Tundra Sport
    Dirty Deeds 10 budget exhaust, Roof rack, 52" windshield, Truxedo Tonneau, and Line x Bedliner
    SICK build. I like the container idea.
  23. Feb 5, 2019 at 2:18 PM
    #53
    DividedSky
    Jeff
    Oh, the other thing that was interesting with P&P was that they no longer use any spacer tubes on the front skid (like they apparently used to do from pics on this site, and as they do w/ the TRD Pro front skid). It may be ghetto but I counter-sunk a pressure treated piece of 4x4 and bolted it in there where the spacer tubes would have gone. I figure that if I can safely lift my truck on the floor jack with a 4x4 wood spacer/extension, then it will at least take a few hard impacts up on the front skid as well. I painted it up w/ enamel to keep it from getting saturated with water and let it last a bit longer. Long term goal is to have my friend w/ a machine shop make me a custom spacer "block".
  24. Feb 5, 2019 at 2:20 PM
    #54
    DividedSky
    Jeff
    Was slightly confused at first but I assume you mean the under seat storage...
    THANKS!!
  25. Feb 5, 2019 at 2:29 PM
    #55
    DividedSky
    Jeff
    Oh, and I forgot to add that I finally got the rig some new rubber!!
    I originally bought these rims with some worn down (stock size) KO2s. Ran those down to about 10% tread and then put on some 295/70r18 COOPER STT PRO's.
    BEEFCAKE!!!
    Super traction, and I loved watching them deform the sidewalls on some of the crawling sections that we encountered. I would have been freakin out about getting a flat w/ my old tires. These handled it like a champ!
    Bigboitundra and osidepunker like this.
  26. Feb 11, 2019 at 2:27 PM
    #56
    DividedSky
    Jeff
    I was browsing CraigsList the other day and found a deal that I couldn't resist!!
    BAMF bed rack with Rhino Lining complete with dual Rotopax mounts, quick-fist mounts AND an ARB 2500 awning. All for $300 (at least that's what I told the wife!!!)
    While the rack is in AWESOME shape, the one thing I was slightly disappointed about was that the accessory pieces (roto mount plate, Awning arms) were bed-lined while installed, not separately. Oh well... at least I can still fit into the parking garage at work!!
  27. Feb 11, 2019 at 2:34 PM
    #57
    DividedSky
    Jeff
    Oh... and for those noticing the stock wheels, since the truck is also my DD I didn't want to run pavement on expensive off-road tires, so I kept my stock wheels and I change them out with the Vision/Cooper set when I want to go wheel. I have the process down-pat now and can change all 4 in about a half hour. I use an impact driver, but I do all the final tightening by hand. I also enlist my 8yr old son to hand me things as needed.
    Scalpel.... Scalpel
    Sutures.... Sutures
    Wipe.... Wipe
    BEER... BEER!!
    sdde4n and Erichudgins like this.
  28. Mar 2, 2019 at 3:41 AM
    #58
    Vegeta7
    Vegeta7 New Member
    2019 Tundra SR5 Crewcab 4X4
    Where did you buy the driver grab handle?
  29. Mar 18, 2019 at 11:47 AM
    #59
    DividedSky
    Jeff
    Sparks Toyota
  30. Mar 18, 2019 at 11:49 AM
    #60
    DividedSky
    Jeff
    Another quick update:
    Decided to add some Matte Black vinyl to my hood. I'll swear that it was to reduce glare, but in truth it is 100% cosmetic.
    IT REDUCES GLARE!!!
    Bigboitundra and GodlessPro like this.
