So You Want To Do Your Manifolds DO You?
Discussion in '1st Gen Tundras (2000-2006)' started by 04 Tundra, May 2, 2020.
  1. May 7, 2021 at 5:12 AM
    #61
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Looking at pictures looks like the top of the studs are squared off for wrenching. Probably the highly sought after 10MM :rofl:
    Having never done this job, I'd try that first and vice grips as last resort.
  2. May 7, 2021 at 5:46 AM
    #62
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    The end of the OEM studs is inverted torx, and an E-torx socket is what you want, makes removing and installing the studs a breeze with no thread damage. I can’t recall the size, but if you have new studs already you can use one to match it up.
  3. May 7, 2021 at 5:54 AM
    #63
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    I’d rather only replace the nuts, not the nuts and the studs.
    Also the nut is already grabbing the stud, it’s a pinch nut, so your basically praying to Ala that only the nut comes off.
    Darkness and FirstGenVol like this.
  4. May 7, 2021 at 6:54 AM
    #64
    Jack McCarthy
    Jack McCarthy Happy hour; beer goggles, not a fake profile.
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I would attempt this job under 3 conditions:
    1. Alternate transportation on standby
    2. AAA+ member enrollment for free tow within 100 miles
    3. MiG welder and spare nuts on standby
    Also for access to nuts/studs on drivers side, I would just cut off the manifold with an angle grinder first after removing the shield.
    Good luck, keep us posted PHM!
  5. May 7, 2021 at 7:20 AM
    #65
    DSTundra
    DSTundra New Member
    Dave
    Albuquerque, NM
    2017 Tundra Platinum
    I did mine on my 2001 Tundra back in 2005, so it was only 4 years old at the time and I didn't have to deal with the rust issues. I don't remember the job being particularly bad though. The headers were way less involved than when I changed the timing belt, idler pulleys, tensioner, water pump, cam seals, hoses, thermostat, etc. I did the driver's side first to get the crappy side out of the way. The passenger side was really easy. One more thing...the OEM gaskets are pretty nice and can be reused. I reused them in 2005 and they were still going strong when the truck was totaled in 2016.
    Dave
  6. May 7, 2021 at 8:40 AM
    #66
    Professional Hand Model
    Hand Protectors
    Yeah. I’ll send up a few Ali Babbas when I get into it.
    A1 Auto Vid shows most all the Studs came off with the Nuts. Seems like thats how 04 Tundra job went (50/50) but he would have preferred both to come off simultaneously.
  7. May 7, 2021 at 8:45 AM
    #67
    Hand Protectors
    Thank you. I purchased/received the E10 Socket the other day. It just looks like the rusty ends of the old won’t take kindly to a new socket which I got for the put back. I think I’ll stick with the Double Nut Back Out method per 04 Tundra. See his first post. If the E10 works I’ll use that.
    Basically, I learned to keep ALL your options open on this particular job so I over ordered tools/extentions/wobbles/extractors/ etc.
    N84434, bmf4069 and landphil[QUOTED] like this.
  8. May 7, 2021 at 9:59 AM
    #68
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I think you’ll be OK using the socket to remove the studs too, as required. The hardware shown in your photo looks to be less corroded than both of the ones I tackled, and they all came out easily with the socket, if not together with the locknut. But there’s only one way to know for sure... Get after it already!! LOL
  9. May 7, 2021 at 10:04 AM
    #69
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    You'll be surprised with how easily the studs might come out of the block. Mine, which I fully expected to be frozen, backed right out with very little resistance. Keep in mind that's on a 20 year old northern climate engine too!
  10. May 7, 2021 at 10:06 AM
    #70
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I did use little Vise Grips on one of them, IIR... Can't quite remember though.
  11. May 7, 2021 at 1:59 PM
    #71
    Jack McCarthy
    Bill
    North of Boston
    When I look at a lot of the pics here and videos online it looks like most of the rust seizing is the nut to the stud and the stud to the manifold itself and not the block. Seems like the logical thing to do is just break the rust bond to the hole in the manifold the stud passes through. I would imagine a torch and some penetrant would be the best route being careful not to apply it on the nut before cranking it off with the impact gun.
  12. May 7, 2021 at 3:45 PM
    #72
    Hand Protectors
    Alright boyz. Headers came in this afternoon. Without removing everything, I tried a Dry Fit down on both sides to semi-pre-game the Mojo. Will these JBAs fit down from the topside of the engine? Seems like it might be tight but not sure until the hoses and other shtuff are removed.
  13. May 7, 2021 at 4:02 PM
    #73
    FrenchToasty
    Mo
    Bone stock
    Fancy!
    I sent both mine from the under carriage, but shorties might fit from above
  14. May 7, 2021 at 4:07 PM
    #74
    Hand Protectors
    I hope. These seem pretty good quality for the most part. The finish is real nice. They could use some Shweetness FrenchToasty Porting on some areas that look a little wobbly. What your recco’d porting tool bit of choice for a high speed drill 3/8” electric drill?
  15. May 7, 2021 at 4:20 PM
    #75
    FrenchToasty
    Mo
    Bone stock
    The all metal bullnose type one works real good for lots of material to remove, and the pink one was nice for clean up and hard to reach places. These are for a 1/4 shank hi speed die grinder
  16. May 7, 2021 at 4:51 PM
    #76
    FrenchToasty
    Mo
    Bone stock
    Also peep the collector merger for clingons and coat tailers.
  17. May 7, 2021 at 4:53 PM
    #77
    Hand Protectors
    Yeah. There is a rim lip up in there. I’d like to grind that part off.
    Darkness likes this.
  18. May 7, 2021 at 4:59 PM
    #78
    FrenchToasty
    Mo
    Bone stock
    I was just looking, that curve after the collector might prove dicey to put the die grinder in. But if you’ve got time and small files, get at it. I had asked my buddy to take care of those before he welded the reducer cone on but he didn’t, so it was much more difficult after to make safe progress on those lips and burrs. Again they should be fine, but I know you can’t leave anything alone either.
  19. May 7, 2021 at 5:05 PM
    #79
    Hand Protectors
    I’ll think about it all and figure it out.
  20. May 8, 2021 at 4:32 AM
    #80
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I installed mine from under the engine. Now, keep in mind I had jacked the engine up as I was replacing the mounts, so I had more room to work from under, and things were tighter on top.
  21. May 8, 2021 at 4:33 AM
    #81
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Those are good lookin pipes, btw... I think you'll really enjoy 'em. Full throttle accelerations sound so much better with the headers installed!
  22. May 8, 2021 at 5:29 AM
    #82
    Hand Protectors
    Thanks. I started Pondering your jack the engine technique and how it opened a few angles after the looking at things. I’m feeling Mission Creep already. :annoyed::rofl:
    Darkness, bmf4069 and N84434[QUOTED] like this.
  23. May 8, 2021 at 5:40 AM
    #83
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I think it was Zig Ziglar that said "Do it right the first time!"
  24. May 8, 2021 at 5:49 AM
    #84
    Hand Protectors
    That is ALWAYS my aim. Takes longer to do it twice than to do it right the first time.
    bmf4069 likes this.
  25. May 8, 2021 at 6:26 AM
    #85
    bmf4069
    bmf4069 Captain wtf
    Beau
    TX
    02 AC sr5 4wd v8
  26. May 8, 2021 at 10:56 AM
    #86
    2006Tundra
    2006Tundra Financially Irresponsible
    Lou
    Long Beach, CA
    2006 Toyota Tundra Double Cab SR5, 4.7L V8
  27. May 8, 2021 at 10:57 AM
    #87
    FrenchToasty
    Mo
    Bone stock
  28. May 9, 2021 at 5:58 PM
    #88
    Hand Protectors
    Reached into my Hand Bag and grabbed my Dremel. Works great! Ported the intakes for smoovvv flows. Had a little slippy doo on the one port but she’ll be alright. Things are coming together nicely. Cut the New Gaskets out of the Remflex DIY Kit.
    2006Tundra, Darkness, bmf4069 and 3 others like this.
  29. May 9, 2021 at 6:48 PM
    #89
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Lookin good louis!
  30. May 13, 2021 at 4:40 PM
    #90
    Hand Protectors
    Spent about 8 hours installing the Pass Side Header. Used every Hand Move in the Arsenal. Started her up and no leaks! This Job is no joke. Every level intensifies into the next one. Never lets up until you finish putting the Splash Guards back on.
    Lil Steve, Mustanley, bmf4069 and 7 others like this.
