So which wheels look better?
Discussion in 'Wheels & Tires' started by Badknees, Mar 12, 2021.
Which wheel looks best
Poll closed Mar 19, 2021.
  1. TRD OR 18"
    8 vote(s)
    20.5%
  2. TRD Pro BBS 18"
    31 vote(s)
    79.5%
  1. Mar 18, 2021 at 12:21 PM
    Badknees
    Badknees [OP] New Member
    South Carolina
    2016 White Tundra 1794 CM 4X4
    TRD Pro BBS Wheels, TRD LED Headlights, Rigid LED Fog lights, 040 TRD Grille, 040 Hood Bulge, Black Center Valence, Driver's Grab Handle, TRD Pro Fox Suspension, 1.00" BORA Wheel Spacers, 1.5" Rear Shackles, TRD Front and Rear Sway bars, 295/70 R18 Cooper Discoverer AT3 XLTs, Full Size Spare, TRD Dual Exhaust, Console cover, Console Organizer, Husky Liner X-act Contours, Tinted Front Windows, Stubby Antenna, Autoventshade Deflectors, Duplicolor Painted Calipers, 040 Painted Front End Caps, Undercover Armor Flex Bed Cover
    Done..
  2. Mar 18, 2021 at 12:28 PM
    AZBoatHauler
    So.Arizona
    Looks great!
    Badknees[QUOTED][OP] likes this.
  3. Mar 18, 2021 at 12:32 PM
    Badknees
    South Carolina
    Tanks-a-bunch!
  4. Mar 18, 2021 at 12:36 PM
    17TundraDCEd
    17TundraDCEd New Member
    Ed
    SE Pa
    2018 White SR5 Crewmax
    Rear Sway Bar
    I prefer the TRD OR wheels - I like the contrast (like a previous poster stated) - but the all black PRO wheels look good too. Both are good choices.
    Badknees[OP] likes this.
  5. Mar 18, 2021 at 12:43 PM
    Badknees
    South Carolina
    Many Thanks for the comments. The shine on the OR wheels certainly stands out as the all black wheels have a tendency to get "lost" a bit in the black wheel wells...especially on the white trucks. So far the voting is exactly 80/20 in favor of the BBS Pros...a little wider margin than I expected.
  6. Mar 22, 2021 at 6:30 AM
    Badknees
    South Carolina
    Done...
    First with Bumpershellz, which I didn't like and then removed.
    Then I changed to OEM style end caps:
  7. Mar 22, 2021 at 7:05 AM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Looks awesome.
    How was the OEM install? You have to take the entire bumper assembly off for that?
  8. Mar 22, 2021 at 7:31 AM
    Badknees
    South Carolina
    Actually, I've done it both ways. Long story, but I bought the OEM style caps and had them painted 040 some months ago. I was changing the valence too, so I removed the valence and the caps while still in place on the bumper. THIS WAS A MISTAKE and a total PITA to reach the small nuts that hold the cap and valence together. I thought the OEM cap color was too bright vs. other parts, so I removed and put the chrome ones back on. I then found out about the Bumpershellz and thought this was a better idea and maybe not as bright. I was wrong about the color and they looked to be a bit brighter white than my OEM set. Also, I didn't like that the fog light bezels were hidden by the cut-outs. Then, I went back and reinstalled the OEM style caps, but removed the complete valence/cap assy. this time. Still a lot of work, but easier than installing in place. Next, I'll replace the small front plastic panels above the caps with new painted ones as they look a little yellowed (5 year old truck) and I think this is where most of my color match problems are most visible...one has some damage anyhow. Like many on this site, I have an OCD!
  9. Mar 24, 2021 at 6:08 PM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    Hey brother, do you think it would be possible to install fog light on top of bumpershellz cap? So you could see bezels?
  10. Mar 25, 2021 at 3:57 AM
    Badknees
    South Carolina
    Unfortunately, no. That won't work. The Bumpershellz don't recess back into the fog light housing area and are flush with the face of the cap. They basically have a cut-out for the fog light. Doesn't look too bad. I just like seeing the full bezel that is factory stock.
  11. Mar 25, 2021 at 8:22 AM
    14CRWMX
    14CRWMX New Member
    Tampa Bay
    2014 SR5
    That is a deal breaker for me as well. Probably will powdercoat it after all. Thanks for reply
  12. Apr 18, 2021 at 6:26 AM
    Dansly56
    Dansly56 New Member
    daniel
    How much are those OEM end caps? I was going to order the ecoological but now that you pointed out that they don’t sit flush with the dog light I’m not sure now
  13. Apr 18, 2021 at 12:23 PM
    Badknees
    South Carolina
    I bought 2 plastic aftermarket caps off EBay for about $95 each. Had them painted by a local shop for $80 each. I think Sparks Toyota sells the complete painted caps but they are a little more pricey.
