So had to get my baby towed home tonight
Discussion in 'Audio & Video' started by tmart, Jan 1, 2018.
  1. Jan 1, 2018 at 8:20 PM
    tmart
    tmart [OP] New Member
    Travis
    I went to a guy from work to get a subwoofer system installed and he said he has done it tons of times. Everything went well and it was all installed but I realized my backup camera didn’t work anymore and he must have unplugged those wires or something. So he pulled the deck back out and started messing with wires tying them in to other wires and a bunch of lights on the dash came on. 4lo, VSC, traction control, and check engine light all were on. And for some reason the P for park and R for reverse etc would no longer light up. Then I started the truck and it barely started and idled super low at about 2-300 rpms and then died after a bit. I tried a couple more times and it kept dying. Then I unplugged the battery and let it sit for a bit and same thing happened. I noticed the battery gauge was almost as low as it would go so I thought it might have drained the battery causing the truck to spazz out so we switched a new battery in and it did the same thing. I have work in the morning so I tried to drive home and the battery slowly died, the deck shut off, then the whole dash including speedo went out and then the headlights started dimming and the truck died while I was driving.
    Does anyone have any sort of explanation? Did this guy fry my ECU computer, etc? Sounds like the alternator is for sure done. I know I should have had it installed at a shop that guarantees their work but it’s too late to worry about that, I just need it fixed. I’m going to have it towed to the dealership and hopefully they can figure out what my problem is and fix it, really started my new year off about as shitty as it could...
  2. Jan 1, 2018 at 8:21 PM
    tmart
    Travis
    I just don’t really understand how wires in the back of the head unit could possibly affect the lights on the dash and the way the motor runs. Unless it just sucked all power out of the battery or something
  3. Jan 1, 2018 at 8:27 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    That’s not good. Not sure what it could be for sure.
    Sounds alternator related but shouldn’t be caused by work behind the headunit.
    Drained battery while working is possible but if you got it jumped and started driving it would recharge via alternator.
    Maybe coincidence that alternator went out.
    Maybe fuse blew that is related to alternator.
    Les7311 likes this.
  4. Jan 1, 2018 at 8:36 PM
    tmart
    Travis
    Yes I jumped the original battery and had truck running and it was barely running and wouldn’t charge. Switched battery and same thing. Just very weird that headunit wires could effect so much. I’m scared, almost willing to take a loss on my loan and trade it in for a new one tomorrow. Hopefully it’s nothing too major
  5. Jan 1, 2018 at 8:42 PM
    nishibot
    nishibot Just2havnfun
    Perris, CA.
    2017 Tundra CM 4x4 TRD Off Road MGM
    It's been a lot of years since I installed stereo equipment, but how did your guy run power wire for amp? Did he use a fuse or straight to battery, sounded like a possible short to ground on power wire.
    Black Wolf likes this.
  6. Jan 1, 2018 at 8:56 PM
    tmart
    Travis
    He ran it straight to the battery I believe. I took the power cable off the battery so it’s like the system wasn’t there and it didn’t fix anything. It did some sort of damage
  7. Jan 1, 2018 at 9:03 PM
    nishibot
    Perris, CA.
    Next step I would start checking all fuses, but sounds like something did get fried unfortunately. I'm sorry you have to go through this.
    Black Wolf and Les7311 like this.
  8. Jan 1, 2018 at 9:11 PM
    What does the code read on the dash?
  9. Jan 1, 2018 at 9:40 PM
    tmart
    Travis
    I haven’t pulled any of the check engine codes but it had the 4lo light on, VSC, traction control and CEL. What a mess
  10. Jan 1, 2018 at 9:46 PM
    TheBeast The Beach
    what year is the truck ?
  11. Jan 1, 2018 at 10:36 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That would be my bet.
  12. Jan 2, 2018 at 1:21 AM
    JBSTOY
    JBSTOY Was tired, so I woke up.
    Jack
    Unknown Origen
    2008 Toyota Tundra SR5 4x4 5.7litres of goodness
    Bilstein 6112s Front Bilstein Rear Fuel Rims
    Might want to call someone like James Randy Taylor and see if he has any guesses as to what your guy might have done. It sounds like a connection was made that should not have been though. Sorry. That stuff is stressful.
    joem1cha3l likes this.
  13. Jan 2, 2018 at 1:24 AM
    tmart
    Travis
    It’s a 2008 limited. Such a terrible situation I’m stressing
  14. Jan 2, 2018 at 1:27 AM
    JBSTOY
    Jack
    Unknown Origen
    Ok. Try to get contact info for the pic in the next post. He might know something to help.
  15. Jan 2, 2018 at 1:29 AM
    JBSTOY
    Jack
    Unknown Origen
  16. Jan 2, 2018 at 1:47 AM
    tmart
    Travis
    Alright thanks for the help man
    ColoradoTJ likes this.
  17. Jan 2, 2018 at 5:54 AM
    JBSTOY
    Jack
    Unknown Origen
    I’m just thinking your installer might have cut or tapped into a wire that was not a good one. Maybe James has done something similar or knows something that might be able to help you out. Or maybe there is something special about that model of truck and there is something special that needs to be done to make it alright again. It is a shot in the dark, but it is still a shot. What part of the country do you live in?
  18. Jan 2, 2018 at 8:30 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    I had a similar a few weeks back, because I blow the dome fuse replacing the bulbs with LED— while the truck was running.
    Pop hood and check the ECM 7.5a fuse.
    I hiccup is I switched the blown dome fuse with the ecu fuse, not realizing the dome fuse was blown.
    Idled rough and VSC light came on.
    Update us
  19. Jan 2, 2018 at 10:48 AM
    Berettafan
    Berettafan New Member
    2017 CM
    I would first uninstall then check function. If no luck then check fuses.
    MotoTundra likes this.
  20. Jan 2, 2018 at 11:04 AM
    TundraTex
    TundraTex FRAC On!
    Lou
    DFW Texas
    '16 TSS CM 4x4
    There are CAN-bus wires in the Head Units harnesses. They're pretty thin gauge and since the bus goes everywhere, a cut or tapped bus wire can cause weird symptoms and lights.
    If that's what it is, then there really shouldn't be any long term effects or damage once it's repaired.
    It's pretty easy to identify the bus wires. They are a "differential pair" so usually the + and - signal wires will be twisted together in the harness run.
    mdavis likes this.
  21. Jan 2, 2018 at 11:10 AM
    MotoTundra
    MotoTundra The Ocho
    Don
    Definitely check those fuses. Everything should be protected by those fuses.
  22. Jan 2, 2018 at 11:40 AM
    ZPMAN
    Minnesota
    Sounds like you have a very good ground, I would do a quick check on all fuses then DQ everything that was installed and test to see if it's still drawing from batt.
  23. Jan 2, 2018 at 1:26 PM
    tmart
    Travis
    I’m in California. But the stereo system is already disconnected so now that it’s light out I’ll have to go check fuses. I’ll update this
  24. Jan 2, 2018 at 1:35 PM
    tmart
    Travis
    Forgot to mention, I checked all the fuses in the cab down by the parking brake and they were all good except for the cigarette lighter one. I changed it and nothing changed. I should be checking fuses under the hood? I’m sorry I’m not an electronics guy
  25. Jan 2, 2018 at 1:37 PM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    Unfortunately, you get what you pay for..
    mudslinger79 likes this.
  26. Jan 2, 2018 at 1:38 PM
    csuviper
    Broomfield, CO
    Yes check fuses in both locations
    darkknight2014 likes this.
  27. Jan 2, 2018 at 1:39 PM
    csuviper
    Broomfield, CO
  28. Jan 2, 2018 at 1:40 PM
    Taco-Blender
    Taco-Blender Old Guys Rule
    AZ
    2010 DC 4x4
    Yes, check all the fuses under the hood.
    Hope you can get it resolved, best of luck.
  29. Jan 2, 2018 at 1:45 PM
    tmart
    Travis
    That will be my next step and if I can’t uncover anything I will be taking it to the dealer. Thanks for all the help, only got one smartass answer! Just never thought installing subwoofers could screw up so much or never would have done it obviously
  30. Jan 2, 2018 at 4:39 PM
    Taco-Blender
    AZ
    2010 DC 4x4
    Life lessons Travis, we've all been there. Just praying it works out for you.
    Having said that, here's my old man words of wisdom. Unless I KNOW my "friend" is 100% capable I'll either attempt it myself (can only blame myself if it goes TU) or take it to a professional.
