So changed my diff oil and saw this
Discussion in '2.5 Gen Tundras (2014-2021)' started by texasrho83, Jun 9, 2019.
  1. Jun 10, 2019 at 3:17 PM
    texasrho83
    texasrho83 [OP] Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Dealer won’t do anything about it. Tech says it’s in “normal condition”. I told them it better be in writing on my ticket and I’m gonna keep it so that if my diff goes, I can show that the dealer didn’t wanna touch it.
  2. Jun 10, 2019 at 3:19 PM
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    It might be worth calling Toyota corporate and showing them the pictures. Worst case they agree with the dealer. You've got nothing to lose at this point.
  3. Jun 10, 2019 at 3:34 PM
    mojojo
    mojojo New Member
    2018 Cement SR5 CM
    That is what I was thinking would happen.
    However, your strategy is good imo. Keep your RO with date and mileage documented. If you do have a future issue, you will have some ground to stand on.
    ...but I think you're going to be just fine.
    Side note: you really should keep all of your ROs, because too often they are overlooked.
    I really don't think Toyota is going to disagree with this dealer's observation. I understand that you are put off by the size of this debris, but there's nothing notable about it that would prove it is from an internal component.
    ...I would be concerned if there was legible writing (as in a bearing race), or it was a shape that was easily identifiable (as in a broken gear tooth).
    I highly doubt that this finding will ever materialize into anything more for the OP.
  4. Jun 10, 2019 at 4:29 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    From what I can see by looking at your pictures on my phone, those are machining chips from the manufacturing of the axle housing that found their way to the magnet. It’s not altogether uncommon to find on the first drain of a diff, but they are alarming.
    For peace of mind, you can try cutting them with side cutters. If they are soft enough to cut, they are not from a bearing or a gear. Not that flakes from a bearing or chunks from a gear look like that.
    Failed thrust washer from a differential spider gear or side gear is possible if the washers Toyota uses are magnetic, but I’m not sure they are. Most are not.
    Any burnouts / one-tire-fires in your history?
    Sunnier, JohnLakeman, 15whtrd and 3 others like this.
  5. Jun 10, 2019 at 4:34 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    It just stinks that the closest dealership to my house is not one I want to do business with...worst customer service too.
  6. Jun 10, 2019 at 4:34 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I edited my post. Can you clean those two large flakes and post a close-up photo.
  7. Jun 10, 2019 at 4:36 PM
    Good point on the testing of materials Phil. Learn something new from you all the time.
    Then again, I have never seen anything like this come from any of my differentials either. Guess sometimes the QC inspector has bad days as well.
    This is why I drop fluids pretty quickly on a newly purchased vehicle. (5-10k miles)
  8. Jun 10, 2019 at 4:42 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Negative. Daddy don’t buy my tires.
  9. Jun 10, 2019 at 4:48 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Haha! Good. Pretty unlikely those flakes are munched up thrust washers then.
  10. Jun 10, 2019 at 4:50 PM
    This is my AAM 10.5” rear axle in my rock crawler (05 GM 2500 gas model truck). This had 160k miles on it, and I just swapped the carrier, gears, and sent it. Four years of some serious abuse, and I never get anything like that on my magnet. Some of you know first hand what kind of abuse.
    This was around 1 month ago.
    This would totally drive me nuts. I would be pulling the driveshaft, sliding the axle shafts out and pull the third member to see the gears, but I’m stupid like that. I wonder if a boroscope camera would be a better option?
  11. Jun 10, 2019 at 4:51 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    E23FA80E-D736-4B9C-845A-0CA438E840E9.jpg C7C3B1D3-DF11-4C10-B4E0-3E54436B5BE2.jpg
    Cleaned the biggest pieces up a little
    georgiey22, JohnLakeman and landphil like this.
  12. Jun 10, 2019 at 4:53 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Totally cuttings from drilling / machining the housing.
  13. Jun 10, 2019 at 5:50 PM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Yup. I agree. First pic of that big one has an "as cast" surface finish in my opinion. Manufacturing debris. Not clear on why it wasn't cleaned out, but if it sinks to the bottom and stays there, it isn't going to do any harm. :thumbsup:
  14. Jun 10, 2019 at 6:36 PM
    I would agree. Magnet did it’s job.
    Now we can all drink some beer/whiskey to celebrate!!!
    Ok, at least I will. lol
  15. Jun 10, 2019 at 8:01 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I’m on my 2nd whiskey as we speak lol.
  16. Jun 10, 2019 at 8:02 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Whew! Hope you’re right. Thanks for the sharp eye and help on this.
  17. Jun 10, 2019 at 8:05 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Thanks for the confirmation. I guess if the diff should fail, I’ve got <8k miles on my power train warranty and another 25k after that on my extended lol
    ColoradoTJ likes this.
  18. Jun 10, 2019 at 9:48 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Wouldn’t hurt to change the oil again before that warranty runs out just to see what’s new on the magnet, but I’m pretty confident you’re good.
  19. Jun 11, 2019 at 5:24 AM
    #49
    Trikerider
    Trikerider New Member
    2015 Limited CM
    I had similar thing on my magnet at when I changed at 60k miles, bought truck used at 56k miles. Was hoping it was machining bits leftover from manufacture as it didn't look like any of the internal parts had failed. I never did get it to a Toyota dealer yet, plan to get there soon to get Trans fluid changed and will bring this up. It was a cpo so I have a drivetrain warranty up to 100k miles. This and over winter I had would occasionally have the cold startup timing chain slap only two 'problems' so far.
  20. Jun 11, 2019 at 6:14 AM
    #50
    SRM18TRD
    SRM18TRD New Member
    18 TundraTRDOR
    Stock
    I had one of those at 10k..
  21. Jun 11, 2019 at 6:40 AM
    #51
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I wouldn't have freaked so bad over yours... mine had a piece of the Great Wall of China stuck to it
  22. Jun 11, 2019 at 7:21 AM
    #52
    :eek:
  23. Jun 12, 2019 at 4:27 PM
    #53
    TRD423
    TRD423 New Member
    Chattanooga
    17 SR5 TRD 4X4
    -20% tint all around and over factory -2” ToyTec leveling spacer -275 70 18 BFG KO2 -TRD duel exhaust -TRD Pro skid plate -TRD Pro grille -TRD sway bar -TRD performance air filter -vinal wrapped front bumpers -Xenon Vision led head/ fog lights and interior lights -AJT Design billet shift knob
    I changed all my differential fluids at 35k, owned my truck since new, and this is what came out of the rear.
    specter208 likes this.
  24. Jun 12, 2019 at 4:31 PM
    #54
    RitcheyRch
    RitcheyRch New Member
    Richard
    Santa Clarita, CA
    TRD Lowered and Supercharged
    This thread is making me consider changing my diff fluid and I only have 19K miles on my 2012.
    texasrho83[OP] likes this.
  25. Jun 12, 2019 at 4:33 PM
    #55
    SRM18TRD
    SRM18TRD New Member
    18 TundraTRDOR
    Stock
    I’m thinking you should, especially if you’re using that supercharger!
  26. Jun 12, 2019 at 4:40 PM
    #56
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Really no reason not to. It takes less than 30 minutes and doesn't cost much.
  27. Jun 12, 2019 at 6:14 PM
    #57
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    IF you don't buy the 75w-85 oil..... that stuff costs a small fortune.
  28. Feb 28, 2020 at 7:20 PM
    #58
    goldenlake
    goldenlake New Member
    Gary
    2017 Tundra 1794
    Gents, I have seen posts here of a similar nature from 2017 and like most of these posts I went in and had the rear differential oil changed for the 1st time at 64,000km. The dealer who can’t seem to point out in the owners manual or maintenance schedule when this should be done indicated at 100,000km. Anyhow I had it done at Mr Lube and guess what I found, some curved metal that look like shavings, maybe machine shavings. The number of posts related to this is concerning, poor QC by Toyota maybe, but front diff change was apparently normal. I think we all need a lot more information here as to what is going on in these diffs and I am struggling to chalk this up as poor cleaning from machining, really seems far fetched. Betting this is a more widespread issue than people know.
  29. Dec 17, 2023 at 8:27 AM
    #59
    Mr Badwrench
    Mr Badwrench New Member
    Old thread, I realize. What was your corrective action on this (if any)?
    I changed mine at 50K, looks absolutely terrible, definitely on par with yours.
  30. Dec 17, 2023 at 8:38 AM
    #60
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    I went with this company
    (Pic source: @Sumo91)
    They shipped me a case of 75w-140 and put 3 qts of 75W for the transfer case.
    Mr Badwrench[QUOTED] likes this.
