So a Lucky Blown Head Gasket ????
Discussion in '1st Gen Tundras (2000-2006)' started by Smily, Aug 6, 2020.
  1. Aug 11, 2020 at 2:24 PM
    Professional Hand Model
    Hand Protectors
    Nice Grasshopper! 9/10 Feather Dusters Award for you this week!
    Smily[QUOTED][OP], 270Fan and bmf4069 like this.
  2. Aug 11, 2020 at 2:34 PM
    Smily
    Smily [OP] New Member
    2004 tundra v6 pain in arse suicide door
    Someone put a crappy stereo in it
  3. Aug 11, 2020 at 4:17 PM
    Smily
    So done that and happy to say it passed so yippee lol and a pic of the siphoned off pretty pink, that shit tastes horrible omg20200811_160036.jpg 20200811_160535.jpg 20200811_155943.jpg
    Did test more than once since had so much blue juice to use so boom. Just wats next lol
  4. Aug 11, 2020 at 5:33 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Wow. Didn’t realise you had the 3.4. That’s probably the first one I’ve ever seen leak coolant.... clean the coolant leak and just keep an eye on it. Probably not even more that a tiny seep judging by photos
  5. Aug 11, 2020 at 5:42 PM
    Smily
    Does "Watch it" mean still rollin hill nd mountain to grandma's house and beyond...lololol
    It truly is a slow leak. I only have added the pink 3 or so times in the few years of ownership. I honestly feel I was sold it in this condition.
    Ya lol 3.4L truly drew the stinky end of the stick on this one.
  6. Aug 21, 2020 at 12:53 PM
    Smily
    So I'm gonna fix it, it looks like a 1/4" inch breach and it looks active. Haven't gotten to test it hard yet 7th grade distance learning started and the damn smoke is so thick. Getting my recall airbag done next week. I'm look to start this in prolly 2 weeks. I'm gonna use my sons gopro and film the entire process. He also can edit the video to watchable length or sequence of disassemble and assembly segments.
    -Plan to tear it down see what I'm dealt.
    -then order every thing (plugs/wires, h2o pump kit, new fasteners kit, hoses, all I come across) upon assessment of the leak
    -then CLEAN everything till parts arrive air flow sensor, throttle body
  7. Aug 23, 2020 at 9:30 AM
    empty_lord
    05 rollover special
    Toyota sells a complete top end gasket kit for a good price. Get the part number from the dealer then buy online. OEM gaskets are far superior to aftermarket on the 3.4
    Tundra2 and NewImprovedRon like this.
  8. Aug 23, 2020 at 11:17 AM
    Smily
    I got dealership quote of 500 bux from Piercy Toyota. A Fel pro set 300. I didn't figure the OEM would be better. Thx Empty_lord
  9. Aug 23, 2020 at 11:20 AM
    empty_lord
    05 rollover special
    I believe the kit your looking for is the valve grind kit. It has everything except rear main seal and all the gaskets you wouldn’t touch for head gaskets. But this is all new valve stem seals and all.
    Smily[QUOTED][OP] likes this.
  10. Aug 23, 2020 at 12:38 PM
    Hand Protectors
    Spend the $ with Toyota Gaskets.
    Tundra2 likes this.
  11. Aug 23, 2020 at 12:58 PM
    Hand Protectors
  12. Aug 24, 2020 at 7:54 AM
    Smily
    @empty_lord & @Professional Hand Model
    I thank you greatly for the info. And setting me straight on OEM gaskets cause I would have done the opposite.
    Is the Asin h20 pump kit still the king of the hill ??
    And wats u guys take on some vids saying
    .... to keep original pulleys because of the superior bearings and build quality of the OEM part ??
    I'm on the fence only cause truck has 105k on it. But I still lean towards using the new ones.
  13. Aug 24, 2020 at 8:27 AM
    empty_lord
    05 rollover special
    The Aisin kit, the bearings will be OEM
  14. Aug 24, 2020 at 12:01 PM
    Smily
    So got this beast for the day whilst my air bag is replaced. Boy o boy this thing isn't that fun to drive and dash computer says Average 18 mpg lolol same as my 04 tundra yikes
  15. Aug 24, 2020 at 9:50 PM
    Smily
    So what about preforming a leak down test to evaluate the condition of the engine ? Since all this gonna be quite a bit of work, thinking with the shit luck I've had with the truck so far would be smart to make sure its worth the effort.
    Any thoughts gentlemen.......
  16. Aug 28, 2020 at 1:59 PM
    Smily
    Any thoughts on the MLS gaskets ? What's the reasoning behind the OEM being superior?
  17. Aug 28, 2020 at 2:58 PM
    Hand Protectors
    Because we said! Now go getter dun!:rofl:
  18. Aug 28, 2020 at 4:10 PM
    Smily
    Lulz I am, I am. Need spanner wrench for springs in the cams and to torque and remove pulleys found OTC . I had a inch torque wrench at one point found another foot pound one I forgot about. So I'm looking at a bi-directional +/-3% one. And am ordering a 3 set of impact wobbles I never knew they existed lol. I'm also reading tech and watching videos in between helping him with the distance learning school.
    And over thinking lol I'm like that sometimes on firsts.
  19. Aug 29, 2020 at 10:40 PM
    #49
    empty_lord
    05 rollover special
    The OEM is MLS
    ktundra and Smily[QUOTED][OP] like this.
  20. Sep 5, 2020 at 7:57 PM
    #50
    Smily
    Had a sewer leak under my house split wye.
    Hopefully quick Help...
    If the hood struts are removed will the hood pivot back against the windscreen??
    Thx
    And yes I'm getting it done lol
  21. Sep 5, 2020 at 8:04 PM
    #51
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    I don’t think those brackets have that much rotation on em, even if they did I think thats a bad idea anyway.
    Completely remove the hood if its in your way? Should be the two gas struts, the four 12mm bolts, and your windshield washer hose.
  22. Sep 5, 2020 at 8:33 PM
    #52
    Smily
    Ya most likely lol find out tomorrow.
    I wanna replace all the bolts and I cant find chit. May I beg on the masters for a bone please.
  23. Sep 9, 2020 at 1:12 PM
    #53
    Smily
    So over looked TDC on #1 on compression. Dont have compression guage.
    With #1 plug out won't something plugging the hole blow out on the up stroke of compression/ detonation and the timing mark will be at 0°'s and the cam shaft Mark's will align then if the valve covers off the cam gear fits would also align
    Correct ?
  24. Sep 9, 2020 at 1:27 PM
    #54
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    At TDC, all the dots should align.
  25. Sep 9, 2020 at 2:00 PM
    #55
    Hand Protectors
    Smily[OP] and FrenchToasty like this.
  26. Sep 9, 2020 at 2:41 PM
    #56
    Hand Protectors
  27. Sep 9, 2020 at 3:18 PM
    #57
    Smily
    Ok then that's it. But belt stripe off a few notches.
  28. Sep 9, 2020 at 3:31 PM
    #58
    Hand Protectors
  29. Sep 9, 2020 at 4:02 PM
    #59
    Smily
    Yes. Left side, drivers
  30. Sep 9, 2020 at 4:08 PM
    #60
    Hand Protectors
