Snugtop Pop up lock
Discussion in 'Tonneau Covers, Caps and Shells' started by Yeshualewis, Nov 14, 2019.
  1. Nov 14, 2019 at 11:30 AM
    Yeshualewis
    Yeshualewis [OP] New Member
    2005 Gold Tundra TRD Access Cab
    I have a snug top shell with a pop up lock. It doesn't lock though when I push the lock in. The key turns it just fine but the lock itself doesn't stick closed, it just keeps popping out. I don't want to just buy a new one until I understand what the actual problem is (plus it's $60 that I don't want to spend if I don't have to)
  2. Nov 14, 2019 at 11:38 AM
    RangerBP
    RangerBP SC Expat. Go gamecocks.
    2017 4x4 DC, Silver Sky
    The snugtop I had on my taco was a pop-out handle. It was the worst.
    If I recall correctly, if you turned the key like a 1/4 or half turn, it would pop out to open. If you removed the key without returning it to the neutral (straight up position), there were little brass ears that would retract keeping it from locking in the “in” position.
    This was normal operation for these.
  3. Nov 14, 2019 at 12:29 PM
    Yeshualewis
    Thanks for that. Do you have a picture by chance of the brass ears?
  4. Nov 14, 2019 at 1:54 PM
    RangerBP
    I don’t. It was on a truck that I no longer own.
    When the handle was extended (not nested), the brass pieces were on either side of the neck of the t-handle.
